New Lowrider Variant?
12 replies to this topic
#1 gatorengineer
gatorengineer
  • Loc: Hellertown, PA
Posted 10 October 2013 - 07:45 PM
http://www.cloudynig...SC_0040-larg...
I am confused when I look at this scope. The rule used to be 30 degrees for baffling on a lowrider. Any steeper angle and the baffle becomes way to large. What am I missing here. This is more like a 60 bend.... I have "toyed" witht the concept of a baffle in the light path halfway between the secondary and the ID of the cage, but I dont see that going on here....
#2 Mirzam
Mirzam
  • Loc: Lovettsville, VA
Posted 10 October 2013 - 08:56 PM
Looks to me like a very large secondary and designed with sufficient backfocus to permit the use of a 45 degree diagonal at the eyepiece. I'm not seeing any baffles other than what may be at the focuser itself. Neat scope!
JimC
#3 gatorengineer
gatorengineer
Posted 11 October 2013 - 12:41 PM
The only problem is optically it doesn't work. You would get crushed by all of the stray light coming in around the secondary.
#4 kfrederick
kfrederick
Posted 11 October 2013 - 02:01 PM
I like his ground board and side bearings setup :bow:
#5 Pinbout
Pinbout
  • Loc: uhmm...2nd grade
Posted 11 October 2013 - 06:11 PM
Did you ever consider a astatic support for your cell?
#6 gatorengineer
gatorengineer
Posted 11 October 2013 - 06:24 PM
no but I am ecstatic that I will get to work on the sling design you helped so much with this weekend.... LOL...
Danny your a solids wiz, can you see what the cone would look like from a 2" focuser on lets say a 50 degree lowrider 36 inch..... It would I think be easy in solids...... If I could baffle it in the light path, might be doable. Would be near impossible to do in 2 D...
#7 Pinbout
Pinbout
Posted 12 October 2013 - 01:05 PM
Need specs to do it. But I wouldnt have a problem with 2d...
#8 mark cowan
mark cowan
    Vendor (Veritas Optics)
  • Loc: salem, OR
Posted 12 October 2013 - 08:42 PM
An adjustable iris could baffle it properly just past the focuser. Hard to baffle it anywhere else with that kind of angle. I like the looks of the scope - nobody will be kicking sand in it's face. ;)
Best,
Mark
#9 Mirzam
Mirzam
Posted 13 October 2013 - 03:27 AM
I was not very clear in my earlier post, but the use of a 45 degree diagonal to straighten out the viewing angle would serve to some degree as a focuser baffle.
JimC
#10 gatorengineer
gatorengineer
Posted 13 October 2013 - 12:16 PM
challenge is at F3.6 you will be clipping with a typical focuser/diagonal combo a 3" focuser and you wont get baffling... for this scope you would want as wide as you can get so an Iris wouldnt work well with the large field stops...
#11 Pinbout
Pinbout
Posted 13 October 2013 - 12:54 PM
hows this for a start...don't know the field stop you'd use.
#12 gatorengineer
gatorengineer
Posted 13 October 2013 - 07:22 PM
many thanks Danny....let's say 4inches of 2 inch ID focuser tube... baffle gonna be huge.....
#13 Pinbout
Pinbout
Posted 13 October 2013 - 10:39 PM
hows a 66" height off the front surface? LOL
I think its a 1-1/2" scale on a c size sheet.
