Bolt size to attach Rob Miller tripod to levelers
3 replies to this topic
#1 ebeyonder
ebeyonder
  • Loc: Singapore
Posted 16 June 2013 - 04:33 AM
Hi all,
I have the Rob Miller tripod Tri36L and the regular levellers (the one on the left).
I was wondering if anyone knows the exact bolt size to attach the levellers to the tripod legs? There are 4 for each of the three levellers.
#2 M13 Observer
M13 Observer
Posted 16 June 2013 - 01:37 PM
Hi all,
OK, so how did you manage to get the levelers without the bolts to attach them?
Bottom line is that you have 4 perfectly good bolts to figure it out with screwed into the bottom of each footpad in the TRI36L. Take one out, figure out what it is (probably 10-32) and add 1/4 inch to the length.
#3 M13 Observer
M13 Observer
Posted 16 June 2013 - 01:52 PM
Yep, that's it, 10-32 x 3/4". Both sets of levelers were supplied with and installed with a 1/16" thick washer on each bolt in that pic. If you can get 10-32 x 5/8" without a washer they would probably be really close to perfect.
#4 ebeyonder
ebeyonder
  • Loc: Singapore
Posted 16 June 2013 - 06:37 PM
Thanks. I had taken the bolts out and lost them all. Now I want to reattach everything. I will try the size you suggested. Thanks very much!
