AVX mount RA clutch lever
7 replies to this topic
#1 cruling
cruling
  • Loc: Jersey City, NJ
Posted 25 December 2013 - 12:57 AM
i just got a AVX mount, the RA axis could not lock very well.
when i tighten the RA clutch lever really hard, i can still turn the RA axis with my bare hands, not very easily, i mean when i grab the CW shaft and push it a little harder, i can still turn it.
i remember my CG5 doesn't behave like this, when i tighten the clutch lever, i cannot turn that axis at all.
is there anything wrong with the mount?
Fan
#2 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 25 December 2013 - 01:02 AM
Remove the screw and the lever and "re-clock" (rotate) it so that you have more travel in the "Lock" position.
Stan
#3 cruling
cruling
Posted 25 December 2013 - 01:24 AM
Hi Stan, i have done that, it's didn't work.
i mean i have tighten the clutch lever really hard, it won't be any more tighter unless i change to a bigger lever. then if i grab the CW shaft at the middle, i can still turn the axis.
#4 mistyridge
mistyridge
  • Loc: Loomis, CA
Posted 25 December 2013 - 01:36 AM
Remove ths lever and screw out the clutch bolt. you will find a black derlin plug on the tip. Clean the grease of the plug and reinstll the plug and bolt. The clutch should provide enough friction now.
#5 RTLR 12
RTLR 12
Posted 25 December 2013 - 02:51 AM
I had to go to the longer ADM clutch levers on my CGEMs in order to get a good lock on the clutches.
Stan
#6 cruling
cruling
Posted 25 December 2013 - 12:09 PM
Hi Mike, i tried clean the grease on the plug, it didn't help, maybe some grease got onto the surface of the barrel inside the housing.
have to think of a way to clean it :question:
#7 cruling
cruling
Posted 25 December 2013 - 12:27 PM
Stan
Hi Stan, i try to remove the lever on my CG5, it's a little bigger, but something bad just happened, see here: http://www.cloudynig...6272113/page...
#8 dragonslayer1
dragonslayer1
  • Loc: SLC, UT
Posted 25 December 2013 - 12:39 PM
is the square block and large threaded piece all one piece? or are they 2 pieces held together by the piece of remaining broken screw? Kasey
