LXD55 metal axis locks - clutch question
4 replies to this topic
#1 m1618
m1618
  • Loc: Orange County - CA
Posted 31 August 2013 - 07:36 PM
Perhaps I should have posted this under ATM/DIY. I found a perfect replacement for those plastic tabs aka axis locks on the LXD55/75 mounts. It's actually a universal shower lever (hot and cold) and as long as you don't mind the little "H" and "C" on them, they're quite durable! :grin:
Question: is there an extra bushing of sorts in the RA (where the knob screws in)? I must have dropped a piece in the dark because now the lock doesn't seem to reach the core to tighten. What would I need?
#2 fetoma
fetoma
  • Loc: Southern NJ
Posted 31 August 2013 - 09:31 PM
You lost one of the clutch pads that fit between the worm and the clutch knob screw face. It's a cylindrical piece that won't mar the worm when the clutch knob is tightened.
#3 m1618
m1618
Posted 31 August 2013 - 09:58 PM
Aha! Friction brake pad of some sort huh? Any idea what that material may be? I suppose I can try a wooden dowel unless there's a better choice... please advise.
#4 orlyandico
orlyandico
  • Loc: Singapore
Posted 01 September 2013 - 01:49 AM
It's some kind of hard plastic. Don't use the clutch without it, you'll score the ring gear. Maybe a cutout from a milk jug will do.. I would avoid wood. It might splinter and then the bits will scatter around the ring gear and get stuck in the grease.
#5 obin robinson
obin robinson
  • Loc: Jacksonville, FL
Posted 01 September 2013 - 06:22 AM
Go to the store and get a nylon screw which is about the same diameter. Trim it until it fits in the clutch friction pad area. It may take several attempts but it will work.
obin ;)
