manual setting circles
3 replies to this topic
#1 donnie3
donnie3
  • Loc: bartlesville oklahoma
Posted 27 June 2013 - 11:00 AM
ive ask this question before but lost my notes that I wrote down. I have a altazimuth mount with manual setting circles. I would like to try them out but not sure how to use them, the instruction manual does not have any info, on the subject. I have a kindle fire tablet and a laptop running windows 7, what would be a good program to get the altazimuth coordinates with.i would appreciate some instructions on this. thanks, donnie
#2 rmollise
Posted 27 June 2013 - 12:00 PM
The mount needs to be as close to level as you can get it. Point the scope at Polaris and set the azimuth circle to 0. You will now need the services of a computer program that will give the current altitude and azimuth of objects--most planetarium programs will. point at a bright star, perhaps, and set the altitude circle to the current altitude as given in the program. Azimuth should be correct. Now, just get the alt-az of the object you want to view and move the scope until the circles indicate that altitude and azimuth. What kind of accuracy? If I level my 8-inch Dobbie carefully, it will put some objects in the field of a low power eyepiece and most within about a degree or so, but it has a large azimuth circle and a level indicator for altitude and is likely more accurate than small circles on an alt-az mount.
#3 donnie3
donnie3
Posted 27 June 2013 - 12:32 PM
uncle rod, thanks for the instructions. I printed this out and put it where i can find it when needed. thanks again. Donnie.
#4 Tom and Beth
Tom and Beth
  • Loc: Tucson, AZ
Posted 27 June 2013 - 12:37 PM
Hey Donnie
Use your mouse and highlight Rod's reply. Right click, then choose "copy". Left click on your start button, then choose->all programs-> accessories-> notepad
Paste
Save as a text file in your "Documents" folder.
