OAG with Slr
7 replies to this topic
#1 Mr Greybush
Mr Greybush
  • Loc: Virginia
Posted 10 October 2013 - 01:04 AM
Has anyone ever had success with an AOG using an SLR. I know I've read every article that has said no but does it really work. I'm curious and not to say I would spend any money on it but if you don't ask you don't know right
#2 guyroch
guyroch
    Vendor (BackyardEOS)
  • Loc: Under the clouds!
Posted 10 October 2013 - 07:25 AM
It works wonders, not sure what articles you read that said otherwise.
With a DSLR you need to make sure you maintain the right distance if you are also using a focal reducer and the added length of a OAG can mess up that distance in a hart beat.
The key is to get a thin OAG; there are a few available. The best thin and somewhat affordable OAG I have seen (and purchased) is the Lacerta OAG... but it's only available from Teleskop Services in Germany.
http://www.teleskop-...acerta-Off-A...
Hope this helps,
Guylain
#3 Footbag
Footbag
  • Loc: Scranton, PA
Posted 10 October 2013 - 08:16 AM
Not only does it work, but it works much better then a piggybacked guidescope. It gives tighter, rounder stars and flexure becomes a non-issue.
The key is to get a good OAG as Guylain suggested and also a very sensitive guide camera. The Lodestar is a good one.
A good OAG setup with the camera will be $700+. IF you skimp, you may have a useless piece of hardware. I think that is why a lot of people try and are disappointed with OAG's. I tried three before settling on the TS OAG9EOS.
#4 Mr Greybush
Mr Greybush
  • Loc: Virginia
Posted 10 October 2013 - 11:25 AM
The cameras I have are an ASI120 and a Meade dsi. I think the ASI will be sensitive enough? I can't afford a loadstar
#5 guyroch
guyroch
Posted 10 October 2013 - 12:06 PM
The ASI120 mono should be good enough... but as the SSAG it's a bit bulky and it may be difficult to use with a DSLR and OAG. The big body of a DSLR may obstruct the ideal position of the guide cam as needed. For this reason the Lodestar, ST-i, or QHY5L-II are better suited for OAG / DSLR combo.
Hope this helps,
Guylain
#6 Mr Greybush
Mr Greybush
  • Loc: Virginia
Posted 10 October 2013 - 12:10 PM
True looks like I'm up to saving some money. Thanks guys :)
#7 PeteM
PeteM
  • Loc: West Michigan
Posted 10 October 2013 - 01:53 PM
It sure does work. I just got the Orion thin OAG(TAOG) and a QHY5L-II. After getting the focus set, it guided great and my stars were pretty much round and consistent from frame to frame! Well worth the money(I spent around $470 for this combo) and learning curve.
#8 SuperBlueNova
SuperBlueNova
  • Loc: Madison, WI
Posted 10 October 2013 - 03:59 PM
Would the OAG interfere with a full frame sensor?
