IOptron Skyguider
40 replies to this topic
#1 kyang
kyang
  • Loc: Fremont, CA
Posted 16 November 2013 - 07:33 PM
Besides the CEM60, IOptron also introduces a portable GEM.
Based on ZEQ25 but without goto.
Source: http://www.hkastrofo...ic.php?p=273032
#2 Astronewb
Astronewb
  • Loc: Connecticut
Posted 16 November 2013 - 09:37 PM
Now that's 'thinking outside the box'. A half of a ZEQ25 mount for wide field camera imaging.
No Go-To, but it can be auto-guided.
Here's iOptron's official release with specs:
http://campaign.r20....00b-a055-36c...
This proves one thing, the folks at iOptron are obviously not sitting around patting themselves on the back for past successes? Someone must have hung up a "Lead, follow or get out of the way" poster at the company headquarters.
Cheers...Paul
#3 Mkofski
Mkofski
  • Loc: Greenfield, Indiana, USA
Posted 16 November 2013 - 10:09 PM
****, now I need to justify 2 new mounts!
#4 kyang
kyang
  • Loc: Fremont, CA
Posted 17 November 2013 - 12:02 AM
Curious about the possible price point of this baby.
They have SkyTracker for ~$400 and ZEQ25 for ~$800 ... Maybe $600? ;-)
#5 Mkofski
Mkofski
Posted 17 November 2013 - 12:07 AM
This seems like more of a replacement for the Smart EQ Pro to me. Would like to find out what the price will be. Shouldn't be long now if they are going on sale in December.
#6 Pinbout
Pinbout
  • Loc: uhmm...still in 2nd grade
Posted 17 November 2013 - 12:22 PM
Cheers...Paul
I appreciate their efforts, they keep designing. And not just going for bigger and bigger but the attention to these smaller mounts is very refreshing.
#7 Yun-Oh
Yun-Oh
  • Loc: Gibsonia, PA (Greater Pittsburgh)
Posted 17 November 2013 - 10:33 PM
The web site says,
- Capable for dual mount application up to 11lbs (5kg) + 7.7lbs (3.5kg), balanced
Can anyone translate this? How much weight can I put on this little mount? 7.7lbs, 11lbs, or 18.7lbs?
I wish they came out with this mount a little earlier. I would have bought it over SkyTracker. SkyTracker is a fine piece of equipment, but the load capacity keeps me from putting everything I want on the mount. I was seriously thinking about getting a SmartEQ Pro, but I guess I will have to wait for this little baby...
#8 gmartin02
gmartin02
  • Loc: Santa Clarita, CA
Posted 19 November 2013 - 01:05 AM
I saw this mount at the ASAE show and talked to the iOptron rep at the show about it.
He said that because it uses some of the same parts as the ZEQ25 they can keep the cost down - although no official price yet, the rep said probably somewhere between $400-500 for the head, motor, counter weight shaft, and I think the counterweight. Also, he said the pictured mount (the same one that was at the show) is a prototype - the production model will use a "standard" 20mm counter weight shaft (larger than the one on the prototype).
#9 Cotts
Cotts
    Just Wondering
  • Loc: Toronto, Ontario
Posted 19 November 2013 - 09:30 AM
Well, that figures. I have just bought a ZEQ25 thinking it was the lightest GEM with a decent weight capacity that I could take in my luggage to Chile in March. I don't really need go-to for the objects I will be shooting there - a Telrad would have been fine...
Not that I am dissatisfied with the Z......
.....but this new mount would have been ideal.
Dave
#10 cloudywest
cloudywest
Posted 19 November 2013 - 09:36 AM
My understanding from the piture, you can mount two cameras (or scopes) when take out the counterweight and shaft. 5 kg at one side and 3.5 kg at the other.
#11 Linkage
Linkage
Posted 20 November 2013 - 12:03 PM
Got SkyGuider. :jump:
Installed in zeq25 (or ieq30) the tripod.
Using the two CW shaft (only used as a test), the upper mounting 5D2 +16-35
I will soon be tested using the 100-400mm.
#12 Linkage
Linkage
Posted 20 November 2013 - 12:20 PM
Compared skytracker, obviously a lot of weight, if coupled with tripod/cw/..., even heavier. (But relatively zeq25 or ieq30 still a lot of light)
I guess that this should be more suitable 200-400mm or greater lens(guide or not guide). Alternatively, dual camera (such as meteor showers, etc.), and solar or lunar eclipse, or more.
#13 Full Sun
Full Sun
  • Loc: NOTL, Ontario
Posted 20 November 2013 - 12:47 PM
Linkage
I notice you have a Lunt LS80 T in your arsenal. Perhaps you have a light weight tracking solar observing mount /scope combination at your disposal. How about giving it a go?
Guessing that tuning maybe more of an issue than focusing while tracking, but could this combination satisfy?
#14 Astronewb
Astronewb
  • Loc: Connecticut
Posted 20 November 2013 - 02:45 PM
That looks like a great lightweight RA tracking mount, what is the weight of the Skyguider mount alone?
Thanks for the image, very nice setup.
Regards...Paul
#15 Yun-Oh
Yun-Oh
Posted 20 November 2013 - 06:51 PM
The spec says 2.6kg (5.7lbs) without the cw shaft. It is still light enough to carry around, I think. It also can support a gimbal and rail support for a telephoto lens, an ideal setup I can't put on my Skytracker. Now I need an excuse to replace my Skytracker I bought less than a year ago. My CFO would not be happy... It's iOptrpn's fault... :-(
#16 Linkage
Linkage
Posted 20 November 2013 - 07:29 PM
Linkage
Because only a single axis, when shooting full disk would be more trouble.
I think it is suitable for shooting local details.
#17 Linkage
Linkage
Posted 20 November 2013 - 07:44 PM
Hi Paul,
alone skyguider mount only 2.6kg, compared zeq25, about lighter 2.1kg.If we add the original cw, cw shaft, is expected to total weight of 5kg or less.
Suitable for a trip shooting.
#18 Linkage
Linkage
Posted 20 November 2013 - 07:49 PM
SkyGuider should be more suitable telephoto lens (200 ~ 400mm or more), while the following skytracker 200mm (100mm or less is best).
And skytracker more suitable for a backpacking trip.
#19 kyang
kyang
  • Loc: Fremont, CA
Posted 21 November 2013 - 03:01 AM
With only single axis control, how much auto guide can help ?
#20 nickwv
nickwv
    Vendor-Altair Astro Europe
Posted 21 November 2013 - 08:05 AM
I imagine that if polar alignment is accurately achieved using the GPS & polar alignment App in your Smartphone, then there should be no need for the DEC motor at DSLR-style focal lengths anyway. Autoguiding could run on the RA axis to match the sky rate.
#21 Aargau
Aargau
Posted 23 November 2013 - 12:38 AM
I've got a Canon 5d3 and a 600mm f/4 II (weight of lens alone is 3.92kg).
If this product supports that combo I'm happy to pre-order.
#22 Bluejay08
Bluejay08
Posted 23 November 2013 - 02:08 PM
It should If the weight is less than 5 kg.
#23 kyang
kyang
  • Loc: Fremont, CA
Posted 17 December 2013 - 04:09 AM
I am curious how it will compare with Kenko Skymemo.
According to http://www.njnoordhoek.com/?cat=9 ,
Kenko Skymemo has something like 42 arc seconds p-to-p PE
#24 kyang
kyang
  • Loc: Fremont, CA
Posted 19 December 2013 - 11:36 AM
In stock now -- http://goo.gl/ExPjp1
#25 Astronewb
Astronewb
  • Loc: Connecticut
Posted 19 December 2013 - 12:23 PM
Very nice looking camera mount. I notice that iOptron finally redesigned the polar scope on this, putting the scope out far enough to actually adjust the axis of the scope to the mount's axis. A longer cover is provided to suit the change.
Now perhaps the latest ZEQ25 mounts will have this type of setup?
iOptron is obviously listening to users, because the original design, was adjusted at the factory and not accessible when installed. That was a serious oversight on the Z design, which now looks corrected.
Cheers...Paul
