ETX 125 PE First Solar Image
8 replies to this topic
#1 Martin Hoyle
Martin Hoyle
  • Loc: Birmingham UK
Posted 19 January 2014 - 09:06 AM
Sun Very Low in the Sky from Birmingham & Just Visible for 1/2 Hour
Captured This with Meade Focal Reducer & Celestron LPI
Registaxed some 500 frames Just to try it Out :foreheadslap:
#2 Mak2007
Mak2007
  • Loc: Houston, TX
Posted 19 January 2014 - 11:24 AM
Great! What filter did you use? The Baader solar filter?
#3 Martin Hoyle
Martin Hoyle
Posted 19 January 2014 - 11:36 AM
Orion Full Aperture from Telescope House
#4 Hitech
Hitech
  • Loc: NW PA.
Posted 20 January 2014 - 12:16 AM
I think you don't need 500 stacked frames for the sun! Here's one I took single frame using my ETX-125 and Thousand Oaks filter.
#5 Martin Hoyle
Martin Hoyle
Posted 20 January 2014 - 08:45 AM
I agree, must get a Liveview Canon Camera ASAP Here is a First stack of Jupiter through Birmingham Murk :bawling:
#6 John Brooks
John Brooks
  • Loc: Central Arkansas
Posted 21 January 2014 - 09:12 PM
Martin,
Be careful using the ETX for solar viewing. I used a Thousand Oaks on an early ETX 90 and ruined it. The baffle on the secondary is stuck on with a glue ring which got hot and melted.
After taking a break, I went back out peaked through the eyepiece to a horrible mess. The baffle had slid down the secondary leaving a trail of glue.
I'm not positive but I think the ETX 125 is done the same way.
John
#7 Martin Hoyle
Martin Hoyle
Posted 22 January 2014 - 12:48 AM
John
I cut the aperture down behind the Filter to 1.5 Inches using a piece of card
Martin
#8 John Brooks
John Brooks
Posted 22 January 2014 - 01:03 AM
Martin, the melting glue problem has happened just sitting out in the sun. My ETX 90 did it while I was inside and it wasn't even pointed at the sun. It has been known to happen to the 125s as well. It would be wise to limit the amount of exposure and cover the scope when not in use.
Of course, this time of year it probably won't matter but in the summer it probably will.
#9 *skyguy*
*skyguy*
  • Loc: Western New York
Posted 23 January 2014 - 01:51 AM
Good start on what I'm sure will become a lifelong obsession ... just like all of us! ;)
I mainly use my ETX-125 for visually observing the sun with a Baader solar filter. It performs exceptionally well in this task!
However, it also does a great job when used for imaging the sun. For this, I'll use my DSLR with the Baader filter. I'm always amazed at the ultra sharp and high contrast views this scope can produce. Here's a shot I took of the sun during the Venus transit on June 5, 2012.
