HOW TO: make your own Video suitable Focal Reducer
14 replies to this topic
#1 Dragon Man
Dragon Man
  • Loc: Snake Valley, Australia
Posted 26 January 2014 - 04:54 AM
A nice easy project to have a play with.
It's cheap, so if it doesn't suit your use, then you haven't lost much :lol:
I made this Video Tutorial of how to make your own Focal Reducer for a 2" Focuser using a Binocular lens and a 1.25" to 2" EP Adaptor. :)
For the Video Tutorial CLICK HERE
Note: If you decide to attempt using a 50mm Binocular lens be aware that 50mm Binocs may actually in some cases have 52mm diameter Primary lenses and can't be used.
Attempt to use a max of 48mm Binocs, they should have a 50mm lens. Any Binocs betweem 32mm and 48mm should be fine.
Also Note that I do state 'Astronomical' Binocs, not those brightly coloured Anti-Glare Horse-racing & nature Binocs.
#2 ccs_hello
ccs_hello
Posted 26 January 2014 - 11:28 AM
Ken,
Great video tutorial.
Just a comment, I do not recommend to use superglue inside the optical system because of the fume. (Remember high school lab or TV CSI shows using superglue fume to lift the finger print :) :)) Or let it dry thoroughly.
For mounting lenses, I'd recommend using an adhesive which is more appropriate for optical use.
Clear Skies!
ccs_hello
#3 ccs_hello
ccs_hello
Posted 26 January 2014 - 11:30 AM
Ken,
Also if you don't mind, I'd like to share this old DIY thread with some pictures.
Clear Skies!
ccs_hello
#4 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 26 January 2014 - 07:24 PM
Ah the old pill bottle mounting setup ... thanks CCS.
Ken, great video. Now I'm looking around at my and my friend's old binoculars in a whole different way.
#5 GlennLeDrew
GlennLeDrew
Posted 26 January 2014 - 07:44 PM
You'd be surprised to learn how many commercial reducers use what are the very same doublets found in binos. For example, the Lumicon Easy Guider and Giant Easy Guider used 50mm and 80mm bino objectives, respectively. Just to name two specific, relatively 'high end' units. The ubiquitous 1.25", so-called 0.5X reducers use 25mm f/4 bino objectives.
#6 tadpoletoo
tadpoletoo
  • Loc: NW Michigan
Posted 29 January 2014 - 10:06 AM
Thanks guys! this is the kind of stuff that keeps me coming back. Dave
#7 JimT
JimT
  • Loc: Milky Way Galaxy
Posted 30 January 2014 - 07:24 AM
Ken
Nice work.
:waytogo: :waytogo:
:bow: :bow:
#8 ccs_hello
ccs_hello
Posted 30 January 2014 - 09:42 PM
Just like to add an important information:
High focal reduction has a steep light cone. To fully illuminate an image sensor, you'd like the objective lens (e.g., donated from a 7x35 bino) as large as possible.
You might find I try to use a larger lens (to avoid optical vignetting), then the medicine bottle (in the shape of reducing profile gradually) to avoid physical vignetting.
Clear Skies!
ccs_hello
#9 rmollise
Posted 31 January 2014 - 07:38 AM
Clear Skies!
ccs_hello
True, but you would need a huge amount of vignetting before a 1/3-inch or 1/2-inch video chip is affected. ;)
#10 ccs_hello
ccs_hello
Posted 31 January 2014 - 08:44 AM
Unk Rod,
Using a smaller focal reducer
with just 23.5mm lens diameter and a type-1/2" CCD, at 0.34x focal reducing ratio, the image sensor is just 10% fully illuminated <-- by on-axis light (cell B29.)
Clear Skies!
ccs_hello
#11 StarStuff1
StarStuff1
  • Loc: South of the Mason-Dixon Line
Posted 31 January 2014 - 03:42 PM
Good video, very Informative.
Years ago I bought a grab bag of small lenses from JerryC0 (American Science and Surplus). Using a couple of the achromats and some color filter housings I made both a .6 and a .5 focal reducers. Worked pretty well and I am still using them.
#12 GlennLeDrew
GlennLeDrew
Posted 31 January 2014 - 04:09 PM
The more aggressive the desired reduction, the faster must be the reducer. No matter how large the lens. For our little video chips, a 50mm f/4 bino objective is really no better than a 25mm f/4.
#13 Dom543
Dom543
Posted 31 January 2014 - 05:05 PM
css_hello,
Is your spreadsheet publicly available? I mean the worksheet with the formulas, not just the screen shot.
Glenn,
Why is that? Can't I make reduction more aggressive by increasing the distance between the reducer and the sensor?
Thank you,
--Dom
#14 ccs_hello
ccs_hello
Posted 31 January 2014 - 06:41 PM
Dom,
The spreadsheet came from one of the Y! group and is not mine. I've asked the author in the past and I did not get approval. (I've also asked him to join CN.) May be in the next long holiday I'll re-write it. It is not difficult at all. The on-axis beam coverage is the special one but is not really difficult (get the new image circle size then divide by the sensor's image area.)
Clear Skies!
ccs_hello
#15 GlennLeDrew
GlennLeDrew
Posted 31 January 2014 - 11:46 PM
css_hello,
Glenn,
Thank you,
--Dom
The increase in separation must be supported by the available reducer lens aperture. When moving the camera farther back, you are effectively pushing the reducer farther up into the light cone, where the beam is wider. The more reduction you demand, the faster must be the reducer if vignetting--or worse yet, aperture reduction--is to be avoided.
