dobsonian mount for 300PDS ?
10 replies to this topic
#1 drago
drago
  • Loc: Latvia
Posted 09 October 2013 - 12:45 AM
Hello!
Maybe anyone has already done to building dobsonian mount for sky-watcher 300pds OTA (12") ?
thinking about buil;ding that dob for these OTA.
think, plywood is a good material for that, but maybe anyone can say, what thickness is optiimal? 18 - 21 mm ?
i be happy for any suggestions and advices.
thanks
#2 eyepiecedropper
eyepiecedropper
  • Loc: aschaffenburg, germany
Posted 09 October 2013 - 05:26 PM
Hi, I´ll post some pics tomorrow. But be warned, it´s rather crude. No fancy notches. 15mm plywood. But it works nicely without backlash and motions are smooth.The az bearing is a lazy susan turntable unit out of plastic with some inherent friction. No overshooting. The alt bearing has a diam. of 400mm with belt strap on Teflon. It works surprisingly good, but all in all i would´t use it as reference ;-)
Regards, Martin
#3 drago
drago
  • Loc: Latvia
Posted 10 October 2013 - 12:44 AM
ok, thanks, i be waiting.
looking also on some russian and english projects, and think as alt bearing try use a rollers wheels.
15 mm plywood not too thin \ flimsy?
i thinking about 18mm laminated from both sides. think a regulate alt friction like on a serial "skywatcher" dobs - via tighten construction and add friction via that...
sorry for my bad english...
#4 eyepiecedropper
eyepiecedropper
Posted 11 October 2013 - 10:20 AM
Hi, the dimensions:
alt bearing diam 360mm
groundboard 500x500mm
clearance between side parts: 400mm
thickness of plywood: 15mm (you can see that i stiffend the open end of the box with 20mm square pipe)
distance between ground board and center of alt bearing: 680mm, that gives you a clearance of 170mm between scope and ground board.
#5 eyepiecedropper
eyepiecedropper
Posted 11 October 2013 - 10:21 AM
next pic
#6 eyepiecedropper
eyepiecedropper
Posted 11 October 2013 - 10:22 AM
last one:
#7 Pinbout
Pinbout
  • Loc: uhmm...still in 2nd grade
Posted 11 October 2013 - 10:56 AM
love the astrogoods design concept with his clamshell rings.
#8 drago
drago
  • Loc: Latvia
Posted 11 October 2013 - 01:21 PM
eyepiecedropper:
Danke shon! :)
i see, you not using azimuth bearing at all? what observations can possible without az axis? :-O
and why groundboard is 50x50 cm, if clearance between walls is only 40 cm?
#9 eyepiecedropper
eyepiecedropper
Posted 12 October 2013 - 04:43 AM
hi, as i said: this thing works, nothing more. usually all of my scopes are eq-mounted.
the az-bearing is a turntable unit.
http://ecx.images-am...41djLlBOYhL.jpg
You want to build a nice looking one:
http://www.deepsky-b...ckerbox-GSO.htm
http://www.astrotref...TOPIC_ID=152694
http://www.astrotref...TOPIC_ID=106315
http://www.astrotref...unde-Teil1.aspx
http://dobstuff.com/...omrockerbox.htm
Regards, Martin
#10 eyepiecedropper
eyepiecedropper
Posted 12 October 2013 - 06:42 AM
some instructions:
http://stellafane.or.../rockerbox.html
http://www.instructa...scope/?ALLSTEPS
#11 drago
drago
  • Loc: Latvia
Posted 13 October 2013 - 05:16 AM
thank you!
