Vixen GP-DX which controller/motor?
12 replies to this topic
#1 yashi
yashi
Posted 23 August 2013 - 09:31 AM
Ive got a Vixen GPDX without motors/controller. What im looking for is a solid solution that offers autoguiding/ goto/ pc interface
It seems like that its possible to adapt the Synscan systems. But ive read a lot of bad stuff about them. The second solution seems to be the Vixen Starbook S. But that one is pretty expensive and i don really need the display.
The little foot system seems to be ok, but ive no idea where its possible to buy it.
#2 cherokawa
cherokawa
  • Loc: Torrance, CA
Posted 23 August 2013 - 10:39 AM
One option that comes to mind is the iOptron GotoNova kit. More details here.
Good luck. :)
#3 fetoma
fetoma
  • Loc: Southern NJ
Posted 23 August 2013 - 11:24 AM
You can put a Meade Autostar on it. Bolts right on with the exception of shortening one motor mount bolt.
#4 orlyandico
orlyandico
  • Loc: Singapore
Posted 23 August 2013 - 12:28 PM
I did a Meade Autostar conversion on a GP.
The problem is unless you get the LXD55 or 75 motors, there's some fabrication required (and it ends up unreliable).
And the LXD55/75 motors are pretty hard to get hold of. Not to mention the 55 motors have that infamous encoder disk that bends and screws up the GoTo pointing.
An overkill approach would be a Losmandy Gemini kit.. although I think the least cost conversion has to be the Synscan GoTo conversion kit for the EQ5. I believe it's $400 from some Canadian dealers.. (if still available)
#5 Christopher Erickson
  • Loc: Waikoloa Village, Hawaii
Posted 23 August 2013 - 01:41 PM
A person can still get a set of LXD-55/75 motors by calling Meade Customer Support with a credit card handy. Meade is used to people calling in and telling them that they "smoked their motors" by plugging the wrong cables into the wrong ports.
I have two GP-DX and one GP mount that have been retrofitted with Meade LXD-55/75 motors and I believe it is an awesome combination. Very powerful/versatile and user friendly.
And this is coming from a guy who's current main mount is an Astro-Physics 900GTO.
  • skycamper likes this
#6 orlyandico
orlyandico
  • Loc: Singapore
Posted 23 August 2013 - 10:40 PM
Chris, I didn't know you could still get 55/75 motors.
I did call Meade some years ago about this, and they wanted $180 each for the motors. So $360 for both.. hardly cost-effective.
#7 Christopher Erickson
Posted 23 August 2013 - 11:09 PM
Compare that to the turnkey GOTO solutions from other sources and it becomes a steal-deal.
#8 orlyandico
orlyandico
  • Loc: Singapore
Posted 23 August 2013 - 11:28 PM
Like I mentioned above, the EQ5 Synscan kit used to be $400 from some Canadian dealers. With the 55/75 motors you'd still need a handset ($80) and the panel box, and some fabrication.
Can't find the Canadian dealer, but FLO in the UK sells this for $467:
http://www.firstligh...o-version-3-...
I suspect you could take 19% off if shipping outside the EU zone.
#9 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 23 August 2013 - 11:42 PM
The interface panel is in the RA motor housing, so that's handled. I don't believe there's any fabrication involved. If I ever run out of SS2K controllers I'll switch over the Meade stuff for my Vixen mounts.
#10 Christopher Erickson
The Meade Autostar 497/Audiostar offers so much more.
* 12,000+ object database.
* Comet and asteroid databases with full orbital element data entry.
* Defacto universal serial command protocol support.
* Massive third party hardware and software support.
* Massive user community.
* PEC.
* Satellite tracking.
* Spiral search.
* Direct RA/DEC coordinate entry for GOTO's.
* Optional GPS units.
* Optional ST-4 autoguider accessories.
* Hacked firmware images from multiple sources that add a whole multitude of features and functions.
* Custom tracking and guiding rates.
* User-programmable axis ratios.
#11 Christopher Erickson
Posted 23 August 2013 - 11:45 PM
The only fabrication required is shortening the RA motor mounting bolt by 1/4".
The interface panel is integral to the RA motor housing.
#12 orlyandico
orlyandico
  • Loc: Singapore
Posted 23 August 2013 - 11:49 PM
One other option is to buy a used LXD75 - there is one on the classifieds for $390.
Strip off the parts, sell the motor-less LXD75 for a hundred bucks. Ends up cheaper..
#13 yashi
yashi
Posted 25 August 2013 - 12:53 PM
i found a used eq5 Synscan. I hope it performs well enough :/
