How much difference do more subs make?
71 replies to this topic
#26 mpgxsvcd
mpgxsvcd
  • Loc: Raleigh, North Carolina
Posted 23 December 2013 - 09:49 AM
Yes - I don't count number fo subframes but the total integration times.
Put it this way, the Gendler's, Croman's and Hallas's of this world do 20 to 30 hours integration. A few DSLR folks here have run up to 20 hours with stunning results.
Personally I find things look very good after 10 hours worth.
Your wasting your time then. Check the equations for stacking. They have nothing to do with total time. Just shear number of subs. However, at some point even adding subs won't help enough.
I believe that point is somewhere around 60 subs for High ISO subs(ISO 6400) and lower(Perhaps 32 subs or less) for lower ISO subs for my camera. That is just my observation though. The camera makes a huge difference in whether that observation is accurate or not.
#27 mpgxsvcd
mpgxsvcd
Posted 23 December 2013 - 10:24 AM
I am very interested in this 'minimalism' discussion. I will be travelling to Chile in March for 11 nights at Atacama Lodge. I plan to devote about 5 of the nights to astrophotography through an AT65EDQ/Canon60Da combination. (The other nights will be visual observing with the 24" dob while shooting wide-angle stills and time-lapses..)
There are waaaay more targets than I will have time for so I will have to compromise on S/N ratio by shooting some bare minimum of subs, flats, darks etc. ISO 1600 works well with my camera...
The big question is: How many subs is the minimum acceptable number? And how long should they be? Which would be better, e.g., 2x6min, 3x4min, 4x3min, 6x2min or 12x1min?
I have a 'wish list' of about 25 targets with the AT65 so, with my planned schedule, I'll do about 5 targets a night -- about 1.5 hours maximum per target. Whatever shall I do?
Dave
I have been interested in this solely because of the Messier Marathon. I want to not only capture all ~110 objects. I want to stack them as well.
From my dark site I can get at least 1 minute ISO 6400 subs at F4.0 before blowing out the sky. That is actually a lot of exposure. If I can take at least 60 of those images with good tracking I know I can get a fantastic image once I figure out my collimation issue.
However, the fact is that at most I am only going to be able to spend about 4-5 minutes on each object. 4 subs is not great but it does help.
For the brighter objects like M42, M31, M45 and the clusters I can definitely knock the time down to 30, 15 or even 8 seconds per sub to retain the brightest elements of those objects. That might give me a few extra minutes on the darkest objects.
My hope is that next spring I can stack at least 4 subs for all of the Messier objects plus the Horse Head in a single night without guiding. To me that seems like an admirable task. I only got through stacking 55 objects last year before my mount failed do to a collision with the tripod leg. It was well below freezing and I was not dressed appropriately so I had to give up then.
I have the warm clothes now and I am closer on figuring out the collimation so I think it will work this year. I don't expect perfect images. However, I do think this will give me nice results of an awful lot of objects for a single night.
#28 Footbag
Footbag
  • Loc: Scranton, PA
Posted 23 December 2013 - 10:47 AM
You do need enough subs that average and median stacking methods begin to work properly. I've found this to be tough with narrowband where you have fewer longer subs.
Once you cross that threahold, assuming properly exposed subs; you can treat a sub as an interval of time.
Keep in mind that we are doing this for aethetic photographs. If 5 hours of subs didn't reduce the noise to visually acceptable levels, then quadrupling the exposure is really the only option.
Is it diminishing returns, or diminishing motivation? At some point, its a lot of work for a gain you may not be able to see.
#29 mpgxsvcd
mpgxsvcd
Posted 23 December 2013 - 11:33 AM
Equations for stacking give you only part of what going on. By your reconing then we should all be shooting 1000's of 1 second exposures to get the best results ?? Makes sense that if you shoot 0 second exposures then you get no noise ;)
I never said that. Stacking more subs will reduce the noise. However, it reduces the noise less and less as you increase the number of subs. At some point you will fail to see a difference no matter how many subs you add.
How long you image for doesn't change the way the stacking process works. If you have less noise to begin with of course you will end up with less noise in the end if you stack the same number of frames. However, the ratio of original noise to final noise will be be the exact same for either scenario if you take the exact same number of subs.
Again, Imaging time has absolutely nothing to do with how the stacking process works. It is simply a way to increase the signal to noise after the images have already been taken. There are many things that will affect the signal to noise while you are taking the image. Stacking is the only efficient way to change it after you have already taken the images.
#30 Tonk
Tonk
  • Loc: Leeds, UK, 54N
Posted 23 December 2013 - 11:42 AM
Have you read this summary
http://www.astropix....TROP/SIGNAL.HTM
Do so and then tell me I'm wasting my time ;)
You have only discussed half the story - noise reduction. So far you have neglected considering collecting sufficient signal - thats a function of total integration time.
If we are not talking about very bright subjects (where lack of signal is not an issue) but the vast range of DSOs such as faint nebula and galaxies then total integration time gets the upper hand. Put it into practice and this becomes very evident. Targets such as ngc 7023 just get better with the amount time you put in capturing photons. On the otherhand bright targets such as M13 don't need this level of effort at all unless you are seeking the faint periphery stars (which will require HDR techniques to balance the core with faint edges in your final image)
#31 mpgxsvcd
mpgxsvcd
Posted 23 December 2013 - 12:08 PM
All I have said is that adding subs of the same exposure duration past the point of diminishing returns will not help you. That says nothing about adding more exposure duration to each sub. However, the standard assumption is that you are using the maximum exposure for your given focal ratio and sky limits. If you aren't doing that then do so by all means. That won't affect how your subs do when stacking though.
You can also use filters to adjust the signal just like you can increase the exposure of each sub. However, that too does not affect how DSS increases the signal to noise ratio.
In my opinion 60 subs is sufficient even with ISOs as high as ISO 6400. In addition the benefit from using longer and longer exposures with lower ISO really decreases after about 4 minutes with my camera. I will post the images for that test when I get the chance. Your camera my vary from mine but I don't think it will vary much unless you are cooling it actively.
At 4 minute subs I believe that 4 hours is the most you should ever spend on an object with my particular camera. I believe that after that you are in fact just wasting your time.
#32 Footbag
Footbag
  • Loc: Scranton, PA
Posted 23 December 2013 - 12:18 PM
This ignores the object brightness. That is a mistake because as objects get dimmer, more exposure is required to improve the SNR.
Tonk's example of the iris nebula is a good one. I have probably 15 hrs on that object and very little to show for it.
#33 tazer
tazer
  • Loc: Central North Carolina
Posted 23 December 2013 - 11:16 PM
I had the same question myself and created an animated GIF of a high ISO stacking comparison at one point. Each sub-exposure was for 30s @ ISO 3200:
http://www.astrobin.com/full/32323/0/
It's a 17MB GIF so I decided not to embed the image.
#34 whwang
whwang
Posted 24 December 2013 - 08:20 AM
There will be no "point of diminishing returns" if you calibrate (bias, dark, flat) your images perfectly. You can essentially get as many subs as you like, and continuously go deeper.
The only thing is, the image quality (S/N) will go with square root of the number of subs. How much you can improve 1 sub by taking another 1, is the same as how much you can improve 60 subs by taking another 60. If I have 1 sub in hand, usually I would not hesitate to add one more. If I have 60 subs in hand, on the other hand, I would think very hard whether or not to take another 60 more. (I think this applies to most of us.) That's a mental effect, however, not a scientific one.
#35 tazer
tazer
Posted 24 December 2013 - 09:33 AM
I think "point of diminishing return" should actually be "point of diminishing return on investment of time" where 'return' is whatever we're trying to glean from a stack. Most often this is an aesthetic return. Is it worth spending 5 hours in the field to double your SNR 3 times? For me it is. Is it worth spending an additional 80 hours in the field to double it two more times? For me it isn't, as the net gains won't be that apparent in my stacked image (based on my scope/imaging camera/computer monitor/etc.)
#36 Steve OK
Steve OK
  • Loc: OKC, OK
Posted 24 December 2013 - 02:11 PM
Well said. Stacking the first 100 subs gives a 10x increase in S/N, while the next 100 subs gives an additional 1.4x increase in S/N. As Whwang points out, all additional subs lead to greater S/N, but they do so at a decreasing rate.
Steve
#37 rkayakr
rkayakr
  • Loc: Northeast Ohio
Posted 24 December 2013 - 02:21 PM
Dave
You can shoot the darks and flats at another time and devote your time in Chile to lights.
Enjoy
Bob
#38 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 25 December 2013 - 12:29 PM
Here is my take on the subject of diminishing returns. I agree with Samir and Wei-Hao.
I had just posted this to another similar question and thought it would be appropriate here also.
Some people argue that you reach a point of diminishing returns, but I don't think there is ever a point where more subs hurt.
Personally, I don't even agree with the point of diminishing returns philosophy. More photons are always going to give you a better signal-to-noise ratio because the signal can only come from the photons, and the only way to collect more photons is by collecting more subs.
In the April 2012 issue of Astronomy Magazine, Tony Hallas argued that you reach an asymptotic boundary at about 25 frames and that shooting more frames was basically a waste of time.
But this is not true. He even mentions that the signal-to-noise ratio improves with the square root of the total number of frames, but then seems to ignore it.
For example 4 frames will give you twice the s/n of 1 frame.
Likewise, 9 frames will give you 3x.
16 frames will give you 4x.
25 frames will give you 5x.
36 frames will give you 6x.
So going from 25 to 36 frames you have needed about 50 percent more total exposure time, buy your s/ has only gone up 20 percent.
Still, it has gone up.
If you follow the logic of 25 frames as a practical limit, you would never want to attempt any deep-sky objects from light polluted areas, yet there are plenty of people doing exactly that.
Look at it like this... 25 frames is 5x better than 1 frame. But, 100 frames is 10x better than one frame, and twice as good as 25 frames.
It certainly would be nice if the improvement was linear, but you still get an improvement by shooting as many frames as you can.
Now, you won't see that much improvement with 26 frames vs 25 frames. But you certainly will with 100 vs 25. The s/n will be twice as good. Is that "worth it?" Only the individual photographer can answer what his/her own level of acceptable quality is.
And this is especially important under light-polluted skies because an individual sub exposure will be limited in duration. So you will need a "hella lotta" (scientific term) subs under those conditions.
I have a shot of M27 from my suburban driveway that is a stack of 90 one-minute exposures at f/8 at ISO 800. And 90 frames certainly was not too many.
Jerry
#39 tazer
tazer
Posted 25 December 2013 - 07:50 PM
I don't think more subs ever hurt, rather the contribution of each successive sub to the resulting stack diminishes.
As I understand it, the primary purpose of stacking is to eliminate noise. To increase signal you take longer subs.
And 400 is twice as good at 100, but that's a huge step for the same increase in SNR. Ultimately you want to get to the point where you can stretch your image aggressively enough to bring out the faintest signal. Any further reduction of noise won't be detectable in the resulting image.
But I think that's the essence of diminishing returns. You invest time to increase SNR. While your time investment remains constant, the rate of return diminishes.
#40 whwang
whwang
Posted 25 December 2013 - 10:21 PM
We should keep in mind that the most important source of noise is signal itself, in deep-sky imaging.
(This assumes that each sub is long enough so the readout noise of the camera becomes negligible.)
Photons carry noise with them. The amount of noise they carry is the square-root of the number
of photons. The more photons we collect, the stronger noise we get. However, since the noise
is the square-root of photons, the S/N is then number of photons divided by the square-root of the
same number. In other words, S/N improves as we collect more photons. This is exactly why we
want longer total integration time, and also exactly why we want more subs. They are the same thing.
Wei-Hao
#41 dmilligan
dmilligan
Posted 25 December 2013 - 11:00 PM
Stacking does not reduce noise, it increases noise - for a given total integration time. Stacking simply allows a longer effective total integration time when single exposure time is limited by some other factor (tracking, LP, etc). It's the longer effective integration time that reduces noise, not the stacking. If you take a single exposure of some given time and compare it to a stack of some N > 1 sub-exposures with the equivalent total integration time, the single frame will win in terms of SNR.
If you understand what stacking actually is mathematically you will understand why. Imaging is basically just counting photons. As time passes, photons (actually photoelectrons) accumulate on the sensor, at some point we end the exposure, and convert the photoelectrons into a digital number that is related to the number the photons that landed on the pixel during that time (plus some amount of error due to the electronics). Mathematically this accumulation is simply addition. We add up all the photons that land and end up with a total. Stacking is the same thing, simply addition. We add up all the counts in each subframe to come up with a total (then we normalize it to some range, usually 0 to 1, but that's beside the point). The reason that stacking works is that it is the exact same process that is happening in the physical realm (photons accumulating, i.e. addition), in the digital realm (addition).
The problem is that when we stack we add in the digital realm, so there is repeated quantization and read errors (i.e. sensor read noise) as well as rounding errors in the mathematical computation (though this is usually negligible). When we simply take a longer single exposure, the photons 'add' in the physical realm and we only get read and quantization error 1 time. Using big-o notation we would say that read noise grows at O(n) when we stack. For a single exposure the read noise is simply O(1). If the total exposure time is the same, the inherent photon noise (or shot noise) will also be the same. Photon noise diminishes with time at a rate O(sqrt(t)).
With proper calibration we can eliminate a lot of the read noise, but it is impossible to eliminate all of it. So it may be a small contribution, but it is still linear ( O(n) ). The improvement from more time is sub-linear O(sqrt(t)), and while it will grow a lot faster than the read noise contribution at first, there will be a point at which the increase in read noise catches up and eventually dominates, this is the point of 'diminishing returns'.
So lets say that a single frame exposure time is limited to some value (b/c in reality it always is). To get more time and thus less photon noise, we are forced to use more subs. There will eventually come a point at which the linearly increasing read noise starts to dominate the sub-linearly decreasing photon noise, and adding more subs won't make a lick of difference. Obviously this point is going to depend on many things like sensor performance and temperature, but I imagine that it is quite large for well calibrated images and low temperatures. The only way you could assert that there is never a point of diminishing returns is that if you could show how to build a sensor with absolutely 0 read noise (if you can do this, I would be interested in going into business with you), that's the only way to make the 0(n) term go away.
There is another point of diminishing returns, and that is when we've collected enough photons for even the dimmest part of the image to have such a high photon SNR that noise is not perceivable. It might still be possible to improve SNR, but the noise would be so small that it would not be even distinguishable on something like the 8 bit computer displays we use to view our pretty pictures on (that would be a SNR that is smaller than the number of discrete brightness values or 256:1 which would be about 50dB, and would require collection of 65,536 photons - let's just say: good luck with that - such an image would be *perfectly* noise free, though I'm sure *acceptably* noise free is a lot sooner than that).
#42 Samir Kharusi
Samir Kharusi
  • Loc: Oman
Posted 25 December 2013 - 11:45 PM
The equations involved for SNR are well understood and quoted here. In particular, I would refer to Line 3. You may note that the Read Noise, R, is not multiplied by N, number of subs. Additionally, provided the subs are long enough (20% of BoC Histogram or more), the dominant term in the denominator is the Skyfog signal, Sky. It is overwhelmingly important to make sure that the Skyfog signal in each sub is overwhelmingly larger than the Read Noise, R, otherwise one gets lousy Stacking Efficiency. For dim objects, those very faint tendrils, the signal from the Object itself, Obj, can also be small compared to Sky. Basically, provided the subs are long enough, the dominant term in the denominator is the the Skyfog signal, Sky. Of course the larger Sky, the larger its quantum statistical noise. In brief, there is NO upper limit as to how many subs will improve the SNR, and while the photographer may be happy with a SNR of, say, 30 on the brighter parts of his nebula, the fainter parts may have a SNR of 3 (barely acceptable). That's why some people would say that x hours is sufficient for a bright nebula, but one has to go longer for fainter stuff. IMHO, all nebulae ought to be treated as super faint and dim. They all have very faint tendrils, and it is only the photographer himself who can determine how deep he wishes to go on that object.
In conclusion please note the statement in Line 8. of the referenced URL:
Quote
8. The curve predicted from equation 6 has an asymptote that can be easily calculated as subexposure time approaches infinity. Specifically, as subexposure time approaches infinity, the contribution of R becomes negligible, and this factor can be ignored in determining the asymptote. The equation becomes: SNR asymptote = sqrt[K]*(Obj) / sqrt[(Sky+Obj)]. Thus, in photon noise limited conditions, the SNR is minimally affected by the read noise or subexposure duration (i.e., assuming that the subexposure duration is sufficiently long).
Unquote
If Steve Cannistra has his equations wrong, and they have stood the test of time, I would appreciate hearing where he went wrong. Certainly in the time I spent digesting all this I could not find any faults. But science progresses and what was obvious yesterday may be proven wrong tomorrow.
#43 dmilligan
dmilligan
Posted 26 December 2013 - 01:26 PM
You're quote is for calculating the effect of increasing subexposure time. Not the effect of increasing the number of subs (which is actually doing the opposite, decreasing subexposure time). It also clearly states the equations are 'ignoring the contribution from dark noise'
Obviously, if the subexposure time approaches infinity, the read noise component goes away (that actually agrees with what I said), but that is not at all what we are talking about. We have short limited sub exposure times due to our *BLEEP* equipment (we cannot 'assume the subexposure duration is sufficiently long'). In those situations, read noise is very important.
All this page really asserts is that sky background also puts a limit on the subexposure duration. Which is true and is one of the limitations I stated in my post (simply as 'LP') in addition to many other limitations such as tracking error. But it doesn't have much to do with what we are talking about here.
I would love to see where those equations came from and how he got from step 1 to step 2, but there are no citations or references listed on that page, and he does not derive them himself.
#44 Footbag
Footbag
  • Loc: Scranton, PA
Posted 26 December 2013 - 03:47 PM
I think you are talking about two separate things. The original post is about adding subs to reduce noise. It's not about dividing the total exposure time into as many subs as possible. In that case, yes, more subs would mean more noise.
But, if you are asking how much does an additional [or extra] sub help, SNR increases proportionally to the square root of the number of subs. So, it depends on whether it's your second sub or your hundredth. If it's your second sub, it helps a lot. If it's your hundredth sub, it helps a little.
#45 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 26 December 2013 - 05:42 PM
This is exactly what we are NOT talking about.
We are talking about using subs that are sky-noise limited, not read-noise limited.
Jerry
#46 dmilligan
dmilligan
Posted 26 December 2013 - 11:02 PM
No, SNR increases proportionally to the square root of the amount of time, not the number of subs. These are close, but not the same thing. Adding more subs adds more time, but at a price: read noise. This means that SNR increases almost to the square root of the number of subs, but not quite.
You did agree that more subs for a given amount of total exposure time increases noise:
The reason I brought that up was to prove that adding more subs does not quite improve SNR at the rate of sqrt(N), but by some amount slightly less.
Example:
9min exposure has 3x the SNR of a 1 min exposure
9x1min exposure has slightly more noise than a 9 min exposure.
Therefore if we are limited to 1 min exposures, going from 1 mins to 9 mins by adding 8 more subs (rather than by adding time, since we can't) means we will not improve the SNR by fully 3x, since we already agreed that 9x1min exposure has more noise than a single 9 minute one, therefore we will only improve it by something slightly less than 3x.
Since the contribution of read noise remains the same per sub (and the error keeps compounding the more subs we take), while the advantage of more time decreases per sub the more subs we take:
This means there will be a point of diminishing returns: The effect of photon noise will continue to decrease while the effect of read noise will remain constant, eventually the image will go from being photon noise dominated to read noise dominated in the deepest shadows. No matter how many more subs we add, we won't get rid of the read noise which is now the dominant source of noise, because we can't. Stacking does not eliminate read noise (if it did then 9x1min would have a better SNR than 1x9min, but we already agreed it doesn't).
#47 Samir Kharusi
Samir Kharusi
  • Loc: Oman
Posted 27 December 2013 - 03:23 AM
Cannistra's equations are so straightforward that I never thought he needed to provide references. It's almost like providing a reference to 2+2=4. But of course what is obvious to one person may not be to another. His entire presentation there is aimed at quantifying Stacking Efficiency, basically an answer to your query as to how well One exposure of 9 minutes is replicated by 9 subs of one minute. But I feel that part of it is somewhat above the level of a very basic discussion we had here above. Nevertheless I tried to answer that particular aspect in a separate post here as related to DSLRs. I feel we have flogged this current horse to death. Some people will be happy with shooting a very bright nebulae, like M42, with an integraion time of mere seconds (me too!), others will prefer to go much deeper to capture the fainter tendrils and use an integration time of 20 hours using many different filters. But personally I would still not dare say that the latter wasted his time or that he might as well have stopped at ten hours. Here is a 20 sec integration on M42 (5x4sec):
and a very festive M13 (29x10sec):
A very happy New Year to all, full of dark, still and clear skies!
#48 Footbag
Footbag
  • Loc: Scranton, PA
Posted 27 December 2013 - 10:33 AM
To bring the theory into practice, you are saying that at some point in stacking; read noise becomes the dominant source of noise. Are you suggesting the SNR stops improving at this point? Not just that it follows the curve asymptotically(diminishing returns)?
Nearly everyone that commented in this thread qualified their statements saying "...given a properly exposed image". It is important that you overcome read noise with brute force.
So at what point does read noise become an issue? Given a specific setup, is it the 1,000th sub? 10,000th sub? 1,000,000th sub? Or is it a non-issue, because given a properly exposed image, with enough time, read noise wouldn't be significant? It would've been overcome with the combined signal. In other words, having read noise dominat a short exposure is a bad thing. But having read noise dominate an extremely long exposure is a sign that all of the other noises have been removed, and you probably have a very nice image at that point.
Also, if we use dark frames, we are removing the read noise. Does this further push back the point where the read noise becomes significant?
Also, if we have the read noise within the SNR formula, then why wouldn't a sub be the exact same thing as an interval of time?
#49 tazer
tazer
Posted 27 December 2013 - 11:01 AM
SNR improves by either reducing N via stacking or increasing S by exposing for longer. Mathematically the ratio is the same, but stacking discards S if it's at or below the threshold of N (varies by stacking algorithm of course.) A stack of 20 5-minute subs will retain more S than a stack of 100 1-minute subs.
#50 dmilligan
dmilligan
Posted 27 December 2013 - 01:25 PM
Technically it will be asymptotic. When one term dominates another term doesn't mean that the dominated term suddenly vanishes at a certain point, but it will continue to get smaller and smaller (basically that is the definition of an asymptote).
It depends, I'm not trying to calculate it here, I'm just trying to show that there is such a point, as many ppl have implied that there is not such a point. Surely this point will vary and will depend on quite a number of things: sensor performance, temperature, light pollution, etc. I imagine it is quite large (many hundreds if not thousands of subs) for a decent setup and dark skies. It's also very likely that most ppl will stop well before ever reaching this point, esp. with bright objects, b/c they would have deemed their result sufficiently noise free (Even the extreme guys who take days worth of total integration time).
Most counter arguments have been something like "well this guy's image is 40 hours". But all of those amazing images, while really long, typically have rather reasonable number of subs usually < 100 (per filter of course, when collecting more subs with a different filter, you are collecting a different signal, you don't stack images with different filters anyway, you merge them in different ways, like by assigning them to different color channels). They just have incredibly long sub-exposures (on the order of 30 minutes).
I'm not saying there is a point of diminishing returns on total integration time, I'm saying there's a point of diminishing returns on increasing the number of subs to get more total integration time. At some point the only way to get more useful total integration time is by increasing subexposure length, not by taking more subs.
Yes it does, but it doesn't eliminate it completely, because it is impossible to eliminate read noise completely (we can do a very good job, esp. with modern sensor with really low read noise, but perfection is impossible). So there will still be a point somewhere where it does happen, it may be many hundreds of subs later, but it will surely happen.
If a sub were exactly the same as an interval of time, we could divide a given total integration time into as many subs as we wanted and never loose any quality -> I could take many thousands of 1/10 sec subs and achieve the same result as an equivalent single exposure. Clearly I can't do that. That is the proof that more subs is not exactly the same as more integration time. It's close, but it's not exactly, and the difference is important, the difference is what puts an upper bound on the number of subs.
