Jupiter 08/01/2014 from Rome - PREVIEW R CHANNEL -
12 replies to this topic
#1 emadeg
emadeg
Posted 10 January 2014 - 10:37 AM
Hello guys, only one day from my 2014/01/07 last shot on Jupiter here is an other one. I think it's my best R channel....
I have some filters problems so i will post all the single channels , and you can merge your own RGB or LRGB as you like.
Newton 400 "TRAPANER" self build , asi 120mm , barlow 3x , derotation of 5 images from 60 secs @ 60 fps movie.
Here you are:
#2 emadeg
emadeg
Posted 10 January 2014 - 06:59 PM
This is B channel. I have a derotated one , sum of 3 B channel, that is better, but i have to process yet....
22.09 UT.
As you can see, it is not at the level of R channel, so the seeing was good but not too good.
#3 Rankinstudio
Rankinstudio
  • Loc: Southern UT
Posted 10 January 2014 - 08:08 PM
Really nice images there :)
#4 CPellier
CPellier
Posted 11 January 2014 - 07:36 AM
Excellent R ! The B is still very good. The color image will go fine.
#5 emadeg
emadeg
Posted 11 January 2014 - 08:27 AM
You have to see G: it's identical to B. If i don't say you can't understand which is B and which G. I have to mesh some R to G, or take full ir-cut luminance as G. Later i will post G and L....and then we can see what kind of solution is possible....
#6 emadeg
emadeg
Posted 11 January 2014 - 07:12 PM
Here channel G.
#7 emadeg
emadeg
Posted 11 January 2014 - 07:13 PM
....levels a bit different due to different elaboration....but it is identical to B!!
#8 emadeg
emadeg
Posted 11 January 2014 - 07:34 PM
...and this is a bad attempt for a first (L)RGB ...
#9 emadeg
emadeg
Posted 11 January 2014 - 07:37 PM
or at 100% dimension :
#10 emadeg
emadeg
Posted 12 January 2014 - 06:06 AM
Here is an other try may better balanced:
#11 sfugardi
sfugardi
  • Loc: CT
Posted 12 January 2014 - 09:02 AM
Emanuele, top shelf quality! Hands down one of the best posted this year. Resolved details are in high definition. Congradulations on this one and thanks for sharing your work
Steve
#12 Mauro Da Lio
Mauro Da Lio
Posted 12 January 2014 - 12:06 PM
One of the BEST images with one of the CHEAPEST scopes!!!
#13 emadeg
emadeg
Posted 12 January 2014 - 12:07 PM
Last attempt...please be patient ;)
