Lambda Orionis
5 replies to this topic
#1 Pete-LH
Pete-LH
  • Loc: Wilmington, DE
Posted 01 January 2014 - 10:21 AM
This is a Sketch from last Friday night of Lambda Orionis and the asterism (Lambda Orionis Cluster or Collinder 69) where it is located (Orion's Head). I recently acquired a used Borg 60ED which I am trying out as both a finder for the C8 and a wide field view. Here I used an 11mm Nagler with the 60Ed giving a 32X/2.4deg field of view. With a 3.5mm Nagler at 100X/0.8 deg Lambda Orionis was resolved with the major star a very nice disc with one concentric ring which overlapped at the edge of the companion. I should have tried sketching that as well. I need to work on my magnitudes-in the 2.4 deg view Lambda, Phi 1 and Phi 2;1 should stand out a bit more from the rest as well as the three stars in a slight arc between Lambda and Phi 1.
Not a difficult split except it was fairly cool and the atmosphere was not so stable at first (or my C8 had not stabilized). But eventually had a fairly good view.
There is a pretty good description of Lamda Orionis in Wiki-pedia.
  • AllanDystrup likes this
#2 kenrenard
kenrenard
  • Loc: Dunmore, PA
Posted 01 January 2014 - 12:53 PM
Nice wide field sketch. You have to love those little refractors.
Ken
#3 PeterDob
PeterDob
Posted 01 January 2014 - 03:21 PM
Very nicely done, Pete! The comparison is very interesting.
Peter
#4 Chopin
Chopin
    Canis Insanus
  • Loc: In the doghouse.
Posted 01 January 2014 - 06:34 PM
Still a great observation, Pete! Even if you feel the split wasn't very challenging. I love the related sketches at varying magnifications.
#5 Pete-LH
Pete-LH
Posted 01 January 2014 - 11:16 PM
Jason, That's what I've been aiming at for a visual setup-A finder that can also be a good wide field visual tool as well when sketching. I really like this set-up of the C8 with a 60-70mm light telescope.
#6 niteskystargazer
Posted 02 January 2014 - 09:30 PM
Pete,
Nice sketch of Lambda Orionis :).
