.965 eyepiece extension
10 replies to this topic
#1 SuperSirLink
SuperSirLink
  • Loc: S.Valley, Va.
Posted 29 June 2013 - 10:05 AM
I have an 8x50 finder that uses .965 18mm eyepiece with 90 deg. diagonal. If I take the diagonal off, then I can't extend the helical focuser out enough to achieve focus.
So I am looking for a way to extend the focus out so I can spot without the diagonal. Most barlows I have found for .965 are 3x and way too long.
Holding the eyepiece back, it looks like I wouldn't need more than 2 or 3 inchs. Does anything exist that would help here?
#2 tubehead999
tubehead999
  • Loc: Kennesaw, GA
Posted 29 June 2013 - 11:47 AM
You can try this....
http://www.ebay.com/...copes-/36067...
Should give you the two inches and more that removing the diagonal requires. Of course, you will have to probably punch the barlow out.
#3 roscoe
roscoe
    curmudgeon
  • Loc: NW Mass, inches from VT
Posted 29 June 2013 - 08:51 PM
I took apart one of those double-prism image-erecting EP adapters, and found that the two end-pieces screwed together..... an instant inch of extension!
Russ
#4 SuperSirLink
SuperSirLink
Posted 30 June 2013 - 08:50 AM
Might give that barlow a try...
Roscoe, do you have a link so I can see?
#5 SuperSirLink
SuperSirLink
Posted 30 June 2013 - 05:55 PM
Here is the back end of the finder...
#6 tomharri
tomharri
  • Loc: along the I-10 corridor
Posted 30 June 2013 - 06:04 PM
Try this guy:
http://www.cloudynig...00&ppuser=25634
#7 SuperSirLink
SuperSirLink
Posted 30 June 2013 - 06:26 PM
Hmm, he had one, but he sold it already... bummer
This is the same one I have, wonder if I can find that extension... :/
http://www.cloudynig...ct=50951&sor...
#8 roscoe
roscoe
    curmudgeon
Posted 30 June 2013 - 10:45 PM
I'll try hard to remember to take a photo of it tomorrow and post it for you....
R
#9 SuperSirLink
SuperSirLink
Posted 01 July 2013 - 05:30 PM
Thanks much!!
#10 roscoe
roscoe
    curmudgeon
Posted 02 July 2013 - 07:50 AM
Here's a photo of my extension:
As I said, I took both the focuser-end tailpiece and the EP-holder out of one of those cylindrical image-erector adapters that came with lots of older 60mm scopes, and in my case, they screwed together. I looked at another one I have, and both ends screwed into the round prism-housing, so that one wouldn't work......
I also have a short 2x barlow that came with a newer 60mm that's around 3" total length, which would work as an extension if the lens was removed, but it's plastic, so might not be real durable.....
Unfortunately, I messed up the best photo of my adapter shrinking it to post here (my computer's a linux os, and the photo program is a bit more complicated than my mac was...) so here's the second-best view.....
#11 SuperSirLink
SuperSirLink
Posted 02 July 2013 - 06:51 PM
Ahh ok, thanks for sharing that... I found someone here in the classifieds with an extension for sale. But if that doesn't work, I guess I will just get the vixen adapter and convert it to 1.25"...
