question to those who does concrete work
13 replies to this topic
#1 donnie3
donnie3
  • Loc: bartlesville oklahoma
Posted 02 August 2013 - 12:48 AM
I would like to have a concrete slab put in to replace a patio with red 16x16 inch blocks that I installed and did not do a very good job of it. I had a free estimate done and the person doing it gave me a price for taking up all the blocks, building the forms and poring the concrete ( 260 sq ft) for $1750, does this sound reasonable or too high. I don't know much about this type of work. the slab is for rolling my scope out on, the blocks are too uneven and unlevel for pleasant viewing. thanks. donnie
#2 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 02 August 2013 - 06:27 AM
Sounds reasonable to me.
I had a 12' x 27' slab poured a year ago and it cost me about $3500. This was a floating slab for a small outbuilding so it was 4-6" thick except at the edges where it was 18" thick. The cost included taking off the top soil, digging out the 18" edge trenches, putting in a layer of gravel, building the forms, installing the rebar, pouring the concrete, removing the forms, and a little grading around it when done.
-Dan
#3 Al8236
Al8236
  • Loc: 48.9173N 122.1390W
Posted 02 August 2013 - 09:02 AM
Well it doesn't sound reasonable, Not knowing your labor rates and material costs in your area makes it hard to give you a firm guess but 3yd. concreet @ $60 = $180, apx. 10hr. labor @ $80 = $800 for a crew gives you a total of $980.
Plus any permits and local taxes it might not be totaly out of line but I cant say for sure!
#4 CharlesW
CharlesW
  • Loc: Chula Vista & Indio, CA
Posted 02 August 2013 - 09:33 AM
Can't give an opinion on the cost but you have an opportunity here. If you always put your scope in the same spot you could dig down about 3' in that spot and pour in a cubic yard under the scope. Just keep that seperate a little from the main slab and you are set for a future pier and AP.
#5 tadpoletoo
tadpoletoo
  • Loc: NW Michigan
Posted 02 August 2013 - 10:23 AM
donnie3, Wait a minute...... I smell a new observatory in your future!
#6 donnie3
donnie3
Posted 02 August 2013 - 11:12 AM
tadpoletoo your right that's an option but for now all I wont is a smooth slab so I can set on my roll around chair with out hitting the cracks in the block type patio ( a smooth roll) I guess each state have different prices. I could get a handy man to do it at a much lower price put if he gets hurt or messes up the job with out being bonded or insured im out a lot more then the price of the slap. thanks, donnie
#7 HunterofPhotons
HunterofPhotons
  • Loc: Rhode Island, USA
Posted 02 August 2013 - 01:17 PM
Hi Donnie,
It's impossible to give an intelligent answer to your question.
You haven't told us any pertinent information. How thick is the slab? Will there be rebar or 6 x 6 inserted? I'm assuming this will be a floating slab. Will there be a bed below the slab of sand or crushed stone? How deep? Will it be compacted?
I could go on, but you get the idea.
dan k.
#8 Midnight Dan
Midnight Dan
Posted 02 August 2013 - 01:37 PM
Wow! Good deal in your area. Here, the concrete costs are almost double that, delivered, with a 2 yard minimum.
Plus there can be a lot of additional costs such as the cost for form materials, any gravel or sand required for a base, excavating costs if the current spot is not deep enough, delivery cost for equipment such as a Bobcat if needed, material removal and disposal, etc.
-Dan
#9 donnie3
donnie3
Posted 02 August 2013 - 04:06 PM
this is what was on the estimate: install patio-11'x18'with ramp 6'6"x8' and sidewalk 4'6"x32" total 260 sq ft. install min, 4"ot 3500 psi concrete w/wire mash control joints as needed. take up all patio blocks and debris and haul them off. $1750
#10 mikey cee
mikey cee
  • Loc: bellevue ne.
Posted 02 August 2013 - 09:00 PM
That price doesn't sound out of line at all. There seems to be an underlying sentiment that blue collar workers like this gouge people. I've done alot of this type of work over the years. Those that think this too high why not have your over priced lawyers try their hand at it. There's more to it than meets the eye. Not like playing with mud pies. :smirk: Mike
#11 donnie3
donnie3
Posted 02 August 2013 - 11:12 PM
thanks mikey cee for the comment. ive tried my hand at working with concrete and believe me there is a skill to it! my concrete job didn't turn out to well. best left to the pros.
#12 Midnight Dan
Midnight Dan
Posted 03 August 2013 - 08:48 AM
Still seems about in the right ballpark to me.
-Dan
#13 Al8236
Al8236
Posted 03 August 2013 - 09:45 AM
Oops!!! I just noticed that I need to read what I post better! I meant to say "doesn't sound UNREASONABLE"
Sorry about that!
#14 1965healy
1965healy
    The Snarkster
  • Loc: San Antonio, TX
Posted 03 August 2013 - 10:36 PM
Donnie, the price is very reasonable. You're getting a lot of bang for your buck. He has to remove and haul off your pavers. He'll keep them and use them for some other job so he's actually saving money later. Sounds like he may have passed that savings on to you a little bit. He needs to grade the area, pitch the slab, ramp and walkway correctly for drainage, steel, forms, expansion joints etc. Concrete work is prep intensive and a bad slab will haunt both of you for a long time. If there is any future plan for an observatory on the slab site it now so that that area is level and the rest of the slab pitches down and out from there. Again if there is any plan for an observatory in the future think about it now. This is the time to bury a couple PVC pipes for future wiring, one for data, one for power. Where would the pier be? The capped end of the PVC pipes need to terminate there. Trying to hydrodrill under a finished slab in a straight line without undermining the slab is a pain, saw cutting is messy and expensive. This is the time to plan for the future while things are easy and much less expensive. Even if you don't do an observatory you, or the next owner can use those lines for a really nice patio set up.
