Lunt 100/Solarmax90?
3 replies to this topic
#1 bill1234
bill1234
  • Loc: NJ, USA
Posted 27 July 2013 - 06:33 PM
Do you know the weight of the "front mounted" Lunt 100 and the Coronado SolarMax II 90mm?I am thinking of purchasing one of these, but am concerned about balance. :question:
Bill
#2 frolinmod
frolinmod
Posted 27 July 2013 - 07:06 PM
Lunt's website says the LS100FHa is 8lbs. I'm not at all sure how accurate that is.
#3 Tom and Beth
Tom and Beth
  • Loc: Tucson, AZ
Posted 27 July 2013 - 11:59 PM
I'm coming up with a bit over 7 pounds for the 90MM Etalon and tuner.
#4 brianb11213
brianb11213
  • Loc: 55.215N 6.554W
Posted 28 July 2013 - 04:21 AM
I've no direct experience of the Lunt front mounted 100mm etalons but my Solarscope SF-100 is heavy enough (around 5 lbs for a single stack unit) to have a significant effect on the tube balance, though easily countered by sliding the tube to a different position on the dovetail & moving the counterweight a bit further down the Dec shaft. The weight distribution also makes the mount's job much harder, damping time for vibrations can be increased unless the mount is specified for a much heavier load than that actually used.
It's certainly something to take into consideration.
