Domes and Snow
25 replies to this topic
#1 my-spot
my-spot
  • Loc: South East Michigan
Posted 01 December 2013 - 09:47 AM
I'm planning to build a remote observatory a couple hours from my home and I'm about 80% settled on a dome. However, I obviously will not be able to clear the snow off. I can just imagine dumping a pile of snow on the scope when opening the slot.
:foreheadslap:
Any Thoughts?
#2 John Fitzgerald
John Fitzgerald
    In Focus
  • Loc: AR ..on the minus side of +36 deg
Posted 01 December 2013 - 10:20 AM
Generally, it will slide right off and not accumulate, if the dome is made of a smooth material. We had one substantial snow since I got the dome and it only stuck a little at the transition area between dome and track, and right around the top. Depends a lot on the design.
#3 rimcrazy
rimcrazy
  • Loc: Overgaard, AZ
Posted 01 December 2013 - 02:09 PM
It always melts on the south side and if need be you just rotate 180 to get the other side. Not an issue.
#4 Mirzam
Mirzam
  • Loc: Lovettsville, VA
Posted 01 December 2013 - 05:52 PM
If you can heat the interior it will melt off faster.
JimC
#5 T1R2
T1R2
  • Loc: NeverWhere, 35*N
Posted 01 December 2013 - 05:57 PM
a push broom will also help if you get a step ladder, just pull it right off
#6 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 01 December 2013 - 08:58 PM
Get one of those snow rakes for the roof that comes with an extension pole.
Michael
#7 JJK
JJK
Posted 01 December 2013 - 09:26 PM
Michael
If by remote, the OPer meant imaging via the internet from his home several hours away, a snow rake won't work.
#8 Galaxyhunter
Galaxyhunter
  • Loc: Northern Illinois
Posted 01 December 2013 - 10:30 PM
Michael
Not unless it had a reeeeeeeeally long handle :lol:
#9 JJK
JJK
Posted 01 December 2013 - 10:52 PM
Michael
Well, of course.
#10 tim57064
tim57064
  • Loc: Southeast South Dakota,USA
Posted 02 December 2013 - 09:42 AM
+1 :lol:
#11 Aquarist
Aquarist
  • Loc: Illinois
Posted 02 December 2013 - 11:02 AM
JimC
My thinking as well. I am considering adding a network controlled heater to turn on when it snows and turn off remotely.
#12 MHamburg
MHamburg
Posted 02 December 2013 - 07:53 PM
Duh! But of course.
Michael :foreheadslap:
#13 my-spot
my-spot
Posted 02 December 2013 - 11:32 PM
The good news is a plan to trial everything for a year or so in the back yard before moving it all to the dark site. Hopefully I'll be able to work out if snow is an issue or not.
#14 John P
John P
  • Loc: Irondequoit, NY USA
Posted 03 December 2013 - 06:47 AM
My clamshell has a great gel coat and snow slides off very quickly. I suspect as it's a remote operation type, you could rotate it a bit and allow the motion to help get the snow off. I open each half of the clam shell separately to accomplish the same thing.
#15 TCW
TCW
Posted 12 December 2013 - 12:13 AM
Might I suggest a camera pointed at the outside of the dome so you can check the snow before opening? Other than that a good heater would melt the snow from the inside if that is an option.
#16 TCW
TCW
Posted 12 December 2013 - 12:18 AM
Put a really big motor on the dome rotation and crank that sucker up to a couple of hundred RPM and the snow will be history! :dabomb: :dabomb:
#17 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 12 December 2013 - 09:51 AM
While not appropriate for the OPs requirements (not a dome design that can be easily automated for remote control) my POD does illustrate what happens with dome material that snow doesn't easily stick to.
This is on a relatively warm morning (just above freezing) after an overnight snowfall.
The PacMan Observatory ... :lol:
#18 rodney
rodney
    Vendor - Explora Dome
  • Loc: Asbury, NJ
Posted 12 December 2013 - 10:27 AM
Frank,
Great posts from the others. The IP camera on the building is a terrific idea. Since you will be automated, turning the dome remotely will help in getting the snow off easily enough. As a dome vendor I can attest to the durability of the products on the market. If you keep your slotted opening facing in a Southward direction most of the problem will be eliminated by sunlight.
As few years back a dome owner installed a 12 volt heat strip on each side of his shutter opening. Similar to Dew Strips and such. I can not find his article, but he used heating elements off mirrors on pickup trucks. Disassembled the mirror and used the elements. I do know he was not as remote as you plan to be, and he did have some form of controller. He ran everything over a Tight VNC connection. And he lived in Northern Canada.
#19 rlandsboro
rlandsboro
  • Loc: Scottsdale, AZ. USA
Posted 16 December 2013 - 10:45 PM
There is a company called Warmquest in Utah that specializes in snowmelt systems for roofs, floors, driveways, etc. Their heat mesh products have a controller that is activated by both temperature and moisture sensors. So the weather has to be below freezing and have precipitation before it turns on. They might sell you the controller and you might be able to let it turn on a heater inside the dome.
There are other companies also. Thier common focus is "snowmelt".
#20 tadpoletoo
tadpoletoo
  • Loc: NW Michigan
Posted 17 December 2013 - 02:48 PM
Hi Frank, Here is my Sirius dome located about 250 miles NW of you. This is about a weeks worth. Depending on temperature and wind speed sometimes it will not build up quite so much. We have not had a clear night in quite some time and thats the way it is in a lake effect area, but the rest of the year I like it! Dave
#21 tim57064
tim57064
Posted 18 December 2013 - 12:46 AM
Those wasps must be hibernating by now huh? LOL :)
#22 tadpoletoo
tadpoletoo
  • Loc: NW Michigan
Posted 18 December 2013 - 06:48 AM
Yes they are but those pesky snow fleas look like they will be around for a while. At least they don't bite or sting!
#23 my-spot
my-spot
Posted 18 December 2013 - 09:39 PM
I have done some imaging not too far from you in a beach parking lot in SBNL. Nice-n-dark...
:question:
Now my real question is, what happens if you try to open the slot with all of that snow up there?
#24 tadpoletoo
tadpoletoo
  • Loc: NW Michigan
Posted 19 December 2013 - 08:06 AM
Hi Frank, Our club GTAS holds public outreach programs at that very beach several times a year. On my dome when the snow falls , it works its way into many places and some of it freezes, so the shutter will not open. To remedy this I broom it off and clean out the track and manually rotate it so the sun , if it happens to shine before the next snowfall, can melt it enough to be useful. My experience is that this is not the place for seeing the night sky during the winter months, but the rest of the year more than makes up for it! Dave
#25 CarsRfun2
CarsRfun2
  • Loc: Ohio
Posted 25 December 2013 - 10:53 AM
You think you have problems?
