SpaceX is amazing!
208 replies to this topic
#1 Footbag
Footbag
  • Loc: Scranton, PA
Posted 10 July 2013 - 04:20 PM
Has anyone seen this video yet? I'm amazed.
https://www.youtube....player_embedded
#2 Qwickdraw
Qwickdraw
  • Loc: Ann Arbor, MI
Posted 10 July 2013 - 04:54 PM
Yes, I watched it. I was wondering if heat dissipation is going to be a problem for them in longer tests. I am not a rocket scientist but I know we have some here. It would seem heat is easier to dissipate when traveling away from the source at thousands of miles an hour but when you are actually moving into the engine thrust for long durations I would suspect that could be difficult.
#3 shawnhar
shawnhar
  • Loc: Knoxville, TN
Posted 10 July 2013 - 05:41 PM
So smooth it looks like CG!
#4 Ravenous
Ravenous
  • Loc: UK
Posted 11 July 2013 - 03:14 AM
I think heat in the engines is usually dispersed by using the fuel/oxidiser itself (which is cool of course) - some of it is pumped where it's needed for cooling before combustion. Though my knowledge of rocket science (or engineering, more precisely!) only comes from looking at the simplified diagrams in books.
If you think about it, the cooling effect of air is pretty useless. Not enough heat capacity or enough heat transfer.
#5 Qwickdraw
Qwickdraw
Posted 13 July 2013 - 07:37 AM
Its not the cooling effect of air but rather the engine itself normally speeding away at thousands of miles an hour and leaving the heat behind also. Under this method of basically hoovering, I would still believe heat would be a huge problem over time but as they say, I am not a rocket scientist.
#6 llanitedave
llanitedave
    Humble Megalomaniac
  • Loc: Amargosa Valley, NV, USA
Posted 13 July 2013 - 06:28 PM
Fortunately, the actual reusable Falcon will not spend these extended periods of time in hover. It will come in fast, basically free-fall plus atmospheric drag, and fire its engines just long enough to touch down softly. The stage will be almost empty and light, so it should be relatively quick to de-accelerate.
I can't imagine such a white-knuckle landing ever seeming routine to someone like me.
#7 deSitter
deSitter
    Still in Old School
Posted 15 July 2013 - 07:10 AM
I cannot see how this is going to work (slowing down). Please explain.
-drl
#8 llanitedave
llanitedave
    Humble Megalomaniac
Posted 15 July 2013 - 11:44 AM
As I understand it, the first stage separation will take place with a small amount of propellant remaining in the tanks. The Merlin 1-D engines are designed to support multiple restarts, and the first restart will reverse the downrange direction to send the stage back towards the pad. Remember, at this time it is nearly out of the atmosphere, and still coasting upwards.
After the first restart, the stage enters a ballistic trajectory back into the atmosphere towards the launch (or nearby landing) pad. Thursters re-orient the stage so that it points downward for the atmospheric reentry. Increasing air resistance slows it down to a terminal velocity of maybe some 150 m/sec or less.
At the right distance above the pad, the center engine will fire long enough to cancel out that 150 m/sec, and set it down to a gentle landing.
I think I've read that this reusability scheme will cut their payload capacity by some 30-40%, but they think the savings will be worth it.
The second stage is going to be a lot tougher to recover.
#9 FirstSight
FirstSight
    Duke of Deneb
  • Loc: Raleigh, NC
Posted 14 December 2013 - 01:24 PM
This thread is back open for posting, obviously with a HUGE number of posts excised, including a great many constructive posts by members bearing little or no fault for the reasons such large-scale intervention was required. I apologize to everyone whose constructive contributions to this thread were snipped, but unfortunately the thread tools available to moderators don't always efficiently facilitate precise surgery, that and we don't have infinite time to devote to it either.
Speaking of easier vs harder, it would have been an easier decision to simply lock the thread away permanently. But instead, let's give this thread a fresh re-start, and see if everyone can keep the debate CONSTRUCTIVE AND CIVIL this time (I say "everyone", because the first place to start toward that is to not point fingers at anyone).
Let the discussion begin.
#10 llanitedave
llanitedave
    Humble Megalomaniac
Posted 14 December 2013 - 04:06 PM
Wow, that takes us back to July!
SpaceX has done some more things since then. It's gotten its Falcon9 v.1.1 launch vehicle operational, with an enhanced payload capacity and two launches under its belt so far. It's been able to restart its first stage engines multiple times to allow a survivable return through the atmosphere, and came very close to a soft landing on its first attempt. They've already reduced the price of putting a satellite in orbit significantly.
They're still learning, and they still have some glitches (and they had a scary explosion at their test facility in Texas a couple of weeks ago), so they're still not out of the woods yet. But they've come a long way.
The real test of their success will be a year from now, when we can read about another monthly launch and shrug with a "ho hum".
#11 DarkSkys
DarkSkys
  • Loc: In the dark desert of Eastern WA.
Posted 14 December 2013 - 06:12 PM
This is Old school sci-fi type stuff.
Very neat.
#12 David Knisely
David Knisely
  • Loc: southeastern Nebraska
Posted 15 December 2013 - 02:01 AM
I guess that "explosion" was just two tanks of Nitrogen that ruptured rather than something involving combustion or the rocket itself. However, it looks like SpaceX is going to get its wish, as it is now in talks about the formal lease of Pad 39A at KSC:
http://www.spaceflig...a/#.Uq1Q9CeaZMg
Now, with Orbital Sciences and Virgin Galactic ramping-up launch preparations, the spaceflight scene is getting nicely busy. I had hoped that Blue Origin would have gotten something flying by now, but about the only things that seems to have gone on lately with them are a test of the capsule's launch escape system and a test firing of their BE-3 engine. Still, it is still early in the game for commercial spaceflight, so much may yet happen. Clear skies to you.
#13 David Knisely
David Knisely
Posted 17 December 2013 - 03:25 PM
SpaceX has released a couple of long-range images of the in-flight restarts of the first stage of the Falcon 9 vs. 1.1's first test flight as the stage descended:
http://www.spacex.co...ission-overview
You have to scroll down a ways to see them, but they do show the restarts (even though, as mentioned in the article, the 2nd one was aborted due to excessive roll and the first stage hit the water "relatively hard" as SpaceX put it). It will be interesting to see them try this again early next year. Clear skies to you.
#14 PeterR280
PeterR280
Posted 17 December 2013 - 04:46 PM
Looks scary. Would you sit on top of that thing if that was the landing mode?
#15 David Knisely
David Knisely
Posted 17 December 2013 - 11:37 PM
Well, you wouldn't be able to "sit" in the booster's stages (although they did put a 6-foot mannequin in the landing leg section of the Grasshopper test vehicle several times). I think that I would be fairly confident if flying in the current Dragon spacecraft if it had an environmental control system (i.e. breathable air and temperature control). It would be about like any of the previous capsule-based reentry and landing systems, with a lot more redundancy than some of the early ones. As for the reusable systems, once they establish some sort of track record in terms of reliability, I would probably be willing to fly in the "Dragonrider" version that descends and lands on the Draco thrusters. Clear skies to you.
#16 Starlon
Starlon
  • Loc: desert, USA
Posted 19 December 2013 - 01:11 AM
Yes, I've watched it a few times. It is basically a take-off on NASA's DC-XA, aka: 'Delta Clipper' Experimental, Advanced edition. See flight: http://www.youtube.c...h?v=JzXcTFfV3Ls
SpaceX arrived upon the scene after our nation's, NASA's, years of blood, sweat and tears blazing the trail and engineering the spacecraft. We built the infrastructure too.
It seems important to understand how Mr Musk arrived at the position he is today. He hired Lobbyists. See: http://sunlightfound...ally-and-pol...
Excerpted from link:
Since its inception in 2002, SpaceX was fuelled by a decade-long, multi-million-dollar political effort to pry funding from a sometimes skeptical Congress. SpaceX has spent more than $4 million lobbying Congress and given more than $800,000 in political contributions, according to data compiled from Sunlight's Influence Explorer. Many of the company's campaign donations went to key members of Congress in charge of the budget for NASA, which has mothballed the space shuttle in favor of commercial rockets for carrying payloads to the space station.
SpaceX's campaign to win political support has been systematic and sophisticated. Elon Musk, a founder of the wildly successful PayPal, does not surface as a political contributor in Influence Explorer records until 2002, the year he founded his commercial rocket company. Since then, he has donated nearly $725,000 to a politically disparate group of politicians. Last year, Musk gave the maximum legally allowed -- $35,800 -- to President Obama's reelection committee. But he also gave $15,000 to the National Republican Congressional Campaign Committee and $5,000 to Sen. Marco Rubio, R-Fla., a tea party hero who is much mentioned as a potential vice presidential nominee on the GOP ticket opposing Obama this year. In 2010, Musk gave identical amounts -- $25,900 -- to California Gov. Jerry Brown, a Democrat, and his unsuccessful Republican opponent, Meg Whitman.
There is more at the link, quite interesting.
But wait, this just from last Friday:
"SpaceX Launches Second Lobbying Team"
See: http://blogs.rollcal...-lobbying-team/
Excerpt:
"After 12 launches, and 50 on its manifest, the world’s fastest growing launch services provider has launched a second team of lobbyists to orbit Congress and the federal government.
SpaceX, a private space transport company that manufacturers and launches advanced rockets and spacecraft, has hired the Nickles Group LLC to lobby on general issues related to aerospace, budget, intellectual property, defense, labor, science/technology and tax. The Nickles lobbyists include Cynthia Merifield Tripodi, and Hazen Marshall, former staff director of the Senate Budget Committee, and former deputy chief of staff to then Assistant Majority Leader Don Nickles, R-Okla."
SpaceX already uses Patton Boggs LLP for lobbying the federal government. They reported paying Patton Boggs $90,000 in the third quarter of 2013. View multi-year lobbying profile. Patton Boggs lobbies on FY 2014 Commerce-Justice-Science Appropriations; NASA re-authorization; NASA COTS and commercial crew programs; FAA indemnification; and space launch regulatory issues. Patton Boggs lobbyists include former Senators John Breaux, D-La., and former Senate Majority Leader Trent Lott, R-Miss. Also lobbying are Bret Boyles, Norma Krayem, John Flynn, Matthew Cutts, and Alexis Early.
I guess he's played his ace in the hole card. This since he just aced out his competition for the launch pad 39A.
Also, here: http://www.spacenews...ly-resigns-p... ..you can read where Musk gets his expertise, even though some have since walked out on SpaceX.
So - in the end.. I am not amazed at all. It all looks like a big business operation. Elon Musk's rocket shop.
You can see his fees here: http://www.spacex.com/about Look under 'capabilities and services'
But wait! There's more: http://shop.spacex.com/ You can buy a SpaceX coffee mug or a cap.. or T-shirts & more..
#17 David Knisely
David Knisely
Posted 19 December 2013 - 03:25 AM
Starlon posted:
Not really. The Delta Clipper was designed from the outset to be an attempt at a single-stage to orbit vehicle with no prior attempts at spaceflight in a completely new design. Single stage to orbit was proving a little too difficult at that time to achieve, and it showed with the problems encountered by both the DC-X and the X33. It is sad that it was kind of relegated to the backwoods in terms of funding, so it wasn't given quite the chance to succeed as it should have had.
The Grasshopper was a modification of the first stage of the already-flying two-stage Falcon 9 launch vehicle to determine methods of controlling that stage during approach and vertical landing tests prior to attempts at landing a fully-reusable first stage. The next version of the Grasshopper appears to be a test vehicle for much higher altitudes and velocities than the first one, although it looks like on the next Dragon flight, they are going to attempt either a water landing or a return to near the launch site of the first stage. If they get enough information from those over-water tests, they might not need to do much with the 2nd version of Grasshopper.
No, NASA had nothing to do with the work of designing and engineering either the Falcon rockets or the Dragon Spacecraft. As for "infrastructure", some of that was existing, but SpaceX had to do a lot to make that structure operational again. Indeed, Launch Complex 40 hadn't been used since 2005 and had most of its major structures demolished by the government before SpaceX got access to it to create their own launch facility. Similarly, SpaceX had to basically design and build most of the Falcon 9 launch tower structure and facilities at the SLC-4E pad at Vandenberg AFB. SpaceX also built their own rocket test stands and facilities in rural Texas, so NASA had nothing to do with that either.
#18 llanitedave
llanitedave
    Humble Megalomaniac
Posted 19 December 2013 - 11:30 AM
They've also started buying land and getting permits for another launch site for the Falcon Heavy on Boca Chica beach near Brownsville, Texas. There's a good chance that Brownsville will also become the assembly point for their next generation rockets, which will be too large to truck out of California.
Somehow, I can't see it as too troubling when you're accused of standing on the shoulders of giants. That's the way progress is supposed to happen.
Musk has acknowledged the trailblazing work of the DC-X and their intellectual debt to it, as well as the work done by NASA over the years. They are doing exactly what NASA had hoped someone would do.
#19 seryddwr
seryddwr
    Innocent Bystander
  • Loc: La-la land.
Posted 19 December 2013 - 12:15 PM
Also, considering the state of funding for NASA: If SpaceX doesn't do it, who will?
#20 groz
groz
  • Loc: Campbell River, BC
Posted 19 December 2013 - 12:50 PM
And correctly so. The mandate of NASA is to develop new technology, to the point it can be commercialized, then allow industry to proceed from there.
If SpaceX is picking up on that mandate, it's a sign that they system is 'working as intended', and not something to get all upset about.
The real problem came about in the late 70's and early 80's with the shuttle program. There were plenty of entrepeneur type looking at the launch business in that timeframe, then nasa announced commercial launch services via the shuttle, for dollar values FAR below the actual cost, and essentially scared everybody away from that area. The only customer that was going to pay full jag pricing for shuttle launch space, was the military, and they quietly went elsewhere. It really amounted to heavily subsidized launch capacity for industry. Then Challenger happened, and they pulled the rug out from under commercial deliveries to orbit, essentially leaving a huge void.
What is happening today, is what would have happened 30 years ago, had Nasa stayed in the R&D role of it's mandate, and not branched off into trying to become a commercial launch vendor.
What I do find a bit interesting in hindsight. Politics of the shuttle program killed any potential for a startup in the field of space launches, and, as soon as the shuttle was finally killed, we see multiple startups in that field. There is a very clear cause / effect relationship there.
#21 herrointment
herrointment
  • Loc: North of 64
Posted 19 December 2013 - 04:12 PM
Lobbyists are the portal to power. No scandal there.
#22 rockethead26
rockethead26
  • Loc: Arizona, USA
Posted 19 December 2013 - 05:23 PM
Excerpt:
Sorry you have such a sour taste in your mouth for all of the private space business going on, but I suggest that you get used to it. It IS the future of space travel, as it should be.
#23 Jay_Bird
Jay_Bird
  • Loc: USA
Posted 19 December 2013 - 07:34 PM
Gee I'm ticked off about how this rocketry is all derivative from Goddard who was funded by Guggenheim and encouraged by Lindbergh. No, wait, it's all derivative from Congreve who helped with 'and the rockets red glare' lyrics. No, wait, from some ingenious Chinese paper-glue-sticks-gunpowder experimenter lost to history. No, no, wait, from the ape in "2001".
I'm also shocked - shocked! - that *private* launch companies like Space-X, Pegasus, Orbital Science, Sea-Launch, Ariannespace, etc., are actually in business to make a profit. Just like the private companies in the NASA golden-age Mercury-Gemini-Apollo-STS supply chain.
Space-X hired some lobbysists to help if get off the ground - literally - and not become a Tucker Motors of space tying to compete with entrenched firms. Those lobbying dollars are peanuts to establisment business as usual: Want to rue lobbying? A news story just ran about pork-barrel politics and lobbying leading to an act by Congress to build 3 more Global Hawk drones at >$200 Million each, after the Air Force grounded about 15 of its Global Hawk fleet because the USAF says that the U-2s that are still flying are much more effective. Protecting constituent jobs won out over actual military needs for the better part of a Billion dollars (many times the Space-X annual budget I'm sure), in this one small example.
#24 choran
choran
Posted 19 December 2013 - 10:28 PM
If the goal is to curb lobbying, the only way to do that is to curtail the power of the federal government to pick winners and losers. That, IMHO, is the real problem.
#25 Starlon
Starlon
  • Loc: desert, USA
Posted 20 December 2013 - 12:49 AM
Hey - don't be sorry for me. Those articles aren't by me, I'm just the messenger. I think the private space industry has been around for awhile before Musk. The commsat's and others. But I also think everyone should know how Musk uses lobbyists to twist our governments arm to get his way. I can't say much good about lobbyists - most of which are lawyers.
Someday a company will offer flights to an orbital hotel. Good! And maybe to the Moon. Good again.
