Anybody imaging with the Celestron HD Pro Wedge?
2 replies to this topic
#1 astrovienna
astrovienna
  • Loc: The NoVa White Zone
Posted 12 September 2013 - 01:15 PM
I used it in the field for the first time this weekend. It blew around terribly in even the slightest of breezes, sending the guide star off by +/-5 arcsecs or more, and ruining about half of my 2 minute subs. This was a CPC1100 imaging at 1700mm, using the CPC tripod. When there was no wind, guiding was excellent. My observatory setup is a Milburn wedge on a (very short) pier, and I've imaged in similar conditions without much trouble.
It's possible that I didn't have all the bolts cranked down tight enough. The Celestron wedge adjusts in azimuth using two plates - one fixed to the tripod and one above that fixed to the lower one with three bolts with slotted holes, so that it can be rotated a bit in azimuth. The top plate "floats" on three semicircular plastic pads between the two plates, and when your alignment is set you tighten down the bolts. After inspecting the wedge I did tighten everything, sometimes as much as a quarter turn, but of course then it was cloudy, so I didn't get a chance to test this out.
Is anyone else using this setup for long FL imaging?
Kevin
#2 Footbag
Footbag
  • Loc: Scranton, PA
Posted 12 September 2013 - 02:00 PM
I used the HD Pro wedge for a while with my CPC-800. I found it to be quite stable, even in moderate wind,(up to 10mph). I would expect it to handle a CPC-1100, but I also know the original wedge wasn't quite rigid enough for the 1100.
My inclination would be to suggest tightening everything down and trying again. If there is a loose bolt, maybe everything is rocking on that. You should also make sure the bolts on the bottom of the CPC are properly seated. I seem to remember some oddly fitting washers that were required for attaching the CPC to the wedge.
#3 astrovienna
astrovienna
Posted 13 September 2013 - 10:46 AM
Thanks Adam. I'll give it a shot. I'm surprised that tightening so much is necessary, but maybe so.
Kevin
