Volcano on the Moon?
9 replies to this topic
#1 smitty0
smitty0
Posted 19 July 2013 - 04:52 PM
It could be a active volcano on the Moon? I think is dome 'Herodotus 1'
Longitude: 50 ° 56 ' West
Latitude: 25 ° 28 ' North
Quadrant: North - West
Area: Aristarchus crater region
Video:
http://www.youtube.c...eature=youtu.be
2013-07-20 00:04
Celestron C9.25 [235/f25], camera QHY5L-IIm, IRpass filter 720nm.
#2 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 19 July 2013 - 05:25 PM
I believe that's the tip of Mons Herodotus catching the first rays of the morning sun.
#3 rmollise
Posted 19 July 2013 - 05:37 PM
Yep.
#4 smitty0
smitty0
Posted 19 July 2013 - 05:45 PM
But it so bright... Ok, tomorrow will try to make more pictures of this location.
#5 azure1961p
azure1961p
  • Loc: Triton
Posted 20 July 2013 - 02:47 AM
I'd be highly inclined to believe its not an active volcano.
Pete
#6 Mert
Mert
  • Loc: Spain, Pamplona
Posted 20 July 2013 - 03:29 AM
IMHO looks like a mountain top still in the dark side
already hit by sunlight.
#7 smitty0
smitty0
Posted 20 July 2013 - 04:43 AM
Understood - i think is peak of Mons Herodotus. His albedo is very high. Snow cap :)
#8 Mirzam
Mirzam
  • Loc: Lovettsville, VA
Posted 20 July 2013 - 08:46 AM
If you wanted to analyze the possibility that this was a hot source (i.e. active volcano) you could make measurements at multiple wavelengths, including IR, and compare the shape of the pseudo-radiance curve with the shapes from other illuminated areas of the Moon. (Pseudo-radiance because you have not corrected for the filter transmission). If the "volcano" has a stronger red-IR response versus other areas it may be due to a higher surface temperature. The other possible cause would be a difference in rock composition, but this is likely to be relatively subtle in a radiance measurement.
I don't think it is a volcano, but just wanted to point out that amateurs could easily collect data to characterize these sorts of features if so inclined.
JimC
#9 AlanL
AlanL
  • Loc: Kansas, USA
Posted 20 July 2013 - 01:01 PM
JimC - I like your thinking!
Conventional wisdom is the moon is geologically inactive. If this is an active volcano, it would be the first we have seen!
#10 Mirzam
Mirzam
Posted 20 July 2013 - 01:48 PM
Actually, an even simpler way to monitor the Moon for hotspots would be to create ratio images, for example, IR/G. There would be variations across the lunar surface, and no doubt noisy data within shadows (easily masked out), but extremely high values that appear localized to a small area would be interesting to examine more closely.
Of course you might have to persist for a long time to discover anything (Hundreds, thousands, millions of years?)
JimC
