Whole Disc Image 8-18-13 - Skyris 674M
20 replies to this topic
#1 PatHolland
PatHolland
  • Loc: Clever, Missouri
Posted 18 August 2013 - 12:53 PM
Here's an whole disc (single frame) taken with the Celestron Skyris 674M camera. Used the Lunt LS60T double stacked, Celestron CGEM Mount. Best 240 frames, processed in Registax and Photoshop CS3. Inverted to best show the flares...
#2 PatHolland
PatHolland
Posted 18 August 2013 - 12:57 PM
And in a somewhat more conventional processing style...Seems to me the northern magnetic belt is weakening?
#3 Aquarist
Aquarist
  • Loc: Illinois
Posted 18 August 2013 - 02:08 PM
I like both images. The first one is really cool!
#4 Andy Devey
Andy Devey
Posted 18 August 2013 - 03:07 PM
Stunning images
Andy
#5 sullij1
sullij1
Posted 18 August 2013 - 03:25 PM
Great work Pat. I agree in the northern hemisphere. I hope that once the end of the polar flip is over sombody puts together a full disk animation over the 2 - 4 month period. Gotta have somthing to do with the weakning.
#6 Aboy
Aboy
  • Loc: Thousand Oaks, CA
Posted 18 August 2013 - 04:02 PM
I like it. :jump: I like the inverter one... You can see the more details :grin:
#7 PatHolland
PatHolland
Posted 18 August 2013 - 04:47 PM
Thanks guys! Interesting to see the northern belt begin to weaken for the pole shift. I was not into solar astronomy 11 years ago, this is my first time seeing it.
#8 AstroPaolo
AstroPaolo
Posted 18 August 2013 - 04:55 PM
i like them, how is working the camera?
i'm interested :)
#9 PatHolland
PatHolland
Posted 18 August 2013 - 04:58 PM
Thanks for asking :), I'll be back tonight and will give the first light assessment.
#10 LarryAlvarez
LarryAlvarez
  • Loc: Texas
Posted 19 August 2013 - 04:14 AM
Looks like a really cool camera setup. Definitely good for Solar. :)
#11 Matt Wastell
Matt Wastell
  • Loc: Paddington, Brisbane, Australia
Posted 19 August 2013 - 05:00 AM
Hi Pat
That is a great image - I love one frame disc snaps - the Skyris looks like a great imager for your setup!
#12 sullij1
sullij1
Posted 19 August 2013 - 10:17 AM
Right there with you. Fascinating stuff.
#13 DavidM
DavidM
  • Loc: Perth, Australia
Posted 19 August 2013 - 05:53 PM
Excellent images Pat. Keep them coming.
#14 PatHolland
PatHolland
Posted 19 August 2013 - 09:16 PM
Thanks all. I thought I would jot a few lines down about my experience with the Celestron Skyris 674M. The camera has a more solid and therefore slightly heavier body than other cameras in it's class. Since the camera is not actively cooled, I figured it is more along the lines of a "heat sink" aluminum body. It's not "heavy", just heavier than my grasshopper or chameleon cameras.
The camera itself works well, it's a Sony Super HAD ICX274 Monochrome chip, which is a safe bet for solar imaging. No newt rings to report (but I did not use it with a barlow either). The image is noise free and no bad, hot or white pixels to report on the camera.
As with most cameras, the real reporting is with the software. I am familiar with ICAP with the NexImage 5 camera, so there were no surprises there. The ICAP software has all settings on automatic when freshly installed on a PC, so the exposure and gain setting had to be set to manual to use the camera without over-exposing the sun.
Registax readily handles the .AVI videos and processes them nicely.
The camera chip size is 8.50mm x 6.80mm (roughly 11mm diagonal) so can easily work with B1200 without severe light drop-off on the sun. The resolution is 1600X1200 pixels (2 Megapixels) so you can make larger prints with your solar system images. The pixel size is 4.40 microns, so even at 12 bit A/D Conversion, you still have sensitivity for solar surface details and flares.
The chip size allows for full frame images of the sun in the Lunt 60mm and I suspect 80mm scopes. I don't like putting together mosaics, so a full frame image of the sun is just the ticket for me. I've ordered a Lunt 80mm APO scope for larger full frame images with WL, Cak and moon shots.
Only had 1 day with the camera so far, so I will report more later.
#15 rigel123
rigel123
  • Loc: SW Ohio
Posted 19 August 2013 - 09:37 PM
Great report Pat and beautiful images, the contrast is great in both of them!
#16 Durval Menezes
Durval Menezes
  • Loc: Rio de Janeiro, Brazil.
Posted 08 September 2013 - 09:48 AM
Hi Pat,
Amazing pictures! Thanks for posting them, and for the report.
Just looked for it over at Celestron's web site, but they don't list a Skyris 674M; there's a camera there with exactly the same specs (specially the resolution, which seems to be the difference between models), but they are calling it a 274C, not a 674C. Could it be that Celestron changed the model number?
#17 PatHolland
PatHolland
Posted 13 September 2013 - 11:06 AM
I have no idea Durval, I will have to look into that. 274 would make more sense for a model number...it's a 2 megapixel camera.
*edit* wonder if that makes the 674 a "limited issue" collector's item? :)
#18 wes
wes
  • Loc: Oklahoma
Posted 14 September 2013 - 07:43 PM
Excellent images Pat I have some images using the Skyris 274 they are good cameras.
Wes Higgins
#19 Andrev
Posted 14 September 2013 - 08:08 PM
Really beautiful image Pat.
Andre
#20 BYoesle
BYoesle
  • Loc: Goldendale, Washington USA
Posted 14 September 2013 - 09:58 PM
Very nicely done Pat! :waytogo:
#21 PatHolland
PatHolland
Posted 15 September 2013 - 01:34 PM
Thank you guys. I was able to get out a few nights ago and image the moon with the Skyris as well. I know this is not the proper forum but here is the image...Shot with the Skyris 274M, Lunt 80mm ED and Orion Sirius mount.
