AZ-EQ6/Atlas Pro issue
40 replies to this topic
#1 Lee Jay
Lee Jay
  • Loc: Westminster, CO
Posted 11 June 2013 - 04:08 PM
Can some owners check this out for me?
On my mount, in Alt-Az mode, manual motion with the arrows, speeds 4, 5 and 6 are all exactly the same speed for me. The other speeds all appear normal.
Is it just my mount, or is this the same for others as well?
I've got hand controller firmware 3.34 and motor controller firmware 2.05.
Thanks.
#2 Mike X.
Mike X.
  • Loc: Greece-Athens and Rome-Italy
Posted 11 June 2013 - 04:36 PM
Just checked my mount, they move in different speeds.
I too use firmware version 3.34
#3 Lee Jay
Lee Jay
Posted 11 June 2013 - 08:55 PM
Thanks for checking.
Do they all sound the same?
#4 Mike X.
Mike X.
Posted 11 June 2013 - 09:22 PM
No problem, no they sound diferent.It is similar but different.
#5 Lee Jay
Lee Jay
Posted 11 June 2013 - 09:36 PM
Well, something is odd with mine. They all sound the same, and timing them shows them all going at the same rate - in both axes. Since the manual says they should each be a factor of 2 apart, the difference should be pretty obvious.
#6 Mike X.
Mike X.
Posted 11 June 2013 - 10:22 PM
Have you tried to check the speed via EQMOD?
If it works fine it might just be a defective Hand control
#7 Lee Jay
Lee Jay
Posted 11 June 2013 - 10:42 PM
I've never used EQMOD.
Orion is offering me a new hand control to test, so that should tell the tale.
#8 Mike X.
Mike X.
Posted 12 June 2013 - 01:19 AM
I hope that solves your problem too ;)
#9 Moromete
Moromete
  • Loc: Romania
Posted 12 June 2013 - 03:29 AM
Would you be so kind and post 2 close up images: A)one with the inferior part of the mount head where it makes contact with tripod and has the middle whole for big screw, and B)one with the upper part of tripodwhere it makes contact with the mount head?
I want to see if the AZ-EQ6 can be mounted on a CG5-GT tripod without problems/adapters.
Thx.
#10 Mike X.
Mike X.
Posted 12 June 2013 - 02:48 PM
The tripods are identical,I have a cg5 too. If there is a difference that is in the "tooth" they have in the middle for the alt-az adjustment..which is black on the azeq6 and probably a little shorter ...
I will do a couple of shots ASAP though so you can have a look ;)
#11 Moromete
Moromete
  • Loc: Romania
Posted 14 June 2013 - 06:20 AM
So you are saying that is possible to mount the AZ-EQ6 head on CG5-GT tripod without problems if you take out that "tooth"?
I'm waiting for the those shots.
#12 Mike X.
Mike X.
Posted 14 June 2013 - 04:07 PM
Yep, even with the tooth I guess ,but that can be removed in a very easy way and changed with the proper one.
Sorry for the delay,I will take the shots,I just didn't had time not even to go back home from the hospital the last 48 hours. I believe during this weekend to be able to send you the photos both of the tripod and the mount base. ;)
#13 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 15 June 2013 - 11:33 AM
This is very unlikely. The AZ-EQ6 should have the same base as the EQ-6 and that base is not the same as the CG-5.
#14 frolinmod
frolinmod
Posted 15 June 2013 - 04:44 PM
I can confirm that the AZ-EQ6 has the exact same base as the EQ-6 and the only difference between the Sky-Watcher and Orion versions of the same mounts is the color (white vs black).
#15 rmollise
Posted 15 June 2013 - 05:49 PM
That's true...but...as Ed says, the EQ-6 bases are different from the CG5 and the tripods are NOT interchangeable. ;)
#16 frolinmod
frolinmod
Posted 15 June 2013 - 06:09 PM
Uncle Rod, I didn't say anything different. In fact I confirmed what Ed was saying. I think you're just getting crotchety in your old age Uncle Rod... :smirk:
#17 Mike X.
Mike X.
Posted 15 June 2013 - 07:24 PM
Not interchangeable?? Omg..I was convinced they were identical!!!
I was actually thinking on using my cg5 tripod with the azeq6 ...I ask sorry if I messed up lee jay
#18 rmollise
Posted 15 June 2013 - 11:18 PM
Who ME????!!!!! :shakecane: :lol:
#19 Moromete
Moromete
  • Loc: Romania
Posted 16 June 2013 - 01:06 AM
In short you are 100% sure that I can't put the AZ-EQ6 head on CG5-GT (not CG5) tripod?
I'm not interested in puting the CG5-GT head on AZ-EQ6 tripod.
#20 Seiko4169
Seiko4169
Posted 16 June 2013 - 03:37 AM
Can someone please confirm whether sky safari does work properly when the mount is in alt-az mode? I hear / read conflicting reports? I've seen a YouTube clip suggesting it does but this appeared to be an indoor test?
Thanks in advance
#21 EFT
EFT
  • Loc: Phoenix, AZ
Posted 16 June 2013 - 10:28 AM
Yes, we are certain.
#22 Moromete
Moromete
  • Loc: Romania
Posted 16 June 2013 - 01:00 PM
Oh, that's so unfortunate because I have a CG5-GT mounted on a pier and I thought I could replace the CG5-GT head with the AZ-EQ6 head on the same pier but it seems that's not possible... :bawling:
#23 rmollise
Posted 16 June 2013 - 02:58 PM
Nope...sorry.
#24 johnpd
johnpd
  • Loc: Green Valley, AZ
Posted 17 June 2013 - 02:30 AM
Thanks in advance
Check the Sky Safari (Southern Stars) Yahoo forum. When I first tried Sky Safari on my AZ-EQ6, the left arrow button was not functional making it impossible to center objects if I needed to move in that direction. I have not tried it again as I did not hear of any fix made. There were several other issues posted there recently. Another person ran into issues with the UP/DOWN arrows. Someone in the group offered a potential solution. No one has replied back to see if that worked.
JohnD
#25 Seiko4169
Seiko4169
Posted 17 June 2013 - 07:37 AM
Thanks in advance
JohnD
Thanks John.
