Jupiter f25 RGB Flea3 Avg Seeing 1/10/14
19 replies to this topic
#1 sfugardi
sfugardi
  • Loc: CT
Posted 10 January 2014 - 01:06 AM
I went back to the Flea3 tonight under 3/5 seeing and haze, using my 2.5x powermate a couple hours before transit trying to beat the incoming clouds. The last 3 avi sets derotated & combined in WJ. Colors seem more vibrant than my prior tries with the ASI120MM, this time with no extra saturation added. The image size is a lot more flexible with the Flea enabling various barlow / extension combinations. It would be nice to catch good seeing with this massive 46+" disk.
Steve
#2 sfugardi
sfugardi
  • Loc: CT
Posted 10 January 2014 - 06:31 AM
In an effort to pull out more detail, I did make 2 IR-685 runs at the end of this session. The filter "darkness" required settings in between G & B to match histograms vs the RGBs. The IR channel appears over sharpened using the same Reg6 settings, so I decided to blend the IR-RGB with RGB, in this case 50/50
Steve
#3 sfugardi
sfugardi
  • Loc: CT
Posted 10 January 2014 - 06:33 AM
One final blend, 33% IR-RGB + 67% RGB which seems optimal for this average data set?
Steve
#4 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 10 January 2014 - 09:23 AM
Definitely, that combination nailed it.
#5 DesertRat
DesertRat
  • Loc: Valley of the Sun
Posted 10 January 2014 - 10:16 AM
Good work Steve! That blending really brought out some fine details. Color balance seems really good for that combination, something that is fairly difficult to achieve. Well done! :waytogo:
Glenn
#6 ToxMan
ToxMan
  • Loc: Tucson, Arizona, USA
Posted 10 January 2014 - 10:23 AM
I like the results with the blending. Very nice collection.
#7 sfugardi
sfugardi
  • Loc: CT
Posted 10 January 2014 - 12:16 PM
Paul, Glenn, Paul, Thanks for the compliments! I only took 2 IR runs and should have made a 3rd to be consistent with the 3 RGBs. My logistical issue is that the IR is a screw on filter, not on my wheel so I have to do it at the end. I am considering getting a more gentle IR610 and replacing the L filter on my wheel (since my grand plan for mono deep sky never materialized) but it has to be sent out and with my luck I'd miss the only 5/5 night of the year. I started taking ASI120MM data but after several runs at 0.15" resolution switched back to the Flea at 0.16". With my smallest barlow lens and shortest tube I cannot go incrementally lower with the ASI. I still need to process the ASI data. For marginal seeing, the 33% IR blending seems to help the detail. From now on, I'll end my Jupiter session with 3 IR runs.
Steve
#8 corpusse
corpusse
  • Loc: Mississauga, Ontario, Canada
Posted 10 January 2014 - 12:55 PM
The IR blend is very nice. I still can't get a nice Jupiter. Not even going to bother posting the last one I did. Seeing was better, but also snowing which likely contributed to my poor image.
#9 Baron
Baron
  • Loc: Rome, Italy
Posted 10 January 2014 - 02:26 PM
Steve, good work!
The result with blending is very nice.
#10 mitovka
mitovka
  • Loc: Slovakia, CE
Posted 10 January 2014 - 02:27 PM
That IR really helped a lot!
According to weather forecast I will have 2-3 hours of clear sky on sunday finally, I bet seeing will be rather bad and I will try this idea also.
#11 Kokatha man
Kokatha man
Posted 10 January 2014 - 07:50 PM
Well done Steve! :waytogo: :waytogo:
#12 sfugardi
sfugardi
  • Loc: CT
Posted 10 January 2014 - 07:51 PM
Andrew, Paolo, Michal,Mo, Thanks! What is interesting about the blending in of the IR-RGB data vs RGB only version, is that highlighted details cannot be adequately pulled out with any amount of deconvolutions or sharpening without gaining a ton of noise from the color data alone. Since being able to image in excellent conditions is so rare, I wonder if this IR blending can help the other planets like Mars & Saturn?
Steve
#13 troyt
troyt
  • Loc: Australia
Posted 11 January 2014 - 04:24 AM
Great images and I like your work on the blending!
Troy
#14 John Boudreau
John Boudreau
  • Loc: Saugus, MA
Posted 11 January 2014 - 07:58 AM
While I'm not a fan of blending in near-IR to RGB Jupiter images, you've done probably the best blending near-IR that I've seen here. Looks like a nice data set too. Nice work!
:waytogo:
#15 Mike Phillips
Mike Phillips
  • Loc: Swift Creek, NC - 35.682 N, 78.743°W
Posted 11 January 2014 - 09:57 AM
I have found in the past that mixing Ir into my Jupiter shots resulted in colors off much like your right shot, IR-RGB. I really like what you did and I came up with a similar scheme using Red instead of Ir. I used Red because, as you said, of logistical problems. I've been using the red as a luminosity in PS and then pulling at the curves to bring out the right contrast, then I set the opacity to taste. Right now it's all buried in some photoshop actions that I saved. Which for those PS users if you don't know about you MUST go learn.
Well done, and great find Steve
#16 sfugardi
sfugardi
  • Loc: CT
Posted 11 January 2014 - 11:33 AM
Troy, John, Mike, Thanks for the positive comments! I'm not a fan of blending either but when the seeing is marginal and you stand outside in the freezing cold for 2hrs, you'd like to end up with a decent image so finding a new trick is always desireable. The blending here was done in WJ, not PS. Going 33% R-RGB 67% RGB should work also assuming the R data is as good as IR. The key is to not over do it
Steve
#17 yock1960
yock1960
  • Loc: (Mostly Cloudy) Ohio, USA
Posted 11 January 2014 - 12:51 PM
I like these Steve! I'll never be called a purist and it can be argued all day long about some of the things we do to get images. If done carefully, blending can have excellent results! If it ever clears here, I'm going to have to finally give my ir filter a try!
Steve
#18 sfugardi
sfugardi
  • Loc: CT
Posted 12 January 2014 - 08:39 AM
Steve, thanks! I've tried collecting L data in the past, but it never seem to add quality to my Jupiter or Saturn images. I suspect that the IR742 is too dark for this vs IR685. There's really no harm in collecting a few IR avis and decide later if the data is needed. Good luck with the seeing!
Steve
#19 MADRID SKY
MADRID SKY
  • Loc: Madrid, SPAIN
Posted 12 January 2014 - 10:32 AM
Steve, I like the smoothness of your processing.
Good job. I will keep an eye on you. (We work with similar apertures)
#20 Space Cowboy
Space Cowboy
  • Loc: Cheshire, UK
Posted 12 January 2014 - 01:49 PM
Excellent images Steve! I do wonder if the cmos cams are as effective on Jupiter.
