Convertible pier top
5 replies to this topic
#1 Laz
Laz
Posted 30 July 2013 - 02:27 AM
I built a small split-roof obs several years ago on a concrete slab in the back yard.I was mostly observing plus some video imaging at times with my Nexstar 8i . The scope was mounted on top of a wheeled cart containing the moniter and recorder. However since the obs was only 7X8' it left no room for setting up my Super polaris mount. My solution was a steel pier with a ply top which accepts the Nexstar 8...the N8 can be lifted off and a self leveling cage attached which contains the SP base attached with 3/8" bolts thru blind nuts on the main base. The pics should make the construction easier to understand. the pier was filled with 50 lbs of sand and is rock steady.
#2 Laz
Laz
Posted 30 July 2013 - 02:29 AM
another pic
#3 Laz
Laz
Posted 30 July 2013 - 02:30 AM
more pics
#4 Laz
Laz
Posted 30 July 2013 - 02:32 AM
last pic
#5 Goodchild
Goodchild
Posted 30 July 2013 - 03:47 PM
Laz,
Clever idea. I like it. What scope do you use to mount on the SP?
#6 Laz
Laz
Posted 30 July 2013 - 05:18 PM
homemade 5" F5 with a Jaegers lens aka 1976 or demounted from fork N8i
