Making a 6 inch Chief
13 replies to this topic
#1 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 25 June 2013 - 12:51 PM
I've been working on a 6 inch Chief. I'm trying Dave O's idea of mounting the upper OTA on a tripod in the corner. Shown here is the work in progress (two of the legs will be added later) to get a sense of what it will look like. Temporary Zip ties are holding the tube on the cradle.
#2 kfrederick
kfrederick
Posted 25 June 2013 - 01:33 PM
Looks nice! I had to use a green laser to find where mine was looking .It will not be centered an any axis . Setting circles will work but more setup is needed [I ask] There is a very large offaxis reflector mounted that way .See if I can find the link . over several meters diameter .
#3 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 25 June 2013 - 02:45 PM
Interesting, and probably a lot more approachable for a potential first time Chief builder. What are the ranges of focal ratios at that aperture?
#4 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 25 June 2013 - 03:41 PM
This one is F/12 and uses COTS lenses which I still need to order. I had made a couple of primaries a few years back and thought I go ahead an build it even though I already have another 6 inch Chief. An awesome performer I might add. I picked up a nice painted 80 mm telescope off Ebay although nobody makes a focuser for it. This one is a reflector focuser without the base.
#5 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 26 June 2013 - 08:20 AM
The lens holder is PVC doughnut machined slightly smaller than the lenses and cut to a 15 degree wedge (the angle between the lenses) on a table saw. The delrin clips were made on a lathe to have a step equal to the edge thickness of the lenses then drilled off center. These can be rotated to center each lens in X and Y measuring with calipers from the edge. Brass pins were placed on the diameter as a rotation axis held in place by a tight fitting ring. This ring was cut from the left over tubing with a key filed into the ends to act as a solid ring. This allow the holder to be placed anywhere in the tube or rotation. Pretty slick.
#6 Dave O
Dave O
  • Loc: Sri Lanka
Posted 26 June 2013 - 08:28 AM
"Pretty slick" is right! Wow! I particularly like your idea for adjusting the de-centers ... be sure to let us know how well that works (thinking it will be a bit of trial and error in adjusting these things?)!
I like 'simple' things, and this lens cell is getting simple enough to where even I may have to give it a go!
Cheers. Dave O
#7 kfrederick
kfrederick
Posted 26 June 2013 - 10:43 AM
The thing you showed me about tipping the lens 90deg to the optical axis to see if the laser reflects back on its self Cannot be done with this? I like that on the 20. as it get the one axis of each lens nailed. Square Very nice Is there a baffle at the secondary? Are you going to Stellafane??
#8 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 26 June 2013 - 11:03 AM
The centration ought to be straightforward. In the X direction (axis of pins) the centration is zero and I can measure from the edge to make them equal with calipers. In the Y direction (wedge direction) the concave lens should be .027 inch farther than the convex lens from the thin edge. I can set the perpendicularity by checking with a laser, (rotating the holder). Finally if the holder rotation axis is off the holder can be rotated in the tube or the tube can be rotated in the cradle if I see any non-orthogonal astigmatism. That's the plan anyway.
#9 kfrederick
kfrederick
Posted 26 June 2013 - 11:19 AM
Only the laser target and holder rotation need to be in correct rotaional axis with each other And the distance to focus from the last surface . Nice Should be simpler to setup . Move the whole top up till the moon focuses at the correct distance .
#10 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 26 June 2013 - 11:44 AM
Stellafane?
I doubt it.
#11 kfrederick
kfrederick
Posted 27 June 2013 - 04:50 PM
Be nice some year For you and me to enter the 20 Chief as a joint build . Guess we should have done that 4 years back. Nice telescope .I guess you making a platform for it ?
#12 Ed Jones
Ed Jones
  • Loc: Sin-sin-atti
Posted 27 June 2013 - 06:26 PM
I already have a platform for it. It should fit in my other 6 inch rocker box as well, at least temporarily. Here's the prescription BTW.
#13 kfrederick
kfrederick
Posted 28 June 2013 - 08:06 AM
http://www.toweropti...erOptical27.pdf
#14 kfrederick
kfrederick
Posted 28 June 2013 - 08:08 AM
http://www.toweropti...erOptical25.pdf
