How do I mount Takahashi Clamshell on Vixen GPDX?
4 replies to this topic
#1 oldjet
oldjet
Posted 20 October 2013 - 08:00 PM
Hi Friends,
I have a Takahashi TSA102 that came with a clamshell tube holder.
Would you please advise how do I mount it to a Vixen-style saddle (my mount is GPDX).
I believe I'll need a matching dovetail plate, but I need advise regarding:
- The right plate length for that scope.
- Where to get the properly sized screws to fit into the Tak clamshell holes.
- Well.. the actual part number would be very nice :)
Thanks in advance for sharing your experience..
-oldjet
#2 Mr Greybush
Mr Greybush
  • Loc: Virginia
Posted 20 October 2013 - 08:03 PM
Read this it should help http://www.cloudynig...php?item_id=845
#3 GolfSierra
GolfSierra
  • Loc: Michigan
Posted 22 October 2013 - 08:25 AM
I used an ADM VDUP7 Vixen plate bolted directly to the clamshell. Balance the OTA fore and aft in the clamshell, a 6MM or 1/4x 20 bolt will work with a locknut.
http://www.admaccess..._Universal.htm?
#4 oldjet
oldjet
Posted 22 October 2013 - 06:45 PM
THANK YOU for that!
#5 Kunama
Kunama
  • Loc: Canberra, Australia
Posted 22 October 2013 - 10:49 PM
I would recommend that you don't rely on just one 1/4" bolt to hold such a beautiful bit of kit.
The clamshell has 8.5mm holes drilled 35mm apart in line with the 1/4" hole,
I recommend you drill the dovetail plate and tap some M8 threads into these holes to secure the OTA to the dove plate. Then use 2 stainless steel M8 cap screws for a nice secure fit.
Just my 2 cents but I would hate to see a Tak Teaser hit the floor.
I actually changed to a Robin Casady saddle and dovetail which are designed just for this situation:
