IC-1316b & NGC-6910
7 replies to this topic
#1 blueman
blueman
    Photon Catcher
  • Loc: California
Posted 18 June 2013 - 02:49 PM
This is my last image for June. It is half of the Butterfly and NGC-6910 an open cluster in Cygnus.
( large 1/2 Scale) http://www.astrophot...php?photo=11501
(smaller image) http://www.astrophot...-1316b-rgb.html
20 x 10 minutes each filter RGB
TEC-140@ f/5.4
ML8300 Astrodon Gen2 Filters
AP900 mount
#2 WhistleStop
WhistleStop
  • Loc: Grafton, Ontario
Posted 18 June 2013 - 04:11 PM
Nice image and framing...well done.
BTW what reducer do you use on the TEC140 for f5.4 ??
Lynn
#3 blueman
blueman
    Photon Catcher
  • Loc: California
Posted 18 June 2013 - 08:08 PM
Lynn
HI Lynn, Thank you.
I use an AP-27TVPH reducer with the TEC-140 and it works very well.
Blueman
#4 WhistleStop
WhistleStop
Posted 18 June 2013 - 08:30 PM
Thanks Blueman...do you also need a field flattner ?
Cheers
Lynn
#5 blueman
blueman
    Photon Catcher
  • Loc: California
Posted 18 June 2013 - 11:14 PM
Cheers
Lynn
Hi Lynn,
I have the TEC flattener but it is not used with the reducer. The AP reducer does flatten some as well as reduce. If my chip was larger then it would not fit the circle and I would have to use the TEC Flattener instead.
Blueman
#6 WhistleStop
WhistleStop
Posted 18 June 2013 - 11:22 PM
Thanks for the input.... I have the same camera, wheel and scope so hence the interest.
Cheers
Lynn
#7 blueman
blueman
    Photon Catcher
  • Loc: California
Posted 18 June 2013 - 11:47 PM
Cheers
Lynn
I have a picture of the complete setup. It used off the shelf parts and adapters, Starlight (feathertouch) provided the focuser to reducer adapter. Then I used other parts from AP as I recall and some shims from McMaster Carr to set the distance. But the photo is labeled with all the parts. Send me a PM if you need more information or I could post the photo here.
Blueman
#8 blueman
blueman
    Photon Catcher
  • Loc: California
Posted 19 June 2013 - 12:33 PM
Cheers
Lynn
Blueman
Here is a photo of the setup. This should help visualize it.
Blueman
