Need help with encoders on G-11
7 replies to this topic
#1 tom77
tom77
Posted 22 January 2014 - 12:29 AM
Hello-
Thanks in advance for any help on this topic.
I purchased a Sky Commander XP4 DSC to use with my Losmandy G-11. The RA and DEC never registered any movement, and it was recommended that I use the cable from Losmandy's DSC kit. I'm waiting to see if anyone has one for sale, but I wanted to see if anyone understands the wiring. Any takers?
The cable supplied with my DSC has 4 color wires (black-yellow-green-red). The S1-512 encoders on my G-11 have 6 pins. What color wires go to what pins in the encoders? I attached a rough sketch.
I'm thinking of replacing the jack on the cable that came with the DSC if I could just get the right color wire-to-pin order. Thanks for the help.
#2 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 22 January 2014 - 12:37 AM
Here's the easy way - $5 ea. from Sky Engineering.
http://www.skyeng.co...ls/P1010106.htm
#3 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 22 January 2014 - 09:05 AM
Cannot help directly, but may be able to add to the information pool.
I use both Losmandy and JMI encoders with JMI's NGC computer. The JMI and Losmandy encoder cables are identical and can be interchanged. Both cables also plug into a NEXUS when working with SkySafari.
I know nothing about the Sky Commander; I am surprised that it uses a wiring protocol different to Losmandy and JMI. Are you sure your encoders work?
#4 Geo.
Geo.
  • Loc: Upstate NY
Posted 22 January 2014 - 11:00 AM
A 6 pin jack is the RS232 port the encoders usually need an 8 pin (RJ-45) jack.
#5 Ed Wiley
Ed Wiley
  • Loc: Texas, USA
Posted 22 January 2014 - 09:07 PM
What kind of encoders do you have on the G11? Mine are Losmandy and I have never had any problem using them with the Sky Commander on either my G11 or my G8.
Ed
#6 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 23 January 2014 - 12:19 AM
+1. You can actually email the Sky Engineering guy and he'll tell you... I was asking the same question a few months ago with my Mi-250 and he's totally willing to help you out.
Chris
#7 tom77
tom77
Posted 23 January 2014 - 06:37 PM
Thanks for the help everyone. I was hoping to rewire/replace the jack that came with my DSC, but this is a bit more complicated than I had imagined. I understand the sequence of the 4 wires (thank you George), but my encoders have 8 contact points (i.e., 8 possible destinations for 4 cables). Should I start in the center ? Left? Right? I will contact the manufacturer and post the solution when I find it. Thanks
#8 tom77
tom77
Posted 23 January 2014 - 06:39 PM
Correction: my encoders have 6 contact points, not 8.
