Problems with dark lines
5 replies to this topic
#1 federico bonino
federico bonino
  • Loc: Argentina
Posted 06 November 2013 - 08:36 AM
Hello everybody!
I have a problem when I take videos with NEXIMAGE CCD. In all cases appear some dark lines that is very difficults to remove.
I have seen that it is possible to minimize them by adjusting the tuning, but not possible to eliminate them.
Could any one told to me if this is a normal effect?
How is the procedure to eliminate them?.
Thanks to all
I attached an image like example
Federico
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 06 November 2013 - 09:13 AM
I guess you are suffering from Newtons rings.
Two ways for cure
1. Tilting
http://zwoug.org/vie...php?f=24&t=1395
2. Flat fielding
http://www.cloudynig...4999954/Main...
#3 bunyon
bunyon
  • Loc: Winston-Salem, NC
Posted 06 November 2013 - 09:56 AM
Yes, that looks like Newton's rings. I cured the ones in my system by purchasing a tilt-adjuster from OPT. If they aren't bad, flat fielding may work. You might play around trying to manually tilt the camera to see if you can get rid of them.
#4 federico bonino
federico bonino
  • Loc: Argentina
Posted 06 November 2013 - 10:11 AM
OOHHKEY Tapio!!!! Excellent!!! Thnaks very much!!.
I did not know that such problems exist.
So Them If I understund good, the problem is due to a difference of parallelism between the camera chip and the device of PST Them maybe I should check first the condition of setting between the diagonal & CCD.....
OK OK thanks very much by your usefull help!!
Best Regrads
Federico
#5 federico bonino
federico bonino
  • Loc: Argentina
Posted 06 November 2013 - 10:35 AM
OK Paul Thanks!!
OK so them, I start trying moving the camera, them if I don´t eliminate it, I try with flat frames.
Thanks a lot!
#6 Paul Hyndman
Paul Hyndman
  • Loc: Connecticut Shoreline USA
Posted 06 November 2013 - 07:17 PM
Take care to ensure the camera is solidly mounted (droop-free), as even a miniscule variation from square (orthogonality) can introduce the "rings". As Tapio mentioned, a tilt adapter can help dial them out, if finessing the mounting alone does not do it.
My preference has always been to hone "front-end" techniques that improve the quality of the raw images, thus requiring the least amount of post-capture processing "magic".
But hey... a big part of what makes this stuff so much fun is the challenge (and sharing our notes)!
Paul
