First semi-permanent observatory Rubbermaid Shed
15 replies to this topic
#1 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 17 December 2013 - 10:32 AM
Hello,
Spent a couple of days making a custom equatorial wedge for my Nexstar 11 GPS and trying to attach wheels to it to make it portable when I had the idea of converting the plastic Rubbermaid shed that I already had in my backyard into an observatory. I have seen others doing the same thing and had some metal heavy duty hinges laying around so I made this observatory in my backyard in one day. I can tell this is going to save A LOT of time with setup and polar aligning. Since setting up the observatory, I only spend 1-2 minutes setting up my laptop instead of a minimum 30 minute setup and tear down. That means more imaging time. I successfully autoguided my first 10 minute sub with this with an off-axis guider. It was amazing how easy and nice it is, without having to polar align it everytime. And it cuts down on wind A LOT! I am very happy and excited about this.
This is a fliptop type observatory. I use a fabricated rod to move the roof. It takes about 15 seconds.
#2 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 17 December 2013 - 10:33 AM
Nice view of sky, unfortunately I had to place the shed in the middle of the backyard because I have a large OAK tree that blocks the eastern part of my sky. I hate to cut it down, but my astrophotography desires beg of it.
#3 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 17 December 2013 - 10:35 AM
Nexstar 11 GPS clears the roof by 1-2 inches in the stowed position.
#4 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 17 December 2013 - 10:36 AM
Fully closed up.
#5 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 17 December 2013 - 10:38 AM
Used stellarium and my Telrad to find true north in my telescope to align my wedge. BTW the wedge is a strong steel junction box with a hinge and some 2x4s for bracing. Its actually sturdy! Although my tripod is probably the weakest link in the setup. However because the shed blocks most of the wind, I really don't have to worry about stability too much.
#6 rlandsboro
rlandsboro
  • Loc: Scottsdale, AZ. USA
Posted 17 December 2013 - 10:40 AM
Nice!
I like trees, too - I hate it when I cut them down. I feel better if I plant 2 new for every 1 taken down. Then they can be placed in the areas you want or need them.
#7 coinboy1
coinboy1
  • Loc: Tulsa, OK
Posted 17 December 2013 - 10:43 AM
First autoguided image in observatory. 10 minute sub. ISO 100 due to light pollution. Slightly out of focus. But stars are ROUND! :) I need to get filters...
#8 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 17 December 2013 - 11:17 AM
Congratulations on a great idea for an observatory! Looks like this setup will serve you very well! Thanks for sharing with us.
#9 DeanS
DeanS
  • Loc: Central Kentucky
Posted 17 December 2013 - 12:53 PM
Cool set up. Make sure you strap it down somehow. Warren Keller could tell you why from his past experience.
Dean
#10 lambermo
lambermo
  • Loc: .nl
Posted 17 December 2013 - 03:22 PM
how do you intend to keep moisture out ? (that setup would rust in my climate in a few weeks)
#11 shawnhar
shawnhar
  • Loc: Knoxville, TN
Posted 17 December 2013 - 05:11 PM
Sweet, I have something like this, except my shed slides away.
That looks like a tight fit!
#12 LoveChina61
LoveChina61
Posted 17 December 2013 - 08:22 PM
...my shed slides away.
Shawn, I can't get a good feel for how your shed slides away. I would like to do something like this in the future. Can you share some pictures? I can't see any tracks or wheels that would enable you to slide it away conveniently and would be curious to learn how you hooked everything up and still kept it secure.
#13 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 17 December 2013 - 09:39 PM
There was another guy who bolted tracks to his concrete from Dallas. There are tons of options, Mike!
#14 shawnhar
shawnhar
Posted 17 December 2013 - 11:17 PM
Sure!
I cut a slot in the bottom of the shed floor, then cut a piece from that so I can replace it when I put the shed back, only the square for the pier remains as a gap in the floor.
I had planned to put wheels under it but I just open the doors and drag it backwards, slides pretty easy on the decking. It's made it through 60mph winds but I keep a 170 ah deep cycle battery on the floor, I take that out, slide the shed away, put back at end of night, you can't move it with the battery in there, lol.
With slot
Piece replaced
Slid away
Upgrades!
I still haven't replaced that stupid wooden pier plate, it was made from a scrap piece of PT 2x6 and has been on there for like 18 months, lol.
I do notice moisture issues, not from rain but in the winter frost forms on the underside of the roof and drips when the sun warms it up. I keep a heavy towel over the scope for that reason. Sometimes summer humidity can cause moisture as well but I haven't seen any rusting or corrosion issues. (knocks on wood)
#15 Starman27
Starman27
  • Loc: Illinois, Iowa
Posted 18 December 2013 - 09:50 AM
Well done. You may want to also brace the rear wall with a 2X4.
#16 LoveChina61
LoveChina61
Posted 18 December 2013 - 10:43 AM
Great! Thanks for sharing, Shawn. I will try to do something just like this in the future. Easier than building something from scratch yet very effective. Thanks!
