Question and Advice
90 replies to this topic
#1 Copernicus1473
Copernicus1473
Posted 19 November 2013 - 10:55 AM
Good Morning,
I hope that I don't get killed for this post. The last Time I asked a question about Questars on the Classic Forum, I created a firestorm. What is it about these scopes that cause quite a stir?
I have heard so many good things about Questars and am excited that I might be able to buy one. I have been in astronomy for about one year and own an Orion 8XT Dobsonian. I have a good assortement of eyepieces. I enjoy using it but sometimes I just don't feel like lugging it out of my garage. I am looking at buying an older Questar (3.5) and was thinking about using it as a grab n go telescope. Would this scope make a good "garb n go? I have only seen pictures of them so I don't know what to expect.
I heard that the optics are good. What about eyepieces? Can you use any type or do you need to buy special ones? Any help, advice or opinions would be greatly appreciated.
Jack
#2 ColoHank
ColoHank
  • Loc: western Colorado
Posted 19 November 2013 - 01:30 PM
Excellent grab n go on its supplied legs for tabletop use, or with a tripod. Resolution and light grasp won't compare with your eight-inch Dob, but a Questar is very compact, very light (about seven pounds), and of superb optical and mechanical quality. Built-in Barlow, and the finder is accessible through the main eyepiece with the flip of a lever. Wonderfully smooth slow motion controls, no collimation necessary, and unparalleled support from a company that's been making scopes in the USA since the mid-1950s.
Plus, it tracks (at both sidereal and lunar rates if equipped with Powerglide II), so you won't have to constantly nudge it along to keep object in the eyepiece.
#3 Brent
Brent
  • Loc: NE Missouri
Posted 19 November 2013 - 02:33 PM
I'm with Hank. Questar has to be something like the original "grab-n'-go," designed and launched when the typical telescope was the 3" or 4" refractor on a less-than-wieldy equatorial mount. I have two other scopes, one larger and one smaller than the Q, but the Questar is the one I use the most precisely because it is so easy to set up and use.
As far as eyepieces: the newer Questars accept both threaded Brandons and standard 1-1/4" eyepieces. To use 1-1/4" eyepieces in an older model, you will need an adapter such as the one TeleVue sells. I don't know what year Questar made the change, but someone will know. My Questar is an '06 model and accepts both types of eyepieces.
Brent
#4 A6Q6
A6Q6
  • Loc: Stroudsburg,Pa,U.S.
Posted 19 November 2013 - 04:47 PM
"My home observing is primarily Questar-based, utilizing an aluminum pier that can be removed for mowing and replaced without losing polar alignment." These words are from RRavenberg. They were from the Ravenberg Scope Gallery before he passed on. He made telescops from 17" dobs to much smaller refractors on very unique mounts. But at home he used a 3.5" Quester. There is now a Ravenberg Memorial Scope Gallery but the Questar section with the all the photo's of how he used his Questar is missing. I would like to see that part restored. I feel that showing how Ravenberg had access to all kinds of telescopes, but that the Questar had a unique place at his home, would show the complete Ravenberg and help others make a decision on owning a Questar. I'm really glad I saved that thread and many others from CN on my computer. Hope this helps Copernicus1473 ;)
#5 starboy1954
starboy1954
  • Loc: Aurora, Il
Posted 19 November 2013 - 06:09 PM
It literally takes minutes to set up and break down. Not to mention if you're using the supplied legs on a table top (I use a hefty picnic table) you can do it all comfortably sitting down. Atlases, iPad, etc. all within easy reach on the table! The viewing experience is so seamless and effortless.
Wonderfully crisp views. Only 3.5 in, yes, but I can count on one hand the number of times seeing provided me with optimal 8 in views with my C8.
Of course the C8 beats it on clusters and galaxies but once again my city skies are so light polluted that lunar, planetary, and double star viewing is what I do anyway. Q rocks here.
I must say I have never yet taken the little Q to a really, really dark site. I'm curious how it performs there.
#6 JMKarian
JMKarian
  • Loc: Northwestern PA
Posted 19 November 2013 - 06:47 PM
Jack,
The Q's have tremendous versatility. One day last summer - with my duplex - (1) imaged damselflies landing on cattails in the pond at 25' distance and able to resolve the critter's compound eye structure (2) later inspected the coaxial cable attachment to my ham radio antenna @ 50' on a tower while sitting on the deck (3) Put it on the tristand to check out the "night's best".
#7 Billydee
Billydee
  • Loc: Winter Haven, FL
Posted 19 November 2013 - 08:51 PM
Brent,
The 1994 model was the last year that the Diopter Adapter would only work with the Brandon EPs. In 1995 they started to produce the Diopter Adapter that will accept all EPs (a copy of the TV adapter). Questar can supply their adapter to pre-1995 Qs (I think they are about $85) and you just screw out the old one and replace it with the new one.
Bill
#8 Copernicus1473
Copernicus1473
Posted 20 November 2013 - 08:00 AM
Thank you for your posts and encouraging words. Looking forward to getting the scope and will post some pictures once I get it. That is if I can figure out how to do it? The weight, portability and ease to setup and take down is what I am looking for (sounds like an ideal grab n go scope). I live in a dark sky area which will only enhance the viewing.
I heard good things about the company and their customer service, and the fact the they are located in the United States and has been in business for awhile is a big plus. Glad to hear that you can buy an adapter so that you can use other EPs. I have been looking on the internet and the Brandon EPs are expensive.
Thanks again for your input. It is greatly appreciated!
Jack
#9 Brent
Brent
  • Loc: NE Missouri
Posted 20 November 2013 - 11:16 AM
Thanks Bill. I knew someone would know.
Best,
Brent
#10 Copernicus1473
Copernicus1473
Posted 22 November 2013 - 08:47 AM
I will be picking up the scope this weekend. It does not have a manual. Is there a manual that I can download or is it best to contact Questar once I get the scope?
#11 dougm
dougm
  • Loc: Philadelphia,PA
Posted 22 November 2013 - 09:51 PM
Here is something that can be found through the Company 7 website.
http://www.company7....ebklt1960lr.pdf
#12 dkapla12
dkapla12
Posted 23 November 2013 - 10:44 PM
Call Questar for the manual. They'll also be able to tell you the age of the scope from the serial number that's on the bottom of the base. Enjoy the scope.
#13 dkapla12
dkapla12
Posted 23 November 2013 - 10:47 PM
Questar's diopter adapter will accept all 1.25" eyepieces starting in around 1972, but in 1995 they added a couple of nylon setscrews to hold the eyepiece in place. Before '95, you could just drop the eyepieces in. If you need to replace the diopter adapter, TeleVue also sells one, but get the one from Questar, it's really much nicer.
#14 Mike E.
Mike E.
  • Loc: Moonstone Observatory
Posted 24 November 2013 - 03:01 AM
Hello Jack,
I recently purchased an older 3 1/2" Standard which came with the earlier eyepieces that have a built in focuser. They uses a smaller 1 3/16" adapter tube as seen in the left of the photo.
A Tele Vue 1 1/4" adapter was also included, but like the adapter for the early version of the Questar eyepieces, has no provision for focusing an eyepiece for finder use (photo center).
I contacted Jim Reichert at Questar for a current focuser diopter adapter. It fit perfectly, (right of photo) and enables the use of threaded Questar Brandons, non threaded Brandons, and other 1 1/4" eyepieces. The price was $85 plus shipping, well worth it in my opinion.
Note that not all eyepieces will come to focus with the Questar "finder". There is a list of those that do, but I don't recall where at the moment; perhaps someone will chime in with a link. Hope this is helpfull.
#15 Copernicus1473
Copernicus1473
Posted 24 November 2013 - 08:16 AM
Thank you you for all of your help. I will be picking it up today and will call Questar Monday morning. I was going to try it out today or tonight but will wait a few days. Hopefully it will get a little warmer. Right now 10 degreesa and wind gusts to 35 miles per hour.
I will probably have a few more questions once I get it and start to use it. You are all a great group of people and from reading the posts very knowledgeable. Thanks for sharing!
Have a great day.
Jack
#16 Copernicus1473
Copernicus1473
Posted 04 December 2013 - 10:55 AM
I contacted Questar and they told me that the scope was manufactured on 7/1/1955. They certainly keep great records. It has been a while since I purchased something older than me :lol:
#17 Billydee
Billydee
Posted 04 December 2013 - 08:06 PM
Jack,
What is the serial mumber on your Q? It may be one made in the first year. Early ones are wonders.
Bill
#18 Copernicus1473
Copernicus1473
Posted 05 December 2013 - 06:27 AM
The serial number for my Questar is R-8-104.
#19 Billydee
Billydee
Posted 05 December 2013 - 03:57 PM
Jack,
You have a very very early one. It was 55th Questar to come off the production line (I understand the first production Q has the serial number 50). The R stands for modified or reworked, remanufactured, replaced or revised at a later date (Questar could probably tell you what was done). The 8 is the last digit of the year it probably was reworked.
You are a lucky man, Bill
#20 Copernicus1473
Copernicus1473
Posted 06 December 2013 - 12:14 AM
Bill,
I did not know that you could tell so much about the scope based on its serial number. I do feel very lucky and fortunate about getting it. I have heard so many great things about Questar telescopes. Though I am not sure that I totally understand about how lucky I am. Is there much difference between the older and newer scopes? I figured that the older scopes would not be as good in optical quality due to all of the advancements in astronomical equipment over the years.
Jack
#21 Billydee
Billydee
Posted 06 December 2013 - 03:46 PM
Jack,
There have been small modifications over the years but all of the Qs have the same general outside look. I think that the first 100 to 200 were the same but minor internal changes were made after that (different mirror maker, prisim and base plate). That makes yours a collectors type scope (much fewer in number than later designs). The mirror in your scope was made by one of the best in the business and I think another mirror maker came after the first 100 to 200 so the optics in yours are probably better than later ones. I think yours is probably worth $500 to $1000 more than a Q made after the first 100 (to a true Q collector).
That does not mean you should not use your Q. That is what they are for and you need to really enjoy it. These ladies enjoy being taken on a date.
Bill
#22 Copernicus1473
Copernicus1473
Posted 06 December 2013 - 04:10 PM
Bill,
I never would have thought that about the mirror and optics being better. I do plan on using it and can't wait. It seems like a good compliment to my 8-inch Dob. It probably could use a cleaning so I will contact Questar ansd send it to them in January. Usually I don't get a chance to do much viewing in January (I live in New Hampshire) due to the cold. Though those clear cold nights are very tempting as long as I dress appropriately. There are also no bugs :lol:
Best Regards,
Jack
#23 NeilR
NeilR
Posted 06 December 2013 - 08:07 PM
Congratulations on finding that early Q!
The early scopes have been discussed extensively over the years. It is generally thought that the optics for very roughly the first 900-1000 were made by Cave. Since then the optics have been made by Cumberland Optics. It is further generally thought that modern optics are better than earlier Q's, and that is true of modern Q's verses, say, 1960s Q's.
You should be aware that if you send it in for a full cleaning that Questar will replace any parts, including cosmetic parts, that they deem necessary. For example, the Logo disks, especially the one at the center of the RA drum, may be replaced as a general rule since removing them may damage them. Those logo disks have changed over the years, and old disks are very distinctive.
Did you get the old English Leather case? That case is very distinctive, the hinge of the front door being integral to the leather. Original units with good working hinges are rare, just due to the ravages of time and the tendency of leather to crack.
People that buy very old Q's, like yours, often will not have them "routinely serviced" because it starts you down a path of modernization that conflicts with the idea of keeping it truly "unmolested" and true to the era PURELY for collectable reasons. From a functional point of view, the factory will restore the unit to modern performance standards, and that is their objective if you don't specifically talk to them about preserving things.
You may not care at all about collectability, but others may, and that scope has collectable value. It has always seemed to me that it does not make a lot of sense to buy a very early Q purely for functional use, for the reasons I am struggling to explain here :grin:
If you were to effectively "swap" it, in some way, with a more modern scope it may cost less in the long run (depending on what happens on the next service of either scope) and you don't have to struggle through the collectable issue.
I am NOT suggesting you sell it and do what I just suggested. I am trying to give you a feel for the choices that seem to be inevitably made when a service is done, and what might make the most sense purely from a functional point of view.
And, no, I don't have the spare bagels to buy your Q, although if I did I would. And never service it unless absolutely necessary, and after careful consultation with the factory as to exactly what they plan to do with it.
The early Q's, the collectable aspects, and "renovation issues" have been discussed extensively over the years in the yahoo group list. You might start there with a search for "Cave" or other search terms. ANd, of course, start here, but I know some interesting stuff has been posted over the years on the Yahoo group.
#24 NeilR
NeilR
Posted 06 December 2013 - 08:16 PM
I also meant to add to the above that all those collectable issues may be a moot point since the serial number seems to imply it has already been renovated. So your first course of action would be to contact Questar and see what they did.
It is my understanding that if the serial number was changed, then the base plate was replaced, and it would have been replaced with a metal bottom plate. The earliest Q's had a synthane base, and yours probably did too.
The Yahoo group archives includes a spreadsheet file listing a number of differences between units of various eras, according to data and serial numbers provided by members. It is a very good resource in order to start to understand the changes made over the years. For example, which units had that synthane base (and synthane tube too).
#25 Copernicus1473
Copernicus1473
Posted 07 December 2013 - 07:33 AM
Neil,
Thank you for the information and PM. I will need to do some additonal checking on this Q. I had been looking for a Q for about 6 months to use as a "grab n go." I really liked the portability aspect and the great ruputation and optics.
I saw an ad and contacted the seller immediately. I was probably very lucky because I was local and they did not want to ship it. Being a novice to Q, I didn't think or know to ask about the serial number. The original owner of the scope was Cyrus Fernald of Wilton, Maine. I think that I will need to do some more research on this Q. This is really fascinating and I think finding out more about this Q is going to be great learning experience. I will also check out the other location that you mentioned.
Best Regards,
Jack
