Locked up Asus Aspire One 722
11 replies to this topic
#1 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 29 July 2013 - 09:45 AM
Beginning last evening, when I would start up the 722, it would start downloading updates. This resulted in freezing everything. I cannot shut it off, no keys work; and the updates are stuck.
How can I shut it down?
#2 Cliff Hipsher
Cliff Hipsher
  • Loc: North Chesterfield, VA
Posted 29 July 2013 - 10:18 AM
Disconnect the AC to DC adapter and then remove the battery. Out go the lights.
Let it sit for a few minutes, and then put the battery back in.
Power up and then do what ever you need to do to get to the BIOS Setup (Typically you press the F2 function key while the Boot Logo is displayed...)
Check your BIOS settings to make sure that nothing got trashed. Change as appropriate.
Plug in the AC adapter in and reboot...
#3 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 29 July 2013 - 10:29 AM
Thanks Cliff; I'll give that a try.
#4 richard7
richard7
    Not Quite
  • Loc: Sacramento
Posted 30 July 2013 - 06:40 PM
Did it work Carol?
#5 StarWars
StarWars
    Mr. Postmaster Man
  • Loc: At the Gym >Spudtastic<
Posted 01 August 2013 - 10:45 PM
Carol,
Your Netbook book is a Acer not ASUS ... :o
#6 StarWars
StarWars
    Mr. Postmaster Man
Posted 03 August 2013 - 06:22 PM
Carol,
You most likely have some malware on your Acer... :mad:
1) Disconnect from the Internet. (shut off DSL modem)
2) start up Acer
3) Run Malware scanner
http://www.filehippo...perantispyware/
4) Download Smarty Uninstaller and install on Acer. You can use SU to remove malware programs with the Force Uninstall option. Connect to Internet and allow SU to collect data on the update problem. (give it 30 minutes)
http://www.smartuninstall.com/
5) Disconnect from the Internet and run Smarty Uninstaller, SU will show you which downloads will be the most current on your computer.
6) SU should of given you enough information to remove the problem updates/malware.
#7 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 15 August 2013 - 11:17 AM
Sorry so late in replying. I did not have any Malware, as I do run a check frequently with my own Malware program.
It appears it was just a fluke with the auto downloads of MS updates. Now that I'm updating manually; no problems.
#8 CarolG
CarolG
  • Loc: Oklahoma
Posted 17 August 2013 - 07:59 AM
Hi, Carol. After your first post, I started up my Acer Aspire after the latest auto MS downloads. To my horror, most of my programs were gone and my screen settings were replaced by a MS logo. I found no malware, but couldn't recover my lost programs and settings. Fortunately, I had a backup, so I had to do a system recovery. What I had not done on the netbook that I had done on my other computers was set the updates to "manual". No more "automatic' updates for me either! Glad you got your problem resolved!!
#9 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 17 August 2013 - 09:59 AM
Carol, thanks for posting your experience with the "auto" updates as well! There obviously is a problem using the "auto"; as since I'm using manual updates, netbook is running smoothly!
BTW, that's how I finally got mine up & running again, is to do a system recovery. For sure won't ever use the "auto" update on the netbook ever again!
#10 StarWars
StarWars
    Mr. Postmaster Man
Posted 22 August 2013 - 12:54 AM
Do you have Windows 7 Starter or Home Premium... :question:
#11 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 22 August 2013 - 11:24 AM
I don't know about Carol G.; however I'm using 7 Home Premium.
#12 CarolG
CarolG
  • Loc: Oklahoma
Posted 26 August 2013 - 10:24 PM
I'm using Windows 7 Pro.
