Omicron Persei
5 replies to this topic
#1 astro4565
astro4565
  • Loc: UT
Posted 02 November 2013 - 03:58 PM
Anybody split this double star with a 120mm refractor? My NGC-Max guide says this star is 1.0" arc-seconds. I guess seeing would have to be excellent to split this double. Any reports on Omicron Persei would be appreciated. May have to try this one on a clear cold night.
#2 azure1961p
azure1961p
  • Loc: Triton
Posted 02 November 2013 - 05:26 PM
I'd personally not even mother. That great s difference in magnitude at that distance is too staggering for me to consider with my 8". Maybe a bigger scope can pull it off but it'd not be easy,
Pete
#3 fred1871
fred1871
  • Loc: Australia
Posted 02 November 2013 - 07:45 PM
Omicron Persei will be a tough one - 2.8 mags brightness difference (current WDS numbers, probably from Tycho) and only 1.0" separation. If the stars were equal, 120mm could show a Dawes Limit touching discs view; but with the big brightness difference, it becomes very much harder, and is likely to be marginal with 140-150mm scopes, though the secondary will sit in the first dark interspace of the diffraction image at that aperture.
It could be possible with a good 8-inch (200mm) - the secondary star on the outside edge of the first diffraction ring. For a 7-inch the secondary will sit on the diffraction ring, making it hard to see. Hmmm. Think I'll try it with my C9.25 when it gets into my midnight sky, a month from now. With that aperture the secondary should be nicely outside the first diffraction ring, with Rayleigh being ~0.6" for that aperture.
Doubles like this one need both sufficient aperture, and preferably an aperture that avoids putting the secondary star on the first diffraction ring.
An historical note - SW Burnham discovered Omicron Per (BU 535) as a double in 1878 with the 18.5-inch refractor in Chicago (though it had been measured by another observer the previous year). The separation has been pretty constant since then, but the angle has gradually changed.
#4 azure1961p
azure1961p
  • Loc: Triton
Posted 02 November 2013 - 07:57 PM
I need to cross reference SS more. They have an almost 5 Delta-M!!!!!!
Well your finds top the scale the other way then.
Pete
#5 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 02 November 2013 - 09:08 PM
I could not do it at 150mm aperture obstructed, "I also did not resolve Atik (P.A. 23 SEP 1 MAG 3.91-6.7) but it does seem doable."
I agree with Fred, and Pete, at ~ 3 mag difference inside the first ring things get interesting. It might be doable, though difficult.
#6 astro4565
astro4565
  • Loc: UT
Posted 03 November 2013 - 11:03 AM
I guess Omicron Persei is in the same catagory as Zeta Herculis. You need at least an 8 inch scope with superb seeing. I may have better luck with Eta Geminorum.
