My Design of a Ultra Heavy Duty Wedge/Nexstar 1100
5 replies to this topic
#1 InTheDark
InTheDark
Posted 03 September 2013 - 01:32 PM
I've been wanting to get a better mount for my Nexstar 1100. I had a previous mount built with 3/4" plywood initially designed for my C8 Computerized (worked great for the C8), wobbly as **** on the 11".
Many of the mounts available through Celestron and other more custom mounts ran anywhere from $450 - 1200 including shipping.
After a while, i just thought I'd be better off purchasing $300-400 worth of good metal tools and build it myself. I spent a good deal of time using Sketch-up to build a base design - used many examples of previous designs I'd seen on the net.
Over the last 3 weeks I purchased a Hor/Ver Metal Band Saw, 10" Disk Sander, Small Grinder, and a Bench Press, various clamps bits, taps/die set, transfer punch, etc- I now have a basic home metal shop for about the price of a low-end wedge!
I got about 70lbs of misc Aluminum bar and plate at Aaron Scrap metals in Hayward for about $1/lb. the result is great - haven't been able to test completely (it was cloudy last night), but its solid on a 12" cement pier. Virtually no detectable movement unless I slam into the pier. If anyone wants copies of the plans I'll post on sugarsync later today/tomorrow (let me know) - you can download sketch-up for free (don't need to purchase pro version). Enjoy...
#2 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 03 September 2013 - 01:50 PM
Wow! congrats and welcome to CN. Looks very nice! Maybe you could go into business making these! Very nice observatory also.
Al
#3 opticsguy
opticsguy
  • Loc: Washington State
Posted 05 September 2013 - 07:08 AM
Excellent choices!!! Excellent work and craftsmanship.
#4 CharlesW
CharlesW
  • Loc: Chula Vista & Indio, CA
Posted 05 September 2013 - 09:44 AM
Very nicely done. The only thing I can comment on is that you have a very small bearing surface with those washers under the socket head screws for your angle adjuster. Considering how much weight you are supporting, I'd go for a bolt with a larger head.
#5 rmollise
Posted 05 September 2013 - 09:55 AM
VERY nice!
#6 InTheDark
InTheDark
Posted 27 September 2013 - 09:15 PM
Good points, I've already made some adjustments including changing the angle plate to give it more range, I have larger washers - I went with 8mm hex to allow me to use a hex tool, there weren't any larger headed screws. I do have access to some larger washers with 8mm openings that could also work. Because I have the angle adjustment rod on the back I haven't noticed any slip or movement. Seems rock solid!
