Saturn 6/23/13, 6-7/10 seeing
13 replies to this topic
#1 azure1961p
azure1961p
  • Loc: Triton
Posted 23 June 2013 - 10:20 PM
I finally had views that exceeded 6 Pickering. I was out with my 70mm achro as its rising earlier and earlier and I set up around 10 so, I did the quick 30 minute observation before it sank appreciably.
Cassinis: this isn't the best this scope has seen it but its the best view this year. Typically it forms a gradient or soft blend that joins the contrasting a and b rings, tonight it was better defined as reflected in the sketch. Nicer nights have it nicely etched.
Globe: not a hint of the Hex spot . Just a uniform grey all the way through save for the EZ. In the past Ive seen a temperate zone but it'd been a while since the .hlobe has presented one bold enough for my 2.7" refractor. Indeed, in 6/10 seeing its quite subtle d en with the 8".
A clean sterile globe.
The Crepe Ring where it crosses the globe was easier than Ring As shadow but both were quite delicate. The dual shadows only showed in the best moments. The shadow of the globe on the rings was far more robust.
Color was a very very subdued cream grey that was virtually colorless.
Best views were at 133x with a 9mm abbé and 2.5x Barlow. Going higher to 162x wasn't bad at all - but it didn't bring anything new to the table.
Didn't bother with filters. It needs more aperture for that.
The nicest view in a while. Not stellar but not bad. Danced around frequently in the seeing.
Pete
#2 frank5817
  • Loc: Illinois
Posted 23 June 2013 - 10:45 PM
Pete,
That is better than my view with a slightly larger reflector so far this year. Saturn really needs steady skies or a very long time waiting for a brief glimpse.
You really did capture great detail with 70mm.
Frank :)
#3 azure1961p
azure1961p
  • Loc: Triton
Posted 24 June 2013 - 10:06 AM
Thanks Frank. I drew Cassinis a little sharper than I should have. That's more indicative of 8/10 seeing. Its extent is the same but it was a little softer edged. Ill see if I can't drag out the 8" tonight weather willing.
Pete
#4 niteskystargazer
Posted 24 June 2013 - 01:22 PM
Pete,
Very good sketch of Saturn :).
#5 Tommy5
Tommy5
  • Loc: Chicagoland
Posted 25 June 2013 - 05:04 PM
Nice sketch of Saturn with a modest aperture , good rendition of the shadow of the globe on the rings.
#6 E_Look
E_Look
  • Loc: near New York
Posted 26 June 2013 - 12:03 AM
There was no darkening toward the extreme polar areas that night, I suppose. Hey! Why not your 8"? I'll bet that'll get some more detail! A nice sketch: smooth shading technique, everything proportionally as they should be according to my memory of views of Saturn recently. To my eyes, though, the planetary shadow on the ring is usually darker, but that could just be me.
#7 kenrenard
kenrenard
  • Loc: Dunmore, PA
Posted 26 June 2013 - 06:29 AM
Nice work Pete,
I always like to see what can be seen in a small scope. Folks are often amazed what a 70mm refractor can do.
Ken
#8 azure1961p
azure1961p
  • Loc: Triton
Posted 26 June 2013 - 08:13 AM
Thanks guys. Ed there wasn't a prayer of polar darkening that night through that scope. Not that it hasn't shown at other apparitions - and a temperate zone too. The shadow of the globe on the rings is representative of what I saw though the crepe band and ring shadow on globe are a little understated. Ehhh - it was a 30 minute observation afterall :).
Pete
#9 BoldAxis1967
BoldAxis1967
  • Loc: Kentucky
Posted 29 June 2013 - 11:18 AM
Hi Pete. Enjoyed your report. Nice work. What is the Hex spot and the Crepe ring?
I frequently learn something reading these kinds of reports and looking at others' observations.
LB
#10 BoldAxis1967
BoldAxis1967
  • Loc: Kentucky
Posted 29 June 2013 - 02:17 PM
Ah, The Hex is the Polar region?
#11 PeterDob
PeterDob
Posted 30 June 2013 - 08:41 AM
Well done Pete! In spite of the modest aperture you brought out a lot of detail.
Peter
#12 Messyone
Messyone
  • Loc: Down Under
Posted 05 July 2013 - 06:11 PM
Nice sketch. Amazing what can be seen with small scopes. I use a 70mm f7 achro as a finder but will have to put in an XW 7 or 5 and see what that looks like, only problem is the plastic focuser...it's a bit nasty.
Matt
#13 azure1961p
azure1961p
  • Loc: Triton
Posted 06 July 2013 - 08:12 PM
Thanks guys. That was an enjoyable observation. The views through the 70mm while a but simple compared to my 8" still are very attractive to me for the clean look a 130x Saturn can have with a nice refractor. I'm glad others feel the aperture can provide good views too.
Pete
#14 ericj
ericj
Posted 15 July 2013 - 08:55 AM
Nice sketch Pete, you picked up a lot of detail in your sketch.
Best,
Eric
