Ioptron ZEQ25 mount
3 replies to this topic
#1 james andraza
james andraza
Posted 21 October 2013 - 08:04 PM
To anyone using the new Ioptron ZEQ25 mount. Do you find that the polar scope led units burn out prematurely? I had two burn out.
#2 ramasule
ramasule
Posted 21 October 2013 - 09:30 PM
Mines still fine, make sure your not overvolting the mount as I suspect the led is not fed from conditioned power, as in connected straight from the switch.
#3 Seanem44
Seanem44
  • Loc: Woodbridge, VA
Posted 22 October 2013 - 06:28 AM
I never had an issue. Though I will say the connection to the scope is a little loose.
I will add that it is the best polar scope I have ever used.
#4 rkayakr
rkayakr
  • Loc: Northeast Ohio
Posted 22 October 2013 - 08:37 AM
No LED problems here.
I have seen even a slightly higher voltage that is still well within spec cause drive error reports.
