CGE-Pro question
4 replies to this topic
#1 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 09 July 2013 - 01:09 PM
Is there a way to adjust for the play in the RA axis on this mount. It seems no matter how I balance the axis or how loose or tight I turn the clutch knobs there is play on that axis. I can touch the eyepiece and the object swings back and forth. It's bad enough that when my neighbor's air conditioner goes on 60 feet away the vibration shows up. It's especially tough when I'm trying to image. The mount has a C14 on it.
Thanks for any feedback.
Paul
#2 Starblazer999
Starblazer999
  • Loc: Australia
Posted 09 July 2013 - 05:53 PM
The reason the slop is their it’s set like that at assembly of the mount they claim it tightens up in cold conditions, can have slop at room temp and can even bind up at sub 0 temp the way to get rid of it is to set the anti-backlash on the hand control and have the balance slightly of set. But it is adjustable the spring loaded worm gear has a Phillips head screw below the spring tensioner ante clockwise will allow the worm gear to close in on the main ring gear but adjustments are very fine and you may get binding that you can hear or even micro binding witch will show up with PE and you will void your warranty if found out if that has been adjusted.
#3 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 10 July 2013 - 09:39 AM
Thanks. If so, I guess that would explain why it's so evident while I was trying to image when it was 105F outside...
#4 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 10 July 2013 - 09:51 AM
The slop (which is backlash between the worm and wheel) can be adjusted in one of two ways depending on what mount you have (older or newer). To make the adjustment on the older mounts you have to remove the worm/motor housing. Beneath the motor are 3 allen head bolts and 4 allen head set screws. The bolts pull the worm and wheel together while the set screws push them apart. In addition, the arrangement of the set screws also effects the tilt of the worm assembly.
On newer mounts where the RA worm assembly is spring mounted, some adjustment may be made without removing the housing by simply turning the large brass adjustment screw on the housing. However, there are a couple of other screws that limit the inward and outward movement of the worm assembly that may also need adjustment. These, particularly the bottom one require removal of the housing.
Adjustments should be made with the axis slewing so that you can hear the meshing of the worm and wheel. They are done easiest with the clutches released on the RA. The adjustments on either system can be confusing and difficult until you get a sense of what they do. You can easily make things worse so plan to spend a little time on this.
#5 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 10 July 2013 - 10:45 AM
Hmmm...wondering how hard it would be to talk a knowledgeable person into coming to my house to take me through it... :grin:
Paul
