Tips for cleaning & lubrication of ES Twilight II
4 replies to this topic
#1 Jan Owen
Jan Owen
  • Loc: Sun City West, Arizona
Posted 11 September 2013 - 10:41 AM
Question for owners of the Explore Scientific Twilight II altazimuth mount; in lieu of factory instructions, what do you recommend for disassembly, cleaning, and lubrication of the bearings/bushings in both axes of this mount???
#2 obin robinson
obin robinson
  • Loc: Jacksonville, FL
Posted 11 September 2013 - 05:41 PM
I cant help you with the disassembly but i can say you should use Militec-1 grease when you reassemble. It is by far the best grease i have used on precision gear.
http://www.militec-1.com/
obin :cool:
#3 Whichwayisnorth
Whichwayisnorth
  • Loc: Southern California
Posted 11 September 2013 - 08:07 PM
obin :cool:
Can you tell us why you like that grease so much? I've never heard of it until now. Most of the time I hear people swear by Superlube Synthetic.
#4 obin robinson
obin robinson
Posted 11 September 2013 - 09:49 PM
obin :cool:
I am an aircraft mechanic and i have worked with many expensive synthetic lubricants. The Militec-1 grease works much better and lasts longer than others we have exposed to various torture tests. If you follow the instructions for Militec-1 you are supposed to heat it up and let the metal absorb it. Once it is treated the grease lasts for a very long time under extreme usage. Though we do not use it on the aircraft we used it with weapons instead of using TW25. I have used it to lubricate weapons which will stay in storage for a long time. It simply works and works well even in sandy, dirty, and dusty environments. In clean environments it simply excels. For telescopes i would not use anything else.
obin :grin:
#5 MrJones
MrJones
  • Loc: Indiana
Posted 12 September 2013 - 08:59 AM
I use Mobil 1 synthetic grease, the pink stuff, for all kinds of stuff including my mounts. It's beaten or compared well with all the others in all the tests I've seen. I would think all 3 of these Superlube, Militec-1 and Mobil 1 are fine for mounts.
