NGC 5005 or 5033?
3 replies to this topic
#1 Usquebae
Usquebae
  • Loc: 43° N, 73° W
Posted 07 January 2014 - 10:23 AM
I stumbled upon something fuzzy in Canes Venatici last night that must have been either NGC 5005 or 5033. I was zooming between 20x and 33x in an ST80. Any guesses as to which one I saw? Is it possible I was detecting hints of gray from both and interpreting as one object?
#2 npc
npc
Posted 07 January 2014 - 04:15 PM
I find 5005 is much easier to spot, so if you only saw one, I'd guess that was it, but I don't know how much you scanned around the area or what your field of view is. It seems *possible* to me that that you were looking at 5033 and 5005 was out of your FOV, but that's not the way I'd bet.
These two objects are about half a degree apart in the sky, so I highly doubt you're interpreting light from both of them as one object.
#3 Philler
Philler
  • Loc: Olathe, Ks
Posted 07 January 2014 - 11:54 PM
Can't say for sure. I have viewed both galaxies years ago. Canis Ven is a great place to stumble across some nice galaxies and also in UMa and Com.
#4 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 09 January 2014 - 05:57 PM
They're not so close together you'd see them as one object.
I, too, suspect you saw 5005, and here's why:
The brightness of both is similar: 5005 is m10.6 and 5033 is m10.8
But. the light in both is not at all uniformly distributed, so the surface brightness of 5005 is a bright m11.1, while the SB of 5033 is a much fainter m13.4
That says that the much higher brightness of the area of NGC5005 is far more likely to be seen easily in an ST80.
