scope question
5 replies to this topic
#1 donnie3
donnie3
  • Loc: bartlesville oklahoma
Posted 26 September 2013 - 11:05 PM
what telescope design is best for video astronomy. thanks, donnie
#2 Dragon Man
Dragon Man
  • Loc: Snake Valley, Australia
Posted 26 September 2013 - 11:48 PM
Hi Donnie,
There is no 'best' design for AstroVideo.
What is important is 'Fast'. f5, f4, f2 etc.
The faster a focal ratio the better, but some people get good results with 'slow' scopes (f8, f10 etc).
For Video, people use Refractors, Reflectors, SCT's, Camera Lenses, Security camera lenses, Finderscopes, etc.
Focal reduction is recommended but not essential. I've seen some great results with scopes at f10.
But the faster you go the wider the Field of View and the brighter the objects appear, and also shorten the integration times needed.
Have a look through the Video Gallery in here and many photos name the scope that was used. Some also say all the filters, Focal Reducers etc used.
That way you can see which scopes can do what and with which camera.
Also depends if your main interest is Deep Space Objects or Planets and Moon.
Different scopes do different jobs, and different Focal Reducers give different results.
I could hightly recommend an ED80 as a fantastic scope, but if you suffer bad light pollution it may not be good in your area.
Some could also recommend an SCT with Hyperstar but they are very expensive.
It's a tough question to answer without knowing your preferred targets, sky conditions, or Budget.
#3 donnie3
donnie3
Posted 27 September 2013 - 10:47 AM
thanks dragon man, ive had real good results with orions 80mm short tube refractor. I am mainly interested in dso. ive been thinking about purchasing orions astrophotography 114mm reflector or a 6" from opt. the 6" is better built but the 114 is more portable and will fit on my se mount, if I buy the 6" I would have to use it on my cg5 goto. not sure what to purchase. donnie
#4 Hemmi
Hemmi
  • Loc: Raleigh, NC
Posted 30 September 2013 - 07:48 PM
I used to use a Orion 114mm on a se mount. My avatar is a shot with that scope using the sdc-435 cam.
#5 maroubra_boy
maroubra_boy
    Vendor - Gondwana Telescopes
  • Loc: Sydney, Australia
Posted 30 September 2013 - 08:06 PM
I use a 114 f/4.4 scope that I've coupled to an old Meade set of forks of an 8" SCT. Made the wedge myself. I never have a problem of with the focuser being in an awkward position as it always above the pivot of the Dec axis, :) There was nothing wrong with the mount other than it wasn't being used and was about to be trashed. Managed to rescue it and give it a new lease on life.
Only change I've made to my set up from when I took this picture was to replace the red dot finder for a 50mm right angle correct image finder.
#6 Stew57
Stew57
  • Loc: Silsbee Texas
Posted 30 September 2013 - 08:23 PM
I just use an ETX80 set in polar mode with a laser finder. I used to use my C11 on a CGEM but some kids almost dumped it over once, so I am more cautious now.
