Mark V or Binotron for 10" Dob - Planet/Lunar Only
50 replies to this topic
#26 beatlejuice
beatlejuice
  • Loc: Hamilton, ON,Canada
Posted 18 October 2013 - 11:59 AM
No, the lowest profile I can have is a 1.5" focuser tube. That's what I have now. If I went any longer I'd probably not be able to come to focus with the filter wheels in some of my eyepieces
But Mike, the length of the focuser tube doesn't effect the profile it just adds extra length for outfocus. Thats why I got the 2.37".
Eric
#27 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 18 October 2013 - 12:50 PM
Yes, this is true. Adding or removing spacers from the focuser itself will raise or lower the profile of the focuser. I misunderstood what Eddgie meant by "profile." IIRC my Moonlite has no spacers now.
In any case, when I ordered my Moonlite I wanted to avoid enchroachment of the drawtube into the light path and allow for use of my eyepieces with both my 1.25" and 2" filter wheels. I did not want the drawtube to dip far into the light path. This cannot be a good thing for contrast. Many observers make a big deal about the CO and spider vanes, but seem oblivious to possible degradation of the image from the drawtube.
If I need more out-focus for some eyepieces, I can always add an extension. In fact, I was doing that even before I upgraded to the Moonlite.
Possible future acquisition of a Binotron was not part of the selection process for my Moonlite. At this point I don't plan on returning my Moonlite to install a longer drawtube.
#28 Mirzam
Mirzam
  • Loc: Lovettsville, VA
Posted 19 October 2013 - 07:01 PM
I am using a Binotron with a 10" home-built f/6.5 newt. I asked Russ if a Paracorr would be useable and he said it was not needed--even at shorter f-ratios. I suspect that this may have to do with the OCS. However, the magnification effect of the OCS alone would not affect coma correction as coma scales linearly with magnification.
Other problems that had to be solved were these:
1. The OCS protrudes into the optical path a lot. I moved my mirror an inch forward and used a taller focuser--not a low profile focuser which will only exacerbate the problem.
2. The weight of the binotron requires a very robust focuser. I ended up with a large format Moonlite focuser and this works quite well.
3. The weight of the binotron (which reportedly is not particularly heavy as binoviewers go) nonetheless required a serious effort at counterbalancing. I made a custom 2.5 Lb counterweight opposite the focuser that is easily removed in case I want to use a mono-view eyepiece.
JimC
#29 beatlejuice
beatlejuice
Posted 20 October 2013 - 01:01 AM
I certainly agree with you Jim on 2 & 3. The regular moonlite focuser + the counterweights that I already had solved those issues.
As far as a taller focuser is concerned I am not so sure. Since the binotron reaches focus with the reducer arm in at a certain height above the tube it seems that the taller the focuser is the more you would have to extend the newtonian spacer to still achieve focus at low power thus marginally reducing the FOV the more it is extended.
I have found that the views have not been noticeabley effected by the protusion into the light path in low power and is a non-issue at mid and high power as the low profile focuser is racked out enough to clear the light path in these settings. This without unscrewing the newtonian spacer at all, giving a seemless transition between all 3 powers without any added procedures.
Eric
#30 Eddgie
Eddgie
Posted 20 October 2013 - 07:09 AM
I agree. Kind of.. I did not see the field reduced, but rather the off axis light rays were badly cut of. I would say that at f/4.9 in my scope, having to extend the OCS was causing about 50% light cutoff.
I believe that it is better to use the lowest profile focuser possible that will allow the OCS to be used at the shortest length (OCS screwed all the way in).
In low power mode, it is impossible to see the effects of the additional obstruction into the light path because if it extends into the light path by one inch, it still only take 3% of the light from a 12" scope, and at low power, you can't see the contast loss.
And yes, at medium and high power, when you need it to be out of the way, it is.
I recommend the lowest possible focuser height with a longer tube to allow the OCS to be screwed all the way in, even if it projects into the light path at low power. It simply does not do enough damage at low power to be seen.
#31 Sarkikos
Sarkikos
Posted 20 October 2013 - 08:42 AM
When monoviewed, won't short focal length eyepieces tend to require the drawtube to be racked farther in? In fact, the only times I've needed an extension on a drawtube is when I'm using a long focal length eyepiece. IIRC, in those cases the drawtube was racked all the way out from the telescope. (It must depend, though, on where the field stop is located in each eyepiece.) Why is the situation seemingly reversed in the Binotron with its Power Switch? Why all this talk about the drawtube intruding into the light path at low power but not at high power?
I don't intend to do all my viewing with a binoviewer, even if I upgrade to a Mark V or Binotron, so I need to live in both the monoview and binoview worlds.
#32 Sarkikos
Sarkikos
Posted 20 October 2013 - 09:02 AM
Russ did not answer your question of whether a Paracorr would be useable with the Binotron. I doubt very much if a Paracorr is useable with a Binotron. He said the Paracorr was not needed. Of course, it's not really needed - with your telescope. But that's because your Newt has an f/number of 6.5!
I don't see what the OCS has to do with reducing coma unless is a coma corrector. As you say, coma should not be affected by magnification. I do think, though, that if you magnify to the point where the entire DLF of the primary is contained within the AFOV of the eyepiece, that ought to reduce the perception of coma.
Of course, there would be a greater need for a Paracorr if the f/number is below 5. My 10" Dob is an f/4.8.
#33 Mirzam
Mirzam
Posted 20 October 2013 - 09:34 AM
Actually, I have used my binotron (sans Paracorr) with my 20" f/4 Starmaster and did not notice any coma. So something is going on. I'll test it out again because I really was not looking for coma. At f/4 it jumps right out under normal circumstances.
I also have the larger size OCS, which reduces any chance of vignetting.
JimC
#34 beatlejuice
beatlejuice
Posted 20 October 2013 - 11:38 AM
Mike, when using the binotron's in a newtonian there is a minimum of 4" between the shoulder of the focuser and the OCS. This consists of the regular 2" shaft + a 2" Newtonian spacer which can itself be unscrewed a further 1/2" to help reaching focus in low power if necessary. The newtonian spacer is removed for use in a refractor or SCT thus making the whole system compatible with any type of scope. In my scope (10" f/5) I rack out more than 1.25" for mid power and about 2" for high power.
I should have picked up on this when you talked about using the binoviewer with a filter wheel. Since you already are able to use the filter wheel in mono, when using the binotron you would have to modify the length of your focuser tube or use an extension tube or pull the whole thing out quite a bit when binoviewing with mid or high power. But using the binotron with the filter wheel is of course not possible.
BTW I still don't know how you are able to reach focus with the filter wheel's extra inch of height + the extra 3/8" in height for the 3 thumbscrew compression ring holder. The math just doesn't seem to compute for my eyepieces.
Eric
#35 REC
REC
  • Loc: NC
Posted 20 October 2013 - 12:36 PM
I have to screw out the OCS about 3/4 the way out for the low power arm in my 10" Dob. The normal and the barlow arm also will focus ok.
BTW...I had a beautiful view of the Double Star Cluster last week and was able to fit both clusters in the FOV....nice!
#36 Sarkikos
Sarkikos
Posted 20 October 2013 - 06:09 PM
Refocusing for the three levels of the Power Switch is not a big deal. In my setup, lower and mid power might not be a problem. But it sounds like I may have to stick in an extension in order to reach high power with the Binotron.
I don't think I'd want to bother with a Power Switch if I'd need to remove the Binotron and stick in an extension every time I wanted to view at high power. Even having to pull the Binotron out an inch or two would be a kludge. These solutions sort of negate the convenience of the Power Switch. If I could insert the extension into the focuser first and then have the Power Switch focus at all three levels, that would be fine.
The funny thing is, I have no problem using a filter wheel with my old school Burgess Binoviewer in the Moonlite focuser. Of course, I still have to put an OCS on the neck of the binoviewer. But I needed to do that with my old focuser, too.
In the 1.5" Moonlite focuser with compression ring - no spacers - I can use either my 1.25" or 2" filter wheel without an OCS and come to focus with all my eyepieces except the ES 100 20mm.
Maybe if I'd gone for a Moonlite without the compression ring the ES 100 20 would have had enough in-focus for the 2" filter wheel? I'm not sure. But I wanted the extra security of the compression ring for filter wheels, binoviewers and heavy 2" eyepieces. I think that's worth not being able to focus for just one solitary eyepiece in the filter wheel.
#37 George9
George9
Posted 20 October 2013 - 08:17 PM
My preferred system for planetary viewing is now my Denk II Supersystem, Denk 21's, the 2" OCS, and an AP Advanced Convertible Barlow on a 18" Zambuto Starmaster with goto. I screw the AP Barlow's optical cell onto the OCS using a Denk-supplied adapter that Russ sent me to accommodate a Lunt blocking filter (the AP cell uses standard 2" filter threads but it requires a spacer between it and the OCS). I could see switching to Denk 14s but I have not bothered yet.
I spent some time playing around with the Paracorr and I forget exactly what configuration finally worked but it didn't add anything so I now skip it. I didn't specifically test for coma, but just got an impression of the view.
This has replaced my monocular planetary viewing, where I used to use a 5.2XL or my orthoscopics plus a Barlow and Paracorr. I only use the Denk on the 18" for planetary and lunar. I go monocular for DSOs.
The biggest advantage of the Denk over the Mark V for me is that I also use it on my solar scopes (Lunt 80, AP130 with wedge, etc.) and I find that the OCS and Powerswitch work very well without major contortions to bring it to focus.
Still, it would be nice to try a Mark V someday.
George
#38 beatlejuice
beatlejuice
Posted 21 October 2013 - 01:00 AM
Thats the thing about the power switch, after you get that first pair of eyepieces every other pair will only get you one more magification that is not close to being a duplicate of what the first pair gives you.
Eric
#39 Sarkikos
Sarkikos
Posted 25 October 2013 - 08:57 AM
At this point, I think I'll pass on both the Mark V and the Binotron.
The Binotron sounded interesting because of the Power Switch. But in practice it appears too fussy to make work easily for all three settings. Also, the image might not be as sharp through the high setting. That wouldn't work for me, because I only binoview planet/lunar. For deep sky, I always monoview. And the Binotron does not allow for coma correction.
The Mark V, on the other hand, does not have a Power Switch. But it does have optional coma correction. I'd like more information on that feature. Theoretically, binoviewing plus coma correction should be an ideal combination for planet/lunar.
For now, I'll continue to use my humble, old Burgess Binoviewer. It works very well for planet/lunar. But no Power Switch and no coma correction. Nothing is perfect.
#40 Eddgie
Eddgie
Posted 25 October 2013 - 10:38 AM
I have to tell you that recently I became aware that the Baader coma corrector might induce some spherical aberration.
I had star tested my new dob when I go it, and SA was actually really nicely corrected. This is not a premium quality mirror, but way better than I had prepared for.
Well, I did not really give it much thougth, but last time I used the scope with the binoviewer, I happened to change from the 35mm Ultmas, which take a lot of in travel, to one of my other pairs that don't take as much in travel.
When I did, for the first time, I noticed when I put in the other eyepices and refocused, the secondary shadow seemed a bit larger than it should have.
I am going to qualify this statement before I even make it. I was not using a 33% obstruction, so the test may not be fully accurate.. Anyway, I decided to rack though focus and to my surprise, the secondary shadow ratio was a lot different on the other side of focus!
This is the classic sign of spherical aberration.
Again, it is important to mention that I did not use a 33% obstruction. The problem is perhaps not really serious and maybe is some higher order spherical aberration (and that is why you use a 33% obstruction rather than the native 23%.. It greatly reduces any influence of HSA).
So, for now, I have to say that I have not had a chance to re-test with the 33% obstruction in place.
I plan on doing this the next time I have the scope out, which hopefully will be Sunday night.
Will try to remember to follow up.
Hoping it is just some HSA that would not be a factor at best focus with the native obstruction. The star test is super sensitive to HSA with small or no obstruction, but you can have a totally meaningless amount of HSA and it can give a bad reading.
Scope seems to perform well on the moon though. I would say at least ad good as my 6" APO and I think perhaps a bit better, but I really haven't done a side by side, so just working from memory of detail around the Triesnecker Rille. I know this area well from the C14 and the 6" APO, and I felt that it was showing detail right between the C14 and the 6" APO.
And that is what makes me think that I am seeing some HSA and not true LSA which I think can be more detrimental.
Still, not conclusive. Will know more when I test with the obstruction.
I love the Mark V and coma corrector though.
But the coma corrector extends into the focuser tube 92mm. This is not much different than the OCS on the Binotron.
So, this may not work for you either..
#41 Sarkikos
Sarkikos
Posted 25 October 2013 - 11:28 AM
My 10" f/4.8 Dob is a Celestron C10NGT OTA ported to a Dob mount. (I can't stand any Newt OTA larger than a 6" on a GEM.) The optics are very nice. I see no difference in the diffraction pattern in-focus and out-focus.
A larger CO reduces HSA? I had not heard of this. Maybe I should go back and reread my Suiter's? :shrug:
But I would think that any advantage to a larger CO - and I'm really skeptical that there is any practical advantage, except maybe for double stars - would be offset by the diminished contrast for planet/lunar. Did you raise the primary in an attempt to binoview without an OCS, and so had to change to a larger secondary? Otherwise, I can't imagine willingly changing from a 23% CO to a 33%.
By the way, my 10" Dob also has a native 23% CO. I like it that way, because IME it places the scope in a Goldilocks Zone making it good for planet/lunar and deep sky. :jump:
Please do, even if you have to start another thread to show your binoviewer experiences.
Sounds very much like my 10" Dob. That's why I'm not in such a hurry to upgrade to a 14" Dob - which I do want to do eventually. I'll just have to continue to ignore the condescending remarks and glances from my fellow observers at the dark site. It seems like for deep sky you're not really a member of the club unless you have at least a 14" Dob. :grin:
Yep, this definitely needs more thought before I pull the trigger. I might even wait on a binoviewer upgrade until I get that 14" Dob. Looks like I'll have to design the Dob around the binoviewer so everything will work optimally.
I'm also concerned that the Mark V coma correction might not be as good as a TV Paracorr. After all, the Paracorr has built-in tuning to optimise coma correction. AFAIK, there is no accommodation like that for the Mark V corrector OCS. Unless the coma correction is just right, there is a definite possibility of making the image worse rather than better. That may be what you are finding out with your Mark V and Dob.
#42 Eddgie
Eddgie
Posted 25 October 2013 - 12:19 PM
No, not what I said. The larger CO does not eliminate or reduce HSA at all.
The problem is that the star test is super sensitive and if you do it with to small (or no) obstruction, it can give the impression that there is lower order spherical aberration.
This is the mistake that Roland Christen made when he condemmed the star test. He noted that his breakout was very unbalanced.
It was clear to me from his essay on the star test that he did not follow Suiter's instructions.
The 33% obstruction is part of the process. The purpose is to desensitize the star test for the presence of HSA.
Unlike LSA, the HSA component will normally not throw light outside of the in-focus Airy Disk until it is quite bad.
It will slightly expand the diameter of the Airy disk, but not usually enough to be disenable visually. Since the light remains in the Airy Disk, contrast is not lowered.
But, if you defocus, you quickly change that dynamic and now the light is going into the ring structure.
The 33% obstruction at 10 wavelengths just gets you so far away from best focus that the effects are not easily seen.
So, obstruction does not fix HSA. Only masks it for the star test.
HSA when present rarely does damage. Even the all spherical f/12.5 MCT only looses .05 Strehl to HSA (best computed Strhel will be .95). This is not enough effect to be seen visually.
So once again, CO does not reduce HSA, only reduces the star test sensitivity to it. All of the HSA is still there, but you simply have to defocus so much that its effects are not enough to influence the breakout.
#43 Sarkikos
Sarkikos
Posted 25 October 2013 - 12:27 PM
OK, thanks. I understand your meaning now.
#44 Eddgie
Eddgie
I have to add one thing though. I was absolute in my answer, and it is really more complicated than that.
It is perhaps conceivable that a big enough obstruction does in fact lower HSA.
One of the forum members (Norme) removed the cone shaped secondary baffle from his MCT because he wanted to see if it improved the contrast.
When he did this, it lowered the obstruction by a meaningful percentage.
He immediately reported that HSA seemed more pronounced in the star test.
But again, the question is "Was there really more CA? Or did the bigger obstruction simply desensitize the test?"
Ant some point, the size of the obstruction takes so much energy out of the Airy disk that a slight change in diameter caused by HSA becomes so moot as to be purely academic because the far greaterr damage is done by the obstruction itself.
And this is why the f/12.5 MCT works OK. The HSA lowers the Strehl a bit, but the scope will star test well, and no one will complain that their scope has excessive LSA.
And I think Norme saw the difference.
Ask him about it in the Cats and Casses forum. He as probably done more with star testing and HSA than anyone else on the forum.
Nomre is his CN user name.
By now, maybe the best star tester on CN. His work with star testing his MCT pushed his understanding of HSA far beyond mine.
#45 Sarkikos
Sarkikos
Posted 25 October 2013 - 12:43 PM
IIRC, there have been many numerous discussions about larger obstruction benefiting double star observing, all revolving around these questions. I'm not sure which side is correct. But I'm confident that for planet/lunar, no advantage will be gained by a larger obstruction, ceteris paribus.
Now you're making me question the excellent star test on my C6. :(
Yep, I know just the guy you're talking about. I've talked with him many times on the Planetary and Lunar Fora. I envy his retirement in the Phillipines. My choice is between Delaware and Florida. :shrug:
:grin:
#46 Sarkikos
Sarkikos
Posted 25 October 2013 - 08:56 PM
Eddgie,
I have to ask you about this: Do observers usually star test their Newts with a 33% obstruction in place? I'd never heard of this before in actual practice. Suiter does mention it a few times in Chapter 10 of his Star Testing. But he doesn't talk as if this needs to be a standard phase of star testing and I've never read about it anywhere else. In fact, I've never heard of anyone actually doing it until now.
#47 Eddgie
Eddgie
Posted 25 October 2013 - 09:54 PM
Ah, good question.
For an instrument with no inherent HSA, (Newtonian) it is less important in the sense that if the pattern is perfectly balanced, the scope is fine.
But what happens if you do see some imbalance?
The 33% obstruction was chosen by Suiter because it is large enough that when used at 10 wavelength of defocus, if there is unbalance, it makes it easier to estimate how much spherical aberration is present.
This is the beauty of Suiter's method. If a 20% obstructed scope is perfect, then you will see it. But if it is not perfect, having the bigger obstruction makes it easier to see the ratio of the difference so you can make a better estimate of the actual SA present.
And again, in designs with HSA, or in APOs that can have HSA and color mixing that is different one either side of focus, the 33% obstruction can be necessary, but again, I believe he chose the 33% simply for the easy of quantifying the amount of SA. If the obstruction is smaller, seeing a difference of 20% is much harder than if the obstruction is a bit larger.
So this I think is why he came up with the 33% obstruction. It minimizes any HSA, and it provides a big enough shadow that it is easier to estimate any SA that is present.
Also, for the 3:1 breakout, it offers the same advantage. A 2 : 1 breakout would be to sensitive, and the 33% obstruction is once again just the right sensitivity. In particular, the breakout can be very imprecise even at 3 : 1 ratio. I have to often do this test several times and average my breakout point because it seems to be hard to find the exact spot where the inner ring comes out. I think at 2:1 it would be hard.
That is why I keep saying to people that the method is very specific, and my own results with all scopes have felt much more accurate when I use 33%.
But for an HSA free design, if the balance looks perfect, it is probably close to it. If it is not though, estimation is harder.
But I cheat. I always use a 33% obstruction but I use Aberrator to model what I see. I find it easier than estimating the secondary shadow size ratio difference. Finding a pattern with aberrator that looks as much like the pattern I see seems to work best.
But after doing it so many times, I have gotten pretty good at taking a wild guess for the initial settings for SA in Aberrator.
I also studied a lot of Rohr's tests where he has Fresnel patterns, and also the Aberrator site (which is where I learned how to do the modeling based on their 40 or so real telescope star tests and Aberrator models for those scopes.. A great web site for starting to learn about star testing.
Anyway, that is why I believe that 33% is best to use. It seems easier to estimate if there is SA present.
#48 Sarkikos
Sarkikos
Posted 26 October 2013 - 08:20 AM
Yes, I think this is exactly what is happening. A Paracorr can also induce aberrations if everything is not set up optimally. I have heard that unless the optics are closely aligned and that the field stop to Paracorr distance is just right, aberrations can be introduced into the system - SA and even more coma. I take for granted that your telescope optics are well collimated. So the odds are that the source of the SA is the Baader coma corrector.
When I first heard about the Baader coma corrector OCS I doubted the correction would be optimal and was concerned that it might even be harmful to the image. How can it be optimized if there is no mechanism such as the Paracorr's tuning top to finely adjust the corrector lens distance? Even if some sort of tuning ring were introduced into the system, how could the user easily gauge when the Baader OCS was optimally set? "Some coma correction is better than none" does not always work well in practice.
Especially for planet/lunar, we don't want SA induced into the optical system. Isn't this the same reason why the back-focus distance should not be overly extended when binoviewing a Cat?
#49 Eddgie
Eddgie
Posted 26 October 2013 - 10:27 AM
Well, some SA is not going to make much difference, so it is all a matter of how much SA changes, and I have not been able to measure that.
The Baader OCS is designed very specifically for the spacing provided by the Binoviwer and while it is only optinmal at one specific spacing, because the much longer design length (120mm minimum behind the corrector with the BV body in place) small variations will not be as big in terms of percentage as they would for correctors desgind for accepting just an eyepeice.
The Coma correction itself is quite excellent.
I won't know how much SA there is until I can use an obstruction and estimate it. I am not going to angst over 1/6th wave. It is really difficult to see much affect from this small a change.
But if it is larger than this, I may remove it and use a standard barlow for planets.
People forgat about this aspect of coma correctors. You don't have to use them when you don't want them.
For planets, I can just drop the OCA and stick in the BV with a 2" Barlow element screwed into the 2" nose piece.
Of course I have not tested that configuration to see if I can reach focus, but It worked in my 6" APO so I think it may work here as well.
And again, the only time SA really matters all taht much is for planets.
Yes, lots of back focus in an SCT can indeed induce SA. And not just a little.
I tested one configuration taht induced about 1/4th wave. That is getting to the edge of what I would tolerate.
But kept under about 200mm of light path and the change is pretty modest. Again, I don't angst over small changes in SA.
Years ago, I was totallly anal about it, but after much testing, I realized that it took more than 1/6th wave difference to really see, and even then, until it gets to 1/4th wave, it is not all that easy to see, though if there are any other issues like roughness, you start to push into soft view territory.
Anyway, hope to test tomorrow night if the weather clears.
#50 Sarkikos
Sarkikos
Posted 27 October 2013 - 09:24 AM
Yes, as you - and Suiter - have said, degradation of the image from SA depends on whether it's HSA or LSA and how much is present. Also, effect of SA will depend on the object viewed and how it is viewed. I have a 4.5" f/4.4 Ball Newt with a spherical primary. The image is acceptable - to me - for low power views of open clusters, bright bright nebulae and large bright galaxies. It was the first telescope that showed me M78 under my light-polluted suburban skies. But for higher power observation of planet/lunar? Forgetaboutit.
This is why I am concerned about SA induced by the Baader coma correcting OCS. My binoviewing is virtually always for planet/lunar.
Makes sense.
Some observers, though, apparently refuse to do any observing unless a Paracorr is in the focuser. I'm not that type of observer. I'd rather have coma correction at all times. But sometimes you do have to give it up for other advantages. For instance, at this time I cannot binoview or use filter wheels with a Paracorr in the system. So out goes the Paracorr. eh... :shrug:
And again, the only time SA really matters all that much is for planets.
And for lunar, and probably for any DSO that are better seen at higher power. But SA is the big bugaboo for planet observation. AFAIK, SA affects on-axis sharpness more than coma. So according to my understanding, for planet/lunar, correcting SA is more important than coma correction.
