ST-4 compatible?
2 replies to this topic
#1 Muledeer
Muledeer
Posted 01 October 2013 - 09:24 PM
I am trying to upgrade my auto guiding setup.
Current setup is a Pictor201XT output through RJ12 cable to a #520 Electronic Relay that outputs to the telescope hand controller. Meade techs hard wired the relay output cable to the hand controller.
The pinout from the Pictor is
1. +5v
2. Ground
3. Left
4 Up
5. Down
6. Right
What I would like to upgrade to is a modern auto guider, with a USB cable to laptop, having PHD app, and the RJ12 output from the auto guider camera plug into the 520 Relay box.
But all new guilders interesting me are ST-4 compatible with a pinout of
1. NC
2. Ground
3. Left
4. Up
5. Down
6. Right
Can I do the new configuration by simply switching the pin connection for 4 and 5 on the Rj12 cable?
Or is there more to it? Will the new camera output activate the hand controller?
I am not very knowledgeable of electronics and do not want to fry anything.
#2 zerro1
zerro1
  • Loc: Smokey Point , 48.12°N 122.25°W Elevation:512 ft
Posted 01 October 2013 - 10:07 PM
1. +5v
2. Ground
3. Left
4 Up
5. Down
6. Right
1. NC
2. Ground
3. Left
4. Up
5. Down
6. Right
Welcome to CN
What mount?
In your description, the only difference I see is # 1. (+5v & NC)
I thought the pictor was an ST4?
#3 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 01 October 2013 - 10:43 PM
ST-4 is the model number of a guide camera once produced by SBIG. The Pictor cameras are ST-4 compatible. No need to worry about reversing up/down or left/right; they are dependent of optical design and camera rotation anyway. The only issue will be the Meade relay box. That will require a power source. Most modern cameras aren't rigged to supply that.
