Counterweight transport
22 replies to this topic
#1 plav1959
plav1959
  • Loc: Central Florida
Posted 05 November 2013 - 06:18 PM
I've got four A-P counterweights on the way and was wondering what people use to transport and protect them. DIY or purchased. Pictures would be very much appreciated!
#2 Cotts
Cotts
    Just Wondering
  • Loc: Toronto, Ontario
Posted 05 November 2013 - 06:51 PM
I use cloth shopping bags. I have 4 counterweights, so, four bags. I put one inside the other so that I only carry two bags....
Dave
#3 Stelios
Stelios
  • Loc: West Hills, CA
Posted 05 November 2013 - 07:12 PM
I transport my humble CG-5 counterweights (2 x 11 lbs ea.) in a small Pelican case (I think it's a 1200). They fit pretty well. I'll see if I can get pictures tonight.
OTOH, AP makes counterweights from 5 to 24 lbs, so much depends on what weight you're talking about. But I would think that ideally you'd split them two to each case (with some protective foam to separate). Then you can walk "balanced."
#4 Whichwayisnorth
Whichwayisnorth
  • Loc: Southern California
Posted 05 November 2013 - 07:33 PM
Only easy way I can think of is to wrap them in plastic and put them back in the original box with the foam forms.
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 05 November 2013 - 10:50 PM
My Atlas counterweights, two eleven lb and one seven lb are in a Pelican case
#6 mgwhittle
mgwhittle
  • Loc: Chattanooga, TN
Posted 05 November 2013 - 11:00 PM
A case I built myself. Holds three 18 pound counterweights and has a lift off top.
#7 core
core
  • Loc: Mostly in Norman, OK
Posted 05 November 2013 - 11:22 PM
$5 tool bag from Harbor Freight and EPP Foam (in this case, the foam inserts for an Orion 6" Dob is a perfect fit). These are 22lb CGE weights. Everything's snug even if bags are upside-down.
#8 snommisbor
snommisbor
  • Loc: Cedar Park, TX
Posted 05 November 2013 - 11:58 PM
My Scope guard case has two slots for my counterweights, of course the case with my mount in it makes it heavy but that is how mine transport.
#9 andysea
andysea
  • Loc: Seattle, WA
Posted 06 November 2013 - 02:09 AM
I have four AP counterweights and I carry them in this case
http://www.amazon.co...r/dp/B0010AWJ5S
The weights are stacked in two tiers separated by a sheet of neoprene that I cut to size. The pluck foam has two layers and that is part of the reason why I picked this case.
It was the most compact and elegant solution that I could find.
#10 MartinTreadgold
MartinTreadgold
  • Loc: Netherlands
Posted 06 November 2013 - 03:24 AM
Supermarket Shopping bags ftw!
#11 hahied
hahied
  • Loc: N57 E13
Posted 06 November 2013 - 04:09 AM
This is my homemade solution. Easy to store, carry and transport in car.
Hans
#12 hahied
hahied
  • Loc: N57 E13
Posted 06 November 2013 - 04:30 AM
And this is for counterweight shafts.
#13 mgwhittle
mgwhittle
Posted 06 November 2013 - 05:03 AM
Hahied, I like what you did. I am going to copy it for transporting my weights when I am setting up at home.
#14 snommisbor
snommisbor
Posted 06 November 2013 - 09:27 AM
Thats pretty cool Hahied
#15 CharlesW
CharlesW
  • Loc: Chula Vista & Indio, CA
Posted 06 November 2013 - 10:37 AM
I have four of the MX counterweights. At home I just leave them stacked up in the closet but on the road I load them onto the shaft and then put everything into a $19 Home Depot Husky plastic tool box. It works perfectly. Of course, the toolbox isn't nearly strong enough to be picked up with all that weight, 100 lbs, it's just to protect them while in the back of the truck. I'm a big fan of the Husky line. I use the big boxes to transport my C14 and mount and the Technician boxes for my eyepieces and bits.
#16 Pat at home
Pat at home
  • Loc: Campbellton, New Brunswick, Canada
Posted 06 November 2013 - 03:56 PM
Haheid,
I suggest you watch out for your toes when carrying the counterweights. Screw threads into end grain wood is not the strongest joint. Better would be a threaded rod all the way through the central dowel and through the base secured with a washer and nut.
#17 plav1959
plav1959
Posted 10 November 2013 - 05:04 PM
Nice case Mark. Where did you get the aluminum extrusions?
#18 plav1959
plav1959
Posted 10 November 2013 - 05:07 PM
Hey Rob,
I had considered Scopeguard cases for the mount and counterweights until I went online and saw the business is up for sale...
#19 Seldom
Seldom
  • Loc: N of Cedar City Light Dome
Posted 10 November 2013 - 06:00 PM
Hans
Like the others said, definitely cool, but why did you put the white buttons on the bottom of the counterweight carrier?
#20 mak7
mak7
  • Loc: light polluted Phoenix AZ
Posted 10 November 2013 - 06:16 PM
I have used two versions of inexpensive carriers for different mounts. Very easy to build with out any special tools.
Brad
#21 mak7
mak7
Posted 10 November 2013 - 06:18 PM
And the other style.
Brad
#22 OneDaveT
OneDaveT
  • Loc: IL, USA
Posted 11 November 2013 - 08:29 AM
Here's a very low tech solution I've been using:
http://www.cloudynig...5006032/page...
#23 hahied
hahied
  • Loc: N57 E13
Posted 11 November 2013 - 08:38 AM
Hans
They are protecting the wood from water when the ground is wet outdoors after rain or melting snow in winter.
In earlier post "Pat at home" made a good suggestion about a threaded rod all the way through the central dowel and through the base to make it stronger. I actually made that change a couple of days ago in order to "save my toes". Now it should hold more than 50 kg without problems.
