Gamma Cygni-Again
6 replies to this topic
#1 AstroMan0
AstroMan0
  • Loc: Dedham, Massachusetts
Posted 29 September 2013 - 07:44 PM
Okay, I finally got a photo of Gamma Cygni last night that I am not embarrassed by. If only the scan wasn't so noisy :smashpc:.
Exposure: 40min. at f/5.9
Film: Hypered Tech Pan (72 hrs)
Gamma Cygni Region
#2 Michal1
Michal1
  • Loc: Czech Republic, Central Europe
Posted 30 September 2013 - 10:45 AM
Noah, glad to see you have solved the problems with uneven fogging. Have you tried to scan the frame several times and stack the scans together to reduce the noise? Of course, using a better scanner or a digital camera would be better.
#3 AstroMan0
AstroMan0
Posted 30 September 2013 - 01:32 PM
I actually have two frames from Saturday night of this object, but when I tried to stack them in Registax they wouldn't align properly; I am probably doing something wrong. I've never thought about scanning the same frame multiple times; maybe I'll have to try that.
#4 AstroMan0
AstroMan0
Posted 02 October 2013 - 05:51 PM
I just realized that Registax is for planetary imaging, so I downloaded Deep Sky Stacker, and have no clue how to use it. Any suggestions?
#5 Michal1
Michal1
Posted 06 October 2013 - 05:47 PM
1. Open picture files
2. Check all
3. Register checked pictures - in the appeared dialog box uncheck "automatic detection of hot pixels" and tell the program to stack 100% of checked pictures.
4. Save picture to file.
If you encounter a problem, let me know.
#6 AstroMan0
AstroMan0
Posted 06 October 2013 - 07:23 PM
Hi Michal,
I just tried this, but DSS tells me that "The checked pictures are not compatibles (width, height, number of colors, number of channels, only one master dark, offset and flat)."
Thanks.
#7 Michal1
Michal1
Posted 07 October 2013 - 07:10 AM
That's easy - the frames probably don't have the same width and height. You have to crop them manually to the same dimensions in some photo editing software.
