Processing video from ASI120MC
5 replies to this topic
#1 tstephens3956
tstephens3956
Posted 18 August 2013 - 02:35 PM
I took three videos of Saturn last night about 2000 frames each. I cannot open these with Registax or Castrator. This maybe due to their size, 7 Gb each. Any ideas on how to work with files of this size?
#2 Klausthaler
Klausthaler
  • Loc: Augsburg, Germany
Posted 18 August 2013 - 04:16 PM
You might try to convert each video into a series of images. (Avidemux 2.5.1, ffmpeg ...) Avidemux saves a .jpg, hence ffmpeg might be the better option.
Example:
ffmpeg -i "myvideo.avi" -an -f image2 "output_%05d.png"
Best regards,
Klaus
#3 rolo
rolo
  • Loc: GA, USA
Posted 18 August 2013 - 06:22 PM
Try using AutoStakkert!2
#4 tstephens3956
tstephens3956
Posted 18 August 2013 - 06:25 PM
Thanks, I will look into that. Going to take a few more photos tonight limiting file size.
#5 Kokatha man
Kokatha man
Posted 18 August 2013 - 07:34 PM
Sorry, just saw this...use VirtualDub "File > Open Video File" then check to make sure "Video > Direct stream copy" is bulletted and then "File > Save as AVI" making sure you add "copy" or somesuch to the name you give it and noting where you file it! :)
Likely as not when you open the large video in Vdub a window will appear telling you the missing file index is being reconstructed and when it finishes doing said you click "OK" and proceed with the task as above...
Usually this scenario is required for files above about 4Gb.....if you achieved 7Gb files with only 2000 frames I presume they were taken at a very large (widefield) scale/resolution..? :question: :)
#6 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 19 August 2013 - 11:29 AM
These PITA compatibility issues are the very reason I have my capture settings in FireCapture set to limit to 4GB. Fortunately, with Winjupos, that doesn't present any issue other than additional processing time.
==Grant
