LXD750/650 controller
12 replies to this topic
#1 CharlieB
CharlieB
  • Loc: Southern NH
Posted 19 August 2013 - 03:17 PM
I know the Meade LXD 750 & 650 must have, at some time, been available without the 1697 Computer Drive System as the instructions for installing the system are in the original user's guide. I was wondering if anyone knows what kind of control system was available before the 1697? And if so, was it used in other Meade mounts? I ask because I blew C2 in the power control board and was using the mount manually until I received a package of 35v 6.8 mf tantalums to replace it and other well-know culprits. It would have been nice to have some drive mechanism, even if it was not-goto.
#2 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 19 August 2013 - 05:43 PM
Those mounts were offered in three versions, though by far the most common included the #1697 goto system. Another option was tracking-only. It used the same motors but a simplified internal controller and a simple handbox. I've only ever seen one of those. It was also offered (at least on paper; never saw one) as a manual-only mount with no drives. That version actually had the motors inside but not connected to anything.
#3 CharlieB
CharlieB
  • Loc: Southern NH
Posted 19 August 2013 - 06:51 PM
Thanks for the great information. When (if) the mount every really dies, I'll take the knobs off and grind a flat spot on them for flex cables. It worked quite well manually and takes a load rather well. When I had the mount apart, I was pleased to see well-designed and well-made boards - quality you don't see very often any more. Sure wish they'd used higher voltage caps, though. Man, was there ever a lot of smoke from that little capacitor! Fortunately, that was all that went. It happened when I connected the 12-18v adapter (without checking the output voltage first). My error and I got very lucky.
#4 southmike
southmike
  • Loc: Fayetteville, NC
Posted 19 August 2013 - 11:44 PM
Open your controller and wrap a piece of duct tape around the ribbon.. At way if it blows it won't blast a hole through the ribbon..
#5 southmike
southmike
Posted 19 August 2013 - 11:48 PM
Which leads me to another question if you blew the power control board..even the dummy non goto version would probably not function....
Would not be as hard to rig up a fix.but just saying.
#6 jrcrilly
jrcrilly
  • Loc: NE Ohio
Posted 20 August 2013 - 01:01 AM
There's no separate, independent power control board. Each controller incorporates its own. If he replaced the #1697 with the tracking-only controller the only parts that would remain in place are the motors and encoder boards.
#7 CharlieB
CharlieB
  • Loc: Southern NH
Posted 20 August 2013 - 10:44 AM
I didn't make it very clear that the board I was referring to is the first of the two that are sandwiched together inside the mount - the one with the voltage regulator. I had already replaced the tantalums in both of my handboxes. I also had shielded the ribbon cables, although I do have one of the replacement cables Ron Sampson made a few years back - just as extra insurance.
#8 Skywatchr
Skywatchr
  • Loc: North-Central Pa.
Posted 22 August 2013 - 05:16 PM
Hi Charlie, I converted my LXD650 to use Autostar (and Audiostar) so you do have options just in case. :grin:
#9 CharlieB
CharlieB
  • Loc: Southern NH
Posted 22 August 2013 - 10:25 PM
I've only read about that conversion kit. Is it still available?
#10 Skywatchr
Skywatchr
Posted 24 August 2013 - 05:42 PM
Yes it is still available. Go to the website http://tech.groups.y.../LX200Autostar/ and send George a message.
#11 CharlieB
CharlieB
  • Loc: Southern NH
Posted 25 August 2013 - 08:15 PM
Thanks! Will do.
#12 JAT Observatory
JAT Observatory
    NOT a Wimp
  • Loc: In the Primordial Soup
Posted 05 September 2013 - 09:04 AM
I have a LXD650 and I can't decide if I should just replace the caps or go with the AutoStar upgrade.
#13 CharlieB
CharlieB
  • Loc: Southern NH
Posted 07 September 2013 - 08:58 AM
If you need a few 35v tantalums, let me know. I have a few left over.
