Does a mount have to be perfectly level?
18 replies to this topic
#1 Dan F.
Dan F.
  • Loc: Kalamazoo, MI
Posted 30 June 2013 - 02:42 PM
Yesterday I was out helping a friend level his iOptron iEQ45, and we got it pretty close. Does it have to be perfect, though? Why or why not? This is a GEM and is permanently mounted to an 8" diameter pier. See the attached photo for a depiction of how close we got it.
#2 andysea
andysea
  • Loc: Seattle, WA
Posted 30 June 2013 - 03:07 PM
As long as the mount is well polar aligned it does not need to be perfectly level. It will work fine the way you have it.
If you had a portable setup, depending on the design of your polar scope, you might need to level it in order to polar align but that does not appear to be your case .
You probably will permanently drift align anyway correct?
Some people will tell you that the mount will work better if it's level because it's better balanced. That is a good point but you seem to be close enough.
#3 bb4
bb4
Posted 30 June 2013 - 03:12 PM
I agree with andyse.
I posted the same question about 4 years ago and the general consensus was leveling is absolutely NOT necessary for proper polar alignment, but having a mount that is properly leveled will greatly facilitate and expedite polar alignment. So while it is not necessary, it is recommended, especially for AP.
Cheers
#4 gdd
gdd
  • Loc: Lynnwood, WA (N/O Seattle)
Posted 30 June 2013 - 03:35 PM
I agree with bb4, it is not necessary to level the mount but it does make polar alignment easier. I level the mount so Polaris will appear in the FOV of the polar scope with at most a nudge to the east or west. I line up the tripod legs to the patio e/w line, so usually nudging is not needed.
Your mount is permanently on a pier, so you don't really need to worry about re-doing the polar alignment.
Gale
Gale
#5 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 30 June 2013 - 03:49 PM
Not required. It will make your ability to polar align it significantly easier since you're only deal with one axis at a shot.
#6 Doug D.
Doug D.
  • Loc: Virginia
Posted 30 June 2013 - 04:15 PM
I guess it depends on your perspective - if a level mount makes it easier to polar align (which it does) then in my book, it is "required" LOL. It isn't particularly tough to do - at least with my gear - so, why not do it? For a permanent mount on a pier, I would certainly try to get as level as possible.
Dan - just curious why you were unable to get the bubble centered. Can you somehow shim if necessary?
#7 rmollise
Posted 30 June 2013 - 05:43 PM
GEMs? No. In fact, alt-az go-to systems don't need to be perfectly level, either, though in their case it can help them land closer to the initial alignment stars...
#8 cn register 5
cn register 5
Posted 30 June 2013 - 05:52 PM
What does "perfectly level" mean?
+- 5 degrees?
+- 1 degree?
+- 0.5 degree?
+- 10 arc minutes?
+- 1 arc minute?
+- 30 arc seconds?
+- 1 arc second?
"Perfectly level" could be said to be far better than these. In reality within a degree is easy, just looking at the mount may be OK. getting to better than 6 arc minutes might be achievable with a builders level. Better than this will need surveying instruments.
What effect does not being level have on alignment or polar alignment? I think that being level hardly matters for alignment and goto and that more or less level - within a degree or two - will be OK for polar aligning.
Chris
Getting to a degree
#9 andysea
andysea
  • Loc: Seattle, WA
Posted 30 June 2013 - 06:14 PM
Good point about drift aligning! My post was actually misleading, thanks Chris for bringing this up.
If you are drift aligning you want to be as close as level as possible so that your adjustments in alt won't affect your adjustments in az. How close? I don't know. My guess would be less the one degree in either direction, however perhaps someone could do the math to better advise you.
#10 Dan Finnerty
Dan Finnerty
  • Loc: Pasadena, CA
Posted 30 June 2013 - 07:38 PM
Some simple trigonometry lets us estimate how close is close enough.
cosine of 10 degrees = 0.984807753, sine = 0.173648178
cosine of 01 degrees = 0.999847695, sine = 0.017452406
The sine (side opposite on a right triangle) is the relevant value for this discussion. It tells us how much the orthogonal axis "cross-couples" to movement on the other axis.
For instance, if you adjust the azimuth axis by one degree and the mount is out of level in azimuth by 10 degrees, the axis will move in elevation by 0.17 degrees. That is a substantial amount.
If you are within 1 degree of level, the cross-axis movement is 1/10th as much, or 0.017 degrees.
To me, this says get within a couple of degrees of level for visual and less than a degree for astrophotography and your life will be simpler when aligning the pole. On the other hand, you can just iteratively adjust both az and elevation and you will converge on accurate polar alignment pretty quickly.
#11 iluxo
iluxo
Posted 30 June 2013 - 09:54 PM
No it does not need to be level - at all - you are on a SPHERICAL EARTH. A mount that has some random tilt error is merely equivalent to using a mount at some other place where the angular shift around the globe in latitude or longitude equals the tilt error.
A tilt error in the north-south direction is equivalent to the telescope being exactly level at some slightly different latitude.
A tilt error east/west is equivalent to the telescope being level at a slightly different longitude and/or a constant error in the local siderial time (if you calculated that).
The mount will compensate for these errors automatically.
The only issue anyone may face is when they are relying on precise coordinates of the site location (eg GPS) for computerised tracking using an altaz mount, but the telescope is not level.
#12 Astronewb
Astronewb
  • Loc: Connecticut
Posted 30 June 2013 - 11:18 PM
I agree with everyone, it doesn't have to be perfectly level, just as close as you can get it. But once you have it there, and are going to reference it, or use for all future viewing, then you want to get your RA and DEC axes squared to your level, to make everything as orthogonal as possible. In other words, you need to establish a zero point.
http://www.astronomy...stablish-zer...
Clear skies,
Paul
#13 Dark Matter
Dark Matter
Posted 30 June 2013 - 11:53 PM
IMHO yes, if you want precise pointing and tracking. I have seven permanent GEM's and all are dead-level. I used an Engineer's level then checked that with a GPS and found both good. Once a drift alignment was done, I can get within 30 arc secs or so of the target.
#14 WadeH237
WadeH237
  • Loc: Snohomish, WA
Posted 01 July 2013 - 01:52 AM
Assuming that it is an equatorial mount and is correctly polar aligned, it does not matter *at all* whether the tripod, pier, mount base, or whatever, is level. You could hang the mount upside down from (very steady) tree branch, and as long as it was polar aligned, it would track fine. Goto would also work, except that most - but not all - goto systems will try and avoid colliding with the tripod or pier, and might be confused by being excessively out of level. I believe that the main purpose of index marks or home switches is to establish the mount orientation to the tripod/pier, and is not even necessary for tracking or goto on an equatorial mount.
As has been said, having the mount very close to level can help you to achieve an accurate polar alignment. This is because polar alignment is achieved by adjusting the mount in altitude and azimuth - and if the mount is not level, a change in altitude also affects azimuth and vice-versa. Even with this, it's still possible to achieve polar alignment, but you may require more iterations of adjustments.
-Wade
#15 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 01 July 2013 - 07:40 AM
Using the bubble fitted to a tripod may get you "near level", and maybe good enough for visual work.
Alas, mount manufacturers do not state level sensitivity, usually quoted in mm/m (or in/ft). Bubble levels as provided on mass-produced equipment are quite poor, and are generally accurate enough to indicate which way is up.
Further innacuracies arise when the level fitted to the tripod are not parallel to the mount head base. I've seen some bubble levels in mounts that were several degrees off level. I get the feeling that assemblers feel that the bubble level is purely cosmetic and just make sure the installation looks neat, rather than accurate.
All this means that you should use an accurate third-party level to check things. I use a Starrett machinists level. On my alt-az, I place the OTA horizontal, check it with the level, and then rotate the OTA in azimuth, checking the level around the 360 degrees of azimuth.
I don't use go-to, but I have been playing recently with encoders and push-to aiming on a Astro-Tech Voyager. I'll fly in the face of "conventional" wisdom and say that the accuracy of your push-tos (and by implication, go-tos) are critically dependent on the level of your rig during and subsequent to alignment. Get it right, and my targets are always withing 0.25 degrees of expected. Get it wrong, and I could be over a degree out over the course of an evening's viewing.
Some people may be OK with that.
#16 rmollise
Posted 01 July 2013 - 09:14 AM
Nope. Polar alignment is not affected at all by level. Think about the geometry of the situation and the surface of the Earth.
Nor is go-to affected. Polar alignment can affect go-to accuracy on some mounts, but not level.
Some mounts need a fairly good polar alignment for accurate go-to, but some like the Celestrons do not. How do I know? One night one of my fellow club members, a novice, accidentally polar aligned on Kochab instead of Polaris. His tracking sucked, but his go-to was fine.
#17 andysea
andysea
  • Loc: Seattle, WA
Posted 01 July 2013 - 11:58 AM
Perfect! thanks Dan....I definitely need to brush up my trigonometry from college:)
Andy
#18 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 01 July 2013 - 01:03 PM
Takahashi does. Their EQ mount manuals (the question that started this thread refers to an EQ mount) clearly state that the mount does not need to be level. Their tracking performance is legendary so they clearly care about performance.
Regarding alt/az setting circles: most are primarily dependent on orthogonality - the axes must be square to each other. Most alt/az mounts equipped with setting circles have no provision for leveling their bases (think dobs) and work quite well off level.
#19 andysea
andysea
  • Loc: Seattle, WA
Posted 01 July 2013 - 03:56 PM
John is right
Even tho I now use an AP mount with the RAPAS, I also have an NJP and I think that the TAK polarscope is still the golden standard. It has a built in bubble level that is aligned with the reticle inside the scope. All you need to do is make sure that the bubble is level and then align the reticle with polaris. Whether the mount is level or not is completely irrelevant thanks to this clever design.
