Obs Alert: Jupiter with 3 shadow transits 10/12/13
19 replies to this topic
#1 ericj
ericj
Posted 05 September 2013 - 09:26 AM
On October 12th, 2013 at 4:32 UT there will be a rare triple shadow event across Jupiter lasting 65 minutes. As shown below in the SkyMap Pro map the moons casting the shadows on Jupiter are Io, Europa, and Callisto. Callisto will be casting its shadow on the South Polar Region of Jupiter.
Also below is a sketch made by George Phillips Bond of a three shadow transits on Jupiter on on January 28th, 1848 using the 15" Great Refractor. Using SkyMap Pro I was able to determine that the shadow transits that night were from Io, Europa, and Ganymede.
http://ejamison.net/...nt_obs11.html#2
Clear Skies,
Eric Jamison
#2 Tonk
Tonk
  • Loc: Leeds, UK, 54N
Posted 05 September 2013 - 12:46 PM
10/12/13 - for non-Americans this is 12/10/13 ;)
#3 azure1961p
azure1961p
  • Loc: Triton
Posted 05 September 2013 - 10:17 PM
Thanks Eric. My Sky Safari shows it well. Trouble is its so low in the east. The seeing would ruin it so Im passing on this one but thanks for the heads up.
Pete
#4 Cotts
Cotts
    Just Wondering
  • Loc: Toronto, Ontario
Posted 06 September 2013 - 01:53 PM
Ok, I will take the final step down the road of pedantry. The correct scientific method of writing dates and times is:
year, month, day, hour, minute, second. Always the largest time division first.
So, Oct. 12, 2013 would be most correctly written as 2013/10/12.
This has nothing to do with one's country or continent.
Let the games begin!!!!
Dave
#5 Cotts
Cotts
    Just Wondering
Posted 06 September 2013 - 02:04 PM
And, while I'm here, the correct pronunciation of "kilometre" is kill' - oh - mee - - ter. Not kill - ah' - mit - ter.
All metric unit prefixes, from kilo, to mega to pico to centi and all the others are pronounced with the accent on the first syllable of the prefix, never the second syllable. Funny thing is, everyone does this correctly for every commonly used metric measurement except the kilometre. Why is that, anyway?
Fun test: try pronouncing, out loud, the following metric terms, first with the accent in its correct place, on the first syllable, and then with the accent as misused in 'kilometre', with the accent on the second syllable. You will soon see how wrong the killAHMetre people are...
kilopascals
megabyte
picofarad,
milliwatt
centimetre
gigawatt.
Rant over. Thanks for listening.
Dave
#6 brianb11213
brianb11213
  • Loc: 55.215N 6.554W
Posted 06 September 2013 - 03:02 PM
Not in the USA ... try 0.621375 miles instead. :smirk:
They even have the wrong size gallons - smaller than proper ones - and then wonder why they get poor mpg from their "automobiles". :tonofbricks:
#7 Special Ed
Special Ed
Posted 07 September 2013 - 12:06 AM
Eric,
Thanks for the post and the historical sketch by George Bond--pretty cool. Too bad that Jupiter will only be 4° above the horizon here in the eastern US but hopefully our friends who live all those thousands of units of measurement east of here will get to see it. ;)
Cotts, thanks for the pronunciation lesson--I've always wondered about that. I thought they were called "clicks".
BTW, it's spelled "ter", not "tre". :grin:
#8 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 07 September 2013 - 06:39 AM
Okay, I'll bite...technically it's referred to as a "Klick" as in "4.5 klicks to target"! :p
How low will Jove be from the east coast for this BTW?
#9 Tom and Beth
Tom and Beth
  • Loc: Tucson, AZ
Posted 07 September 2013 - 02:51 PM
My Plantarium shows Jove rises at 11:20 local time, so you're probably out of luck unless you like looking just above the Horizon.
Darn... :tonofbricks:
#10 Rick Woods
Rick Woods
  • Loc: Inner Solar System
Posted 07 September 2013 - 08:24 PM
Dave
...And that's "correct" because it sorts properly that way.
#11 Robert Cook
Robert Cook
  • Loc: San Diego County, California
Posted 07 September 2013 - 08:55 PM
Well, here in America :usa::salute: my calcumalator says that a kee-LAH-meter is closer to 0.621371 miles. I guess arithmetic works differently here, too. So where is it more accurate? :thinking: Yeah, that's what I thought. :coolnod: ;)
#12 Jarad
Jarad
  • Loc: Atlanta, GA
Posted 09 September 2013 - 01:24 PM
Our rule to avoid any possible ambiguity is to record dates as: DD-MON-YYYY
So October 12, 2013 is written as 12-Oct-2013.
Last year I had to do a data cleaning on medical data recorded by a mix of U.S. and U.K. nurses. It took weeks - I never realized how many different units there are, and how many ways to write them down. One patient had 2 nurses taking shifts, one recorded his temps in Celsius, the other in Fahrenheit. It took me while to figure out what unit they used for his blood pH - turned out to be nanomoles of hydrogen ions per liter. And nobody ever bothers to write down which units they used, just the number...
The worst was trying to match up the hospital data with the lab data. The lab data comes with a specimen ID, not the patient name. In the spot for specimen on the hospital record, instead of putting the ID#, they just put "Yes"...
:tonofbricks:
Jarad
#13 Tyranthrax
Tyranthrax
  • Loc: Tampa, FL
Posted 12 September 2013 - 01:21 PM
You could use julian dates.. . .I'm in a desert so math and time don't function properly here.
#14 ericj
ericj
Posted 15 September 2013 - 03:53 PM
Hi Pete and Michael,
While Jupiter will be low in the sky for observers in the Eastern United States it may still be worth while to observe it. This is because sometimes the seeing conditions can be better than expected. There have been times I have set up my telescope to observe a celestial event and the seeing did not seem like it would be very good. Still I ended up seeing some detail that I would not have otherwise seen if I did not set up the telescope.
For example during the Venus transit across the Sun on June 8th, 2004, Venus and the Sun were only around ten degrees in elevation when I began obsering them. Still, I saw far more detail than I expected:
http://ejamison.net/recent_obs.html#6
Best,
Eric
#15 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 16 September 2013 - 10:30 PM
Jarad, thanks for the hilarious and sad anecdote about labeling data. I'm stealing this word-for-word as an example for my science students.
#16 aa6ww
aa6ww
  • Loc: Sacramento, Calif.
Posted 23 September 2013 - 02:50 PM
Can someone translate this into my time here in California?, this is too much for me to decipher.
..Thanks.
Ralph
#17 Edward E
Edward E
  • Loc: Tucson, Arizona
Posted 23 September 2013 - 05:49 PM
For us here on the west side of the USA it translate as "Out of Luck" or below the horizon. :bawling:
#18 Mark Harry
Mark Harry
  • Loc: Northeast USA
Posted 01 October 2013 - 04:40 AM
+ 1 for jarad and Tonk!
M.
#19 David Gray
David Gray
  • Loc: Ower Yonder, 01.5ºW. 55ºN.
Posted 12 October 2013 - 01:30 AM
No luck here: typical UK skies - consoled myself watching a real-time animation on WinJupos.
No doubt many images will appear from the more fortunate I might just avoid them.........:whistle:
David.
#20 azskies
azskies
  • Loc: Prescott, AZ
Posted 12 October 2013 - 10:27 AM
Yeah, with us being in the 21st century you think there would have been a time table for when and where it won't be seen....just like eclipses!
Jeff
