AstroTortilla vs UniMap for plate solving
37 replies to this topic
#26 Phillip Easton
Phillip Easton
  • Loc: DFW
Posted 21 October 2013 - 09:22 AM
That should help. Just a FYI I am imaging at 0.887 arcsec-pix. I set my limits too 0.75 - 1.0 arcsecperpix. Field is set to 45 and sigma 6 or 7. My exposure is 10sec. It solves in about 10 sec.
Cheers!
#27 orlyandico
orlyandico
  • Loc: Singapore
Posted 21 October 2013 - 09:52 AM
i've been using arcminwidth - but you can also use arcsecperpix?
#28 Coastal
Coastal
  • Loc: Vancouver island, Canada
Posted 21 October 2013 - 10:05 AM
If I understand correctly, you're using arcminwidth with a range of 0-200. Certainly doesn't sound ideal. Use Pinpoint to calculate your actual image scale and try 0.1 lower and 0.1 higher (ie I use 1.6 and 1.8 for my 1.8"/px scale) using arcsecperpix.
#29 orlyandico
orlyandico
  • Loc: Singapore
Posted 21 October 2013 - 10:17 AM
Well Astrometry itself tells me my correct pixel scale. :) which (was) 2.68"/pixel as opposed to... 2.68"/pixel according to the Starizona calculator (http://starizona.com...calc_pixel.aspx)
I don't have PinPoint, and I have no interest in Elbrus (you need to set the camera angle correctly every time?!?!?!?!?!) but I will try being very exact.
BTW nice idea with the USB power box.. I went with a similar method (R78B05 DC-DC converter to provide 5V for my USB hub form a battery). Thankfully I don't need 7.5V, but the camera cooler sucks power like there's no tomorrow...
#30 Moromete
Moromete
  • Loc: Romania
Posted 21 October 2013 - 10:26 AM
Why don't you try Unimap if you are using hints already?
#31 orlyandico
orlyandico
  • Loc: Singapore
Posted 21 October 2013 - 11:03 AM
astrometry works for me (if a bit slow), I like their development model (and the fact there's a lot of published research that uses their engine), etc. etc.
the reality is I only do 1-2 slews per session, so that's 1-2 solves per session. 20-second solves barely annoy me. I would like things to go faster, but the current scheme isn't killing me.
#32 David Pavlich
David Pavlich
    Transmographied
  • Loc: Mandeville, LA USA
Posted 26 October 2013 - 09:19 PM
I have an MI250 controlled by SiTech. Since it's an ASCOM driven program, I'll assume that it'll work with this setup. Is there anything that in the SiTech system that may cause a problem with the mount interfacing with AT?
David
#33 orlyandico
orlyandico
  • Loc: Singapore
Posted 26 October 2013 - 11:54 PM
Dave, not that I know of. AT only knows how to talk to ASCOM (and nothing else) on the mount side, so anything with a working ASCOM driver that supports resyncs will work.
#34 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 27 October 2013 - 07:43 AM
Dave, it works good :)
#35 David Pavlich
David Pavlich
    Transmographied
Posted 27 October 2013 - 10:00 AM
That's all I needed to read! Thanks, Chris.
David
#36 David Pavlich
David Pavlich
    Transmographied
Posted 27 October 2013 - 10:01 AM
Well, I'll have to download it and give it a try. Thanks for the quick reply!
David
#37 Raginar
Raginar
Posted 28 October 2013 - 09:12 AM
One thing to consider, what are you imaging with? You might try out Sequence Generator Pro. It can use the localized astrometry.net server you install with AT. Free plate solving included with acquisition automation kis really me. And, they're adding dome/roof support this version.
#38 Gvs
Gvs
  • Loc: Texas
Posted 05 November 2013 - 06:43 AM
It is possible to refactor Astrotortilla to point to http://nova.astrometry.net/ which is up an running.
live dot astronomy dot net has issues.
